Concrete With Fly Ash Vs. Concrete Without? - Concrete & Paving - Contractor Talk
Old 03-31-2010, 08:34 PM   #1
cdkyle's Avatar
Trade: Concrete & General Construction
Location: The Heartland of the United States of America
Rewards Points: 552
What is your opinions on using concrete with fly ash and using concrete without it?
The reason I am asking is, we have for quite some time, used ready mix suppliers who use the fly ash (at around 15% ratio I think.) But, we have recently (last couple of months) been using a ready mix supplier who does not use fly ash, straight cement only, or so we are told.
The non-fly ash supplier's concrete definitely gets harder faster. But we have been having some problems of late with the finishing characteristics of the mud. Separation seems to be the greatest issue we have. My guys are complaining about not be able to float and trowel as easily.
The fly ash including suppliers concrete certainly finishes better, but does not seem to be near as good of a final product.
I'm not joking, you can't hardly drive a concrete nail in the non fly ash concrete the next day.
Any thoughts?
cdkyle is offline
Old 03-31-2010, 08:41 PM   #2
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Re: Concrete With Fly Ash Vs. Concrete Without?
I believe you.
It's the same with the C4 concrete mix. It is stickier and is therefore harder to work with. And it gets harder faster.
I wonder what the numbers are. For example, if you require 4000 psi concrete, why pay for 6000?
I suppose it all boils down to economics.
cleveman is offline
Old 03-31-2010, 09:17 PM   #3
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,960
The straight concrete mix will always cure faster than a mix with fly ash in it, but the ultimate strength will be about the same. Just don't pour a big slab in cold weather with a fly ash mix if you expect to finish it the same day. - I have seem some long hours or a second crew waiting most of the night on a big indoor slab in an unheated building. Some ended up being torn out because of the low temperatures of the aggregates or the base under the slab that dropped the temperature below critical levels when the cement reaction was too slow.
Fly ash is now not the "junk" or by- product that was used as a low cost cement replacement years ago. The good fly ash distributors have the supplies tied up for years and do the testing and carefully control the properties. Some cement is also made with fly ash as a raw material in the process.
Dick
concretemasonry is offline
Old 04-01-2010, 03:03 PM   #4
Concrete Mike
CONCRETE MIKE's Avatar
Trade: concrete
Rewards Points: 250
Any thoughts?
What mix are you using? (6sac,6 1/2 , 7, 800lb ms) I think concrete without fly ash finishes better. Fly ash reduces the heat in concrete. Seperation, sound like you are finishing your concrete when there is high winds, that will create some seperation, also are you using a slag mix?
CONCRETE MIKE is offline
Old 04-01-2010, 09:22 PM   #5
cdkyle's Avatar
Rewards Points: 552
Most here use 5 1/2 sack mix.
cdkyle is offline
Old 04-09-2010, 10:06 PM   #6
Concrete John's Avatar
Trade: Concrete/Excavation
Rewards Points: 25
I agree with all said as mentioned , flyash is basically a filler , but in recent years mix designs have broaden massively , specific everything, what conditions are you pouring in ?? wet / dry / windy ?? maybe try wetting the base just prior to pouring . are you using any surface retarders? Maybe your supplier has chnged something in the mix ?
Concrete John is offline
Old 04-13-2010, 06:47 AM   #7
mugzy's Avatar
Trade: Concrete
Mixes with flyash take longer to make initial set however they finish much better.
mugzy is offline
Old 04-13-2010, 07:08 AM   #8
Anti-wingnut's Avatar
Rewards Points: 3,420
Chance are we are all going to get better acquainted with concrete containing no fly ash in the future
http://enr.ecnext.com/coms2/article_...FlyAshAsbest-1
Anti-wingnut is offline
The Following User Says Thank You to Anti-wingnut For This Useful Post:
DJ9222 (07-19-2010)
Old 04-13-2010, 01:27 PM   #9
rustyjames's Avatar
Rewards Points: 1,732
I read that on another site yesterday; now when you click on it they want a subscription to read it.
rustyjames is online now
Old 07-19-2010, 04:18 PM   #10
cdkyle's Avatar
Rewards Points: 552
Check out this link:
http://www.newsok.com/article/3476858
cdkyle is offline
Old 07-19-2010, 07:58 PM   #11
Wood Butcher
bhock's Avatar
Trade: Remodels/Custom Cabinets/Granite Countertops
We recently poured a water disapator(sp) for the irrigation district and it was spec'd for 25% flyash due to the alkalinity of the water that runs through it.
And we noticed the set time for sure. So we actually had to have them ad high early for the 2nd and 3rd pours.
Never thought I would add high early during 80 deg weather.
