Concrete Pad Setup Questionz - Concrete & Paving - Contractor Talk
Old 04-29-2019, 07:48 AM   #1
awelstad's Avatar
Trade: Pole Building
I have a guy who is providing my company all the flat work. generally 4" slab with rebar. not anything fancy.
This last job he has been doing things I feel are questionable.
we have to bring in crushed gravel 3/4 minus.
In the back corner we are almost 16" out of grade and the gravel is flowing out of the bottom of the green board. I'll attach pics.
My question is shouldnt he compact the gravel every 4" or 6"? or can he use a vibrator with the full 16"?
Also is it ok that the gravel is just flowing out the bottom of the green board?or should we add more boards?
Thanks in advance
I tried to add pictures but it's not working.
awelstad is offline
Old 04-29-2019, 09:03 AM   #2
Fishindude's Avatar
Trade: Industrial
Rewards Points: 864
Re: Concrete Pad Setup Questionz
Yes crushed stone should be placed in shallow lifts and compacted each lift. Thickness of lifts depends upon the material and the type of compactor.
I assume you mean that the stone under the slab is leaking out outside of the building and leaving a hollow void under the slab. This is a problem and will lead to the slab failing if they load it in that area. Build up some fill on the outside of the building if possible so the stuff under slab can't leak out. Crushed stone will never hold in place "vertically" at the edge of a building without a retaining wall of some sort.
Fishindude is offline
The Following 2 Users Say Thank You to Fishindude For This Useful Post:
concretemasonry (04-29-2019), Seven-Delta-FortyOne (04-29-2019)
Old 04-29-2019, 04:56 PM   #3
awelstad's Avatar
Would I be able to just add more gravel? or does it need to be something to hold the gravel back?
or would I just keep adding gravel till it hits the greenboard?
awelstad is offline
Old 04-29-2019, 04:59 PM   #4
awelstad's Avatar
awelstad is offline
Old 04-29-2019, 05:06 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,343
How long have you been in the pole building business?
Tinstaafl is offline
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
Bull Trout (04-29-2019), Seven-Delta-FortyOne (04-29-2019)
Old 04-29-2019, 05:42 PM   #6
awelstad's Avatar
I have been with the company for 1 year now. I dont know much of the concrete side and am not around when it comes to specifics.
awelstad is offline
Old 04-29-2019, 08:53 PM   #7
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 562
Did the topsoil get stripped off under the building? Doesn't look like it from here....
mrcat is online now
Old 04-29-2019, 08:58 PM   #8
mrcat's Avatar
Rewards Points: 562
I usually have the site leveled up before we start, and like to have the pad 3-6 feet larger than the building size depending on the elevation difference between the pad and the existing grade.
mrcat is online now
The Following 3 Users Say Thank You to mrcat For This Useful Post:
Bull Trout (04-29-2019), jhark123 (04-29-2019), Seven-Delta-FortyOne (04-29-2019)
Old 04-30-2019, 06:38 AM   #9
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 400
That's how it's typically done here too, then I can do finish grading inside.
If it isn't though, extra stone needs to be brought in on the outside and tamped just the same as the base inside.
NYCB is offline
The Following User Says Thank You to NYCB For This Useful Post:
mrcat (04-30-2019)
Old 04-30-2019, 08:19 AM   #10
Fishindude's Avatar
Trade: Industrial
Rewards Points: 864
You need more stone (or soil) installed on the exterior of building and more gentle slope away from the building. Get some of the exterior fill up on that treated band board so the interior fill can't leak out under it.
If you're not on Facebook, you should be. Sir Mixalot Marketing & Sales 1854 02-24-2019 04:59 PM
J&L CUSTOM CONCRETE Palm Springs, CA | Custom Concrete Contracting Jack Harris Help Wanted or Looking For Work 0 01-06-2015 03:14 PM
Help Thinking outside the box here... CONCRETE HELL!! JeremyBCalnan Tools & Equipment 37 06-24-2014 10:33 PM
Concrete Floor, no vapor barrier ericomerico Specialty Coatings 6 06-17-2014 08:27 AM
Lightweight concrete alternative in a condo DanFreysinger Flooring 17 11-14-2012 10:10 AM
