Concrete Chipping When Cut With Saw???? - Concrete & Paving - Contractor Talk
Old 07-13-2010, 07:24 PM   #1
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
I just poured some concrete and went to cut it two days later. I just bought a brand new stihl cuttoff saw and brand new high quality blade. When I started cutting I notices that I was getting a lot of chipping along my saw line.
Anyone know why?
I talked to my local ready mix guy and he thought it was because of the vibration in the saw. What do you guys think?
I don't want to have to rent a walkbehind saw everytime I have to cut concrete.
Thanks
Spencer is offline
Old 07-14-2010, 12:52 AM   #2
Kgmz's Avatar
Re: Concrete Chipping When Cut With Saw????
First did you check the basics, is the blade running true?
Is it a diamond blade or abrasive?
If a diamond blade is it a wet or dry blade?
Is the blade the right size arbor, or do you have one of those Stihl plastic adapter bushings in there.
Now the best investment I bought for our Stihl cut off saw was a Quik Cart. This is a small cart specially made for your saw so you can use it like a walk behind. Available from Stihl, and it sure beats bending over trying to keep the saw straight and true.
Our cart doesn't have the water tank since we only use dry diamond blades, and also a older model so isn't as nice as the one in the pic and doesn't have the handle for height adjustment at the top.
Kgmz is offline
Old 07-14-2010, 09:21 PM   #3
beretta13's Avatar
Trade: Concrete contractor
Green concrete will chip everytime if you use a regular concrete saw. The answer to your problem is a SOFFCUT, It's the only was to go in my opinion. You can saw inside corners the same day you pour. If you do stick with the stihl saw run it one of two ways either idle or wide open.
beretta13 is offline
Old 07-14-2010, 09:30 PM   #4
Elyrain's Avatar
Rewards Points: 446
Too much RPM. Those demo saws spin at 8k+ soffcut saws are around 3-4k.
Elyrain is offline
Old 07-14-2010, 09:49 PM   #5
cdkyle's Avatar
Trade: Concrete & General Construction
Location: The Heartland of the United States of America
Rewards Points: 626
If it had been two days after the pour, the concrete should not have been too wet to have used a regular saw. Soff cut saws are for the same or next day. Unless this pour was in a basement or other high humidity area.
cdkyle is offline
Old 07-14-2010, 10:05 PM   #6
house bldr's Avatar
Trade: general contractor
Rewards Points: 250
First of all,2 days later is really to late to cut concrete,problem is, any earlier and you will have minor chipping on the edges of the cut.You can keep it to a minimum by keeping the rpm down and keep the saw running true so the blade doesn't bind in the cut.
house bldr is offline
The Following User Says Thank You to house bldr For This Useful Post:
Spencer (07-15-2010)
Old 07-15-2010, 06:30 PM   #7
Livin the dream...
Spencer's Avatar
Hey I really appreciate all the good advice guys.
I did decide to rent a walkbehind today from my local ready mix plant. ($40) It was the way to go. It produced a very nice cut. It was at least a sixteenth thinner than my cutoff saw??? It looks a lot better. I think until I can buy my own I will continue to rent one on jobs like this.
Spencer is offline
Old 07-15-2010, 08:06 PM   #8
beretta13's Avatar
You can buy a soffcut x150 for under 2 grand, well worth it
Old 10-08-2010, 06:31 PM   #9
Frenchie@dbw's Avatar
Trade: Account Manager
x-150 is also only a 6" blade It depends what are you using the soffcut for you are talking about late entry into green concrete. You have two options Use the Soffcut brand or the Greencut brand. What is the difference. When you are using the Soffcut blades you are suppose to change the guard every 2 blades. Kinda gets expensive after a while if you use it alot. There is a nice feature about Greencut With every blade you get a boot which eliminates the need to keep buying/replacing the guard. But Yes a green concrete blade will be what you want. The bonds of the blade also matter though when it comes to cutting green concrete because it is really abrasive at that state. So the different hardness and softness in the bonds matters so you do not glaze over the blade and you get a nice clean cut.
Frenchie@dbw is offline
Concrete Company delivered junk concrete. How best to pursue? marcomjl Concrete & Paving 47 06-03-2014 10:17 PM
Concrete with Fly Ash vs. Concrete without? cdkyle Concrete & Paving 19 07-28-2010 09:57 PM
Tire line in concrete after finishing. aydin_eng Flooring 34 03-09-2010 10:03 PM
4x4 posts in concrete vs. saddles Strongarm Decks & Fencing 20 08-31-2009 09:41 PM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 04:18 PM