As far as flat work finishing I did notice the fly ash mix has a nicer cream come up when floating..
Brett Hocking
Eagle Eye Construction/Aspen Custom Cabinets
Buffalo, WY
bhock is offline
Old 07-19-2010, 09:34 PM   #12
The reason it can make a smoother finish that can be easier or slower to finish is that they act like little round "marbles" in the mix. Ash can improve some of the chemical properties, but should be certified and tested to know what they are since there is good and bad ash around, but the good ash is under contract for years in advance by the larger distrubutors.
Dick
The Following 2 Users Say Thank You to concretemasonry For This Useful Post:
bhock (07-19-2010), Fouthgeneration (10-10-2014)
Old 07-25-2010, 12:34 PM   #13
FlatworkGuy's Avatar
Trade: Precision Concrete Finishing
Rewards Points: 75
When I came to Texas, I discovered that most here were using a slury mix of 3 sack .. .. scary stuff indeed.
The guys at the batch plant think I'm nuts, but the least I've ever ordered here was 5 (at a 4 slump) .. added fly ash by percentage for those really hot days and a J20 cure for the final ..
The only separation issues I've seen down here involved juiced 3 sack (too much water) and no fly ash
Precision Concrete Finishing | Facebook
FlatworkGuy is offline
Old 07-25-2010, 01:31 PM   #14
A 3 bag mix on a slab would disappear over one winter or so here - No mater what magic stuff was added.
Around here, it is hard to get anything less than 4000 psi and 5-7% air and 3-4" slump delivered for a driveway. If you demand less, you may not get it or at least have to sign a waiver eliminating the suppliers liability for all problems. - Not enough profit in a volume of a driveway if you have failures for any number of different reasons.
Dick
Old 07-25-2010, 01:53 PM   #15
Rewards Points: 75
I discovered all of this when I signed on to sub a job with a builder from Florida last year. My eyes popped out of my head when I saw the ticket and I turned 4 of the trucks around thinking the mix design was a mistake.
I learned after that, that the 3 sack slurry was the default around here, unless otherwise specified. I've only ever used slurry as a base at best on jobs with poor ground .. never as a main for any finished product.
At any rate, with the exception of Knife River, I get my 5 1/2 sack mix whenever I place an order these days around here from the others w/out asking specifically for it. Anything that resides on City/County property gets a 6 1/2 sack mix, even though it isn't really required by coding, just like how we do in North Central Montana.
Old 07-26-2010, 05:39 AM   #16
cdkyle's Avatar
Rewards Points: 552
Using a 3 sack mix vs. a 5 sack mix is probably saving the ready mix company $10 - $15 per yard.
Question is, are they passing that savings on to the buyer?
But, who would willing and knowingly use a 3 sack mix?
I wonder what psi a 3 sack mix would attain?
cdkyle is offline
Old 07-28-2010, 08:37 PM   #17
Rewards Points: 75
Absolutely not .. my price is 83 bucks a yard, 3 sack or 5 ..
um .. Transit Mix .. Knife River (Southeast Texas) ..
My guess would be (I haven't done the math lately), roughly 1500 to 1800 PSI and that's about it .. the stuff drills like sandstone, and wears about the same too.
Old 07-28-2010, 08:51 PM   #18
Project Superintendent
mudpad's Avatar
Rewards Points: 2,000
Around here we call that "lean" concrete and we use it for things like mudsills and filling dirt seams in weathered rock under footings where rock bearing is specified.
No way we would pay full price for "lean"
Steve
mudpad is offline
Old 07-28-2010, 09:33 PM   #19
Rewards Points: 75
It's like I said in the previous post .. slurry being what it is, is only really used for poor ground .. but the Texans around here use it like it's the real deal for all of their finish jobs.
Old 07-28-2010, 09:57 PM   #20
Cement is not the biggest cost in the delivered price of concrete. - It is just one item like different aggregates, admixtures/fly ash, but one of the biggest costs is delivery (time, distance and yds per load) because of the truck cost, fuel cost and clean-out/EPA costs.
If there is a lot of concrete used in an area the price (for the same profit) of higher strength concrete could be the sames as low strength concrete. - Especially if the job site time is higher for higher for the higher strength concrete, since time can be longer. - Just like pricing a job.
The ma & pa days of owners just marking up products based on material costs are gone.
Dick
Concrete Company delivered junk concrete. How best to pursue? marcomjl Concrete & Paving 47 06-03-2014 10:17 PM
Tire line in concrete after finishing. aydin_eng Flooring 34 03-09-2010 10:03 PM
4x4 posts in concrete vs. saddles Strongarm Decks & Fencing 20 08-31-2009 09:41 PM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 04:18 PM
