Concrete... Poly Or No Poly. - Concrete & Paving - Contractor Talk
Old 03-27-2014, 06:03 PM   #1
S.U.M's Avatar
Trade: Brick/Stone Mason
Rewards Points: 1,286
Hey, I normally hangout in the masonry section but I do have a question regarding poly vapour barrier under concrete.
I am pouring a basement floor for a friend, I don't normally do floors just small side walks, kerbs, the odd step or two.
The specs on the drawing calls for 3" of 15mpa concrete with poly, but I was told that the code here in Ontario says if the concrete strength is 25 mpa or more there is no need for poly.
I also understand it takes a lot longer to finish the concrete with ploy as the water has no where to escape.
Anyone got any additional info on this.
Thanks.
S.U.M is offline
Old 03-27-2014, 06:17 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Re: Concrete... Poly Or No Poly.
Put the super 6 down, it prevents moisture escaping during the cure, your correct if can slow the cure down, but I would not call it a measurable amount of time, there are so many variables which can affect how long before you can get on the slab and finish it.
After the cure it prevents below slab moisture from coming up through the slab
Chris
Chris Johnson is offline
Old 03-27-2014, 06:20 PM   #3
S.U.M's Avatar
Thanks Chris, If I was to up the strength of the concrete would I still need it.
S.U.M is offline
Old 03-27-2014, 06:47 PM   #4
tgeb's Avatar
Rewards Points: 1,032
I put poly under all of our slabs.
You don't want the subgrade pulling the water out of the concrete.
Any dry or wet areas in the subgrade will cause the slab to cure unevenly, you can end up with dry spots while the rest of the slab is still too soft work.
I have never heard of eliminating poly based on the strength of the mix.
www.gebcon.com
tgeb is offline
Old 03-27-2014, 06:57 PM   #5
S.U.M's Avatar
Thanks I have never heard of it either, one last thing I would think putting it on top of the gravel would be the right thing to do is this correct.
S.U.M is offline
Old 03-27-2014, 07:20 PM   #6
tgeb's Avatar
Yes the poly goes right over the stone, unless the slab requires foam insulation board, then the poly goes over the foam.
www.gebcon.com
tgeb is offline
If you're not on Facebook, you should be. Sir Mixalot Marketing & Sales 1854 02-24-2019 04:59 PM
Help Thinking outside the box here... CONCRETE HELL!! JeremyBCalnan Tools & Equipment 37 06-24-2014 10:33 PM
Concrete Floor, no vapor barrier ericomerico Specialty Coatings 6 06-17-2014 08:27 AM
need help on bidding for concrete jobs! Bconcretegirl Marketing & Sales 15 12-04-2013 12:25 PM
Concrete footing removal 18withtools Demolition 19 01-29-2013 07:34 PM
