Expansion Joint Maintenance - Concrete & Paving - Contractor Talk
Old 04-24-2015, 10:35 PM   #1
Renaissance Man
superseal's Avatar
Rewards Points: 5,828
I'm fixing up some control and expansion joints in a driveway and I'd thought I post a thread on how I do it.
I know many of you probably practice this as well, but for any of you guys on the fence using 2 part polyurethanes and bulk guns, you should really give it a try.
Even though 1 part tube or sausages can contain quality materials, 2 part products are superior in many ways...bulk value is cheaper, bulk guns dispense more efficiently, the products generally tool better than any other sealant you've ever used and they're just damn good sealants...Vulkem, Sika and Dymeric/Tremco are some of my favs.
On the downside, these aren't water based products and you don't lick your fingers while you're smearing the goop Zylene cut's it well and cleans the tools when your done and whatever you mix up must generally be used within 4 hrs. +/-.
Regardless, preparation is key,...I've saw cut or razored out the old sealant, pressure washed the surface, patched some minor surface defects and allowed it to dry.
Backer rod is next and you want it installed at a consistent height relevant to your joint design, Use the proper sized rod so you don't damage the product during installation. With closed cell foam, if you perforate the jacketing, It can out gas and cause major bubbling of your finished work. Open cell or soft type won't out gas but it's consistency is different and doesn't give as uniform of joint base.
Anyway, I stock both types and a bunch of sizes because you really don't want to be wasting time on your knees installing this necessary component. Soon as I'm done that, I apply bond breaker tape to prevent 3 side adhesion and give the surfaces a final shot of compressed air or leaf blower.
Over to the mixing drill, I use a 3/4" makita with a paddle on low speed. Add the liquid and mix very well for 10 min.
Load the bulk gun and grab some spatulas, you're ready to roll
I'll be broadcasting silica sand over the tooled sealant which is purely an option to help disguise the joint, you may or may not decide to do this although on windy days with debris flying around, it helps keep the sealant free of airborne hijackers which can make quite a mess of your hard work.
Enough already...here's some pics
Expansion joint maintenance-dymonic-sealant-006a.jpg   Expansion joint maintenance-dymonic-sealant-008a.jpg   Expansion joint maintenance-img_1658a.jpg   Expansion joint maintenance-img_1660a.jpg   Expansion joint maintenance-img_1663a.jpg
supersealconstruction.com
superseal is offline
Old 04-24-2015, 10:52 PM   #2
Renaissance Man
superseal's Avatar
Re: Expansion Joint Maintenance
some more less rambling...
Expansion joint maintenance-img_1665a.jpg   Expansion joint maintenance-img_1667a.jpg   Expansion joint maintenance-img_1668a.jpg   Expansion joint maintenance-img_1669a.jpg   Expansion joint maintenance-img_1671a.jpg
Old 04-24-2015, 11:06 PM   #3
Renaissance Man
superseal's Avatar
It's like whip cream, very easy to tool...
Expansion joint maintenance-img_1672a.jpg   Expansion joint maintenance-img_1673a.jpg   Expansion joint maintenance-img_1674a.jpg   Expansion joint maintenance-img_1676a.jpg   Expansion joint maintenance-img_1678a.jpg
Old 04-24-2015, 11:29 PM   #4
Renaissance Man
superseal's Avatar
Helps guard against water, weeds and high heels, well, maybe high heels
The blasting sand is blending with the older crete quite nicely.
Expansion joint maintenance-img_1680a.jpg   Expansion joint maintenance-img_1681a.jpg   Expansion joint maintenance-img_1688a.jpg   Expansion joint maintenance-img_1689a.jpg   Expansion joint maintenance-img_1684a.jpg
The Following 11 Users Say Thank You to superseal For This Useful Post:
aptpupil (09-09-2015), CConcreteEx (04-26-2015), greg24k (10-12-2015), j_sims (10-12-2015), mnld (04-25-2015), Railman (10-12-2015), Rio (10-11-2015), SmallTownGuy (10-12-2015), thezoo (04-25-2015), Xtrememtnbiker (04-25-2015), Youngin' (04-25-2015)
Old 04-25-2015, 08:24 AM   #5
mnld's Avatar
Trade: drywall junky
Rewards Points: 498
And crap......... You had to go and learn me sumthin on a Saturday morn.:-) :-)
mnld is offline
Old 04-25-2015, 08:28 AM   #6
mnld's Avatar
Rewards Points: 498
I've got a concrete porch that's eight years old and needs something done with the expansion joints. What are you doing next Saturday??
