Cold Weather Concreting - Concrete & Paving - Contractor Talk
Old 01-23-2013, 01:09 PM   #1
perimeterbrew's Avatar
I recently had a footer for a retaining wall poured and the person who did the job did not seemed concerned with the temperature falling to 20 degrees the night after we poured. He covered the footer with insulation and I was told the use a heater to keep it warm. I ran the heater for 20 minutes every couple hours till about 1am or about 9 hours after the pour, then started the heater again in the morning around 8am. I assumed the concrete contractor knew what he was talking about but the more I read about concreting in cold weather, I'm unsure of the strength of the concrete. Opinions? Is there any way to tell now the strength of the footer?
perimeterbrew is offline
Old 01-23-2013, 02:43 PM   #2
stombaugh85's Avatar
Trade: Roofing
Rewards Points: 284
Re: Cold Weather Concreting
If you dont trust your concrete guy then why did you hire him?
If your worried about pouring in the cold then why didn't you wait?
Your the home owner right?
Sounds like the concrete guy took precautions covering the pour with insulation. Concrete is a chemical reaction which will generate it own heat. Next time do your research before you hire someone.
stombaugh85 is offline
Old 01-23-2013, 03:07 PM   #3
Crete's Avatar
Trade: EIFS
Rewards Points: 25
The concrete is fine. Or are you looking for a different answer so you don't have to pay?
Crete is offline
Old 01-23-2013, 03:22 PM   #4
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,960
You are concerned by the air temperature and not the soil or concrete (that generates some heat) and forgetting about the thermal storage of heavy construction materials. the insulation was really to retain the internal heat and a few little puffs of warm air do not have that much effect.
In MN, a good concrete and masonry contractor can excavated and build with block in 4 days to let the nail benders in to cap and enclose and heating can be temporarily hung from the basement ceiling and heat the soon to be closed space and extend the construction system when it is needed. - A retaining wall footing is a little different because it is smaller and not deep enough to get to warmer soil.
Dick
concretemasonry is online now
Old 02-09-2013, 10:37 AM   #5
daniel8675's Avatar
Trade: Concrete Contractor
The first night is not as critical as the 2nd night. The first night its creating enough heat in its setting up process that it will be ok but by the 2nd night, the heat has dissipated and there is still moisture in the concrete that can freeze. If your temp got up during the day and its covered, as he did, it will retain the heat it absorbs during the day. You will be fine.
daniel8675 is offline
Who here makes a mean stew, home-made cold weather working man stew? Crawl-Dog Off Topic (Non Trade) 35 02-06-2011 04:44 PM
Makita LXT and Cold Weather HandyHails Tools & Equipment 56 01-02-2011 09:11 PM
OSI QUAD in cold weather master of none Windows, Siding and Doors 8 12-21-2010 10:04 PM
Cold Weather Mix Specs Southengineer Concrete & Paving 3 01-11-2010 07:27 PM
