Best Solution For This Garage Slab Edge? - Concrete & Paving - Contractor Talk
Old 08-30-2018, 12:34 PM   #1
Greggw208's Avatar
Trade: General contractor
Rewards Points: 4
Customer had this fixed twice before, one side and then the other. He said they removed, drilled into existing slab to add rebar to stabilize the newly poured edge. Both failed as you can see. The rest of the slab does not seem to have sunk, one hairline crack, some efflorescence (or maybe salt from vehicles).
Looking for the right permanent solution. Some ideas I've heard include stabilizing with cement piers, cutting further into the slab to get joint away from the door. Need expertise, thanks!
Best solution for this garage slab edge?-img_0747.jpg   Best solution for this garage slab edge?-img_0748.jpg   Best solution for this garage slab edge?-img_0749.jpg   Best solution for this garage slab edge?-img_0750.jpg
Greggw208 is offline
Old 08-30-2018, 03:33 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,292
Re: Best Solution For This Garage Slab Edge?
can't really tell what you have going on there.
all the pics just look like a demo job waiting to happen.
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
avenge (08-30-2018), tgeb (08-30-2018)
Old 08-30-2018, 04:20 PM   #3
Donohue Const's Avatar
Rewards Points: 1,530
looks like somebody keep trying to put a bandaid on the issue
the asphalt is all busted up
maybe they should dig it out and put a proper apron on
hard to tell if the slab in the building from the pic is good?
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
Old 08-30-2018, 08:04 PM   #4
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 920
Are you in an area subject to freeze and thaw conditions? That will wreck an area in front of a garage just like that, if not addressed properly.
www.gebcon.com
tgeb is online now
Old 08-30-2018, 08:18 PM   #5
Greggw208's Avatar
Rewards Points: 4
It's in Minnesota, so yeah, freeze and thaw. Southern exposure. The rest of the slab looked fine. Probably 30 years old and showing typical wear for that age. One hairline crack, level, and a little salt damage from road salt on cars being brought in, nothing major.
Void under garage slab dayexco Construction 6 11-26-2017 10:59 AM
4" vs. 6" garage slab Rio Construction 22 06-12-2016 07:49 PM
Looking for best solution to bring water into New Garage Big_Ben Plumbing 4 09-16-2014 09:03 PM
Garage slab slope dsnider General Discussion 4 12-02-2011 05:22 PM