mnld is offline
Old 04-25-2015, 08:45 AM   #7
thezoo's Avatar
Rewards Points: 238
Nicely done and as usual extreme attention to detail.
thezoo is offline
The Following User Says Thank You to thezoo For This Useful Post:
Old 04-25-2015, 08:59 AM   #8
SAcarpenter's Avatar
Trade: residential/remodeling carpenter
Rewards Points: 938
Wow! That's some nice work. Extremely clean
You can rest when you're dead
SAcarpenter is offline
Old 04-25-2015, 01:27 PM   #9
Hack
asevereid's Avatar
Rewards Points: 476
That's some great work there.
Never see that attention to detail around here.
Thanks for the walk-through.
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
Old 04-25-2015, 06:45 PM   #10
Renaissance Man
superseal's Avatar
Thanks guys, you should she me frost a cake
It's not really rocket science, just takes a little practice and know how, half of what you now know
Hmm... that attention to detail theme sounds familiar
https://www.youtube.com/watch?v=LfFSaRfoGcI
The Following 2 Users Say Thank You to superseal For This Useful Post:
greg24k (10-12-2015), SmallTownGuy (10-12-2015)
Old 04-26-2015, 07:07 PM   #11
Renaissance Man
superseal's Avatar
I finished up the driveway and the total tally for sealant came in at 3 gallons /46 pounds, or approx 36 tubes.
Even though it's a fast cure, it still takes about 3 days to fully cure beyond damaging the surface.
I try to keep it down in the joint a bit so cars can immediately run over it but will tell customers to keep the kids and animals away from it for a couple of days.
Most of the joints on this drive required the 3/4" and 1" knife and several of the expansions required the 1 1/4" knife tip to shut them up.
Glad it's done, it's a lot of bending over and knee work so be sure to grab you knee pads- you're gonna need'em...
Expansion joint maintenance-sealant-work-001a.jpg   Expansion joint maintenance-sealant-work-002a.jpg   Expansion joint maintenance-sealant-work-006a.jpg   Expansion joint maintenance-sealant-work-004a.jpg   Expansion joint maintenance-sealant-work-005a.jpg
Old 09-01-2015, 09:24 PM   #12
Empire Seal's Avatar
Trade: sealants, coatings
Rewards Points: 8
no need to apply bond breaker tape over the baker rod. Other than that your work looks great!
Empire Seal is offline
Old 09-07-2015, 01:04 AM   #13
Love me some Concrete
brhokel606's Avatar
Rewards Points: 4,113
Wow, I am glad this thread was brought back to life. Fricken incredible looking, dang....never ceases to amaze me how good most of you guys are at your choosen craft.
Super, do you save the cut dust to use in the joints? I had never thought of spreading the silica dust over the caulk, that is an amazingly great idea, makes the joint so much nicer.
I know I'm crazy...I love concrete
brhokel606 is offline
Old 09-08-2015, 11:02 PM   #14
Rewards Points: 8
sand gives it a grout-like appearance.
Old 10-11-2015, 07:16 PM   #15
Renaissance Man
superseal's Avatar
Sorry, I didn't catch the revived thread...no you don't save any dust, it'd be too fine anyway. It's simply #1 blasting sand, pure silica sand. Must be kept dry to perform well.
Old 10-11-2015, 07:36 PM   #16
Renaissance Man
superseal's Avatar
I hear ya, not all joints got the backer rod so I had it out for them. The roll would have probably gone to waste since it began telescoping out anyway and was getting old.
Not many real commercial caulkers around here...nice to have you on board!
Old 10-11-2015, 10:30 PM   #17
Designer/Contractor
Rio's Avatar
Rewards Points: 2,616
Thanks for the good information and great photos that so clearly showed what you were doing.
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
superseal (10-12-2015)
Old 10-12-2015, 02:48 PM   #18
General Contractor
greg24k's Avatar
Rewards Points: 8,420
Beautiful work as always Bro!
greg24k is offline
Alternate to expansion joint??? MKnAs Dad Flooring 11 04-17-2013 08:09 PM
OC Duration expansion?? FramingPro Roofing 57 03-19-2013 07:35 PM
Expansion Joint Below Grade/Negative Side basementman Construction 1 01-11-2013 07:21 PM
Questionss on Hardwood underlayment and expansion newtofloor Flooring 8 11-24-2005 08:18 PM
