Concrete And Fire - Concrete & Paving - Contractor Talk
Concrete And Fire
Old 02-20-2011, 09:40 PM   #1
Dan_Watson's Avatar
Rewards Points: 2,594
Concrete And Fire
Concrete table with a burner in the middle.
GFRC 'standard' grey flanks and base, red center. The top is one pc and the base is another.
More here: http://www.facebook.com/album.php?ai...d=253525421721
Dan_Watson is offline
Old 02-23-2011, 10:03 AM   #2
Dan_Watson's Avatar
Re: Concrete And Fire
No feedback at all? I am slightly shocked no one has a smartass comment or critique...
Old 02-23-2011, 11:26 AM   #3
jomama's Avatar
Trade: Concrete & masonry
Rewards Points: 166
Well then, how's this?
Look's great as long as you're not using it to sacrifice small animals.............
No really, that's awesome IMO.......
How about some more details on the fire set-up?
jomama is offline
Old 02-23-2011, 11:49 AM   #4
AmeliaP's Avatar
Trade: Masonry
Rewards Points: 1,624
nice!
AmeliaP is offline
Old 02-23-2011, 11:53 AM   #5
fireguy's Avatar
Trade: Fire Suppression Equipment Sales & Service
Rewards Points: 324
playing w/fire is always cool.
what is the burner? A griil burner or a piece of pipe w/holes drilled in it?
You do have regulator on the supply line?
fireguy is offline
Old 02-23-2011, 01:11 PM   #6
Dan_Watson's Avatar
No small animals as of yet. Copper with holes in it, the only regulator used in the pic was the valve on the propane tank but when its actually used there will be a secondary that has more control.
Old 02-23-2011, 01:40 PM   #7
jason.'s Avatar
Trade: Remodeling, Construction, Home Improvement
Rewards Points: 250
Nice work, but how is that functional?
www.CaConstructionCenter.com
13659, Victory Blvd #261, Van Nuys, CA-91401 | Twitter | Facebook
Contact# 800-372-4080
jason. is offline
Old 02-23-2011, 01:43 PM   #8
Dan_Watson's Avatar
Outdoor table....when its chilly at night you sit around it and drink, or talk, or sing, or all three...
Old 02-23-2011, 02:11 PM   #9
jason.'s Avatar
Rewards Points: 250
Ahh I see nice
jason. is offline
Old 02-23-2011, 02:34 PM   #10
DavidC
DavidC's Avatar
Rewards Points: 2,006
Nice concept. I can see using that when I sacrifice small animals. The woodchucks and rabbits have been destroying my garden the last couple of years.
Is this an original idea of yours?
Can we get a daylight pic of the work?
I like the rhythm of 3 questions so filled this space?
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 02-23-2011, 02:41 PM   #11
Dan_Watson's Avatar
Original idea yes, for a design challenge. There are obviously other tables out there with fire coming out but the colors, shape, size, implementation all as original as anything can be anymore.
Closest to daylight I have here.
No Flames:
Right after demold:
The Following User Says Thank You to Dan_Watson For This Useful Post:
DavidC (02-23-2011)
Old 02-23-2011, 03:32 PM   #12
DavidC
DavidC's Avatar
Nice work. I like the contrast in color, probably a good idea with the burner installed.
Is that a vibrating table in you shop?
Good Luck
DavidC is offline
Old 02-23-2011, 04:04 PM   #13
Dan_Watson's Avatar
No vibrating table. No need. The face coat is sprayed eliminating most pin holes..the gray was a little dry this time and came out a little rough but the red was nice.
Old 02-23-2011, 05:01 PM   #14
DavidC
DavidC's Avatar
That's a pretty sharp contrast between the colors. How did you prevent them from bleeding into each other?
If it's too many questions just kick me aside. I'm playing with wet cast right now and haven't ventured into spraying, yet.
Good Luck
DavidC is offline
Old 02-23-2011, 05:31 PM   #15
Dan_Watson's Avatar
Questions are very welcome. I'm new to all of this and wouldn't be here if others didn't answer all of my questions. The gray was done first with a plug where the red is then red was done after. I would do the red first if I did it again.
Old 02-23-2011, 06:59 PM   #16
DavidC
DavidC's Avatar
Every time I look I think of something else. This concrete stuff can be addictive.
Any special considerations in the red mix? Thinking about the heat from the flame.
Good Luck
DavidC is offline
Old 02-23-2011, 07:06 PM   #17
Dan_Watson's Avatar
I feel the same way. My girlfriend says I have an issue. That mix can be in direct contact with 300c and the flame is far enough away it should not be an issue.
DavidC (02-23-2011)
