Converting Softplan To CAD, Or AutoCAD? - Drafting & CAD Forum - Contractor Talk
Old 06-22-2019, 08:30 AM   #1
META's Avatar
Trade: General and Trades
Rewards Points: 5,814
Anyone know of a streamlined way of converting Softplan data to CAD or AutoCAD, etc...in order to render 3d models? I know it will require additional measurements.
I have a reasonably complex home and roof system I am looking to bid the framing on. The last time I had one of these, the truss engineers ended up doing a 3d model as well.
Any help is appreciated.
META is online now
Old 06-22-2019, 09:52 AM   #2
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 190
Re: Converting Softplan To CAD, Or AutoCAD?
I believe that SoftPlan has it's own redering and/or ray tracing engine like Chief Architect does but perhaps you only have the 2D PDF plans for the project?
In which case you may have to have someone build a new 3D model from the 2D plans you do have in order to render or ray trace.
You would want either a SoftPlan, Chief Architect or Revit user to build the model. I think that Chief Architect would be the better choice.
Andy
ScipioAfricanus is offline
The Following 2 Users Say Thank You to ScipioAfricanus For This Useful Post:
META (06-23-2019), overanalyze (06-22-2019)
Old 06-22-2019, 10:00 AM   #3
META's Avatar
Thanks Andy. I could get access to the raw data from SoftaPlan if helpful. The draftsman is family so 3D rendering would be a bonus for his business.
META is online now
Old 06-22-2019, 10:10 AM   #4
Texas Wax's Avatar
Rewards Points: 1,990
Softplan 2016 has an export option to Sketchup.
Export to CAD or AutoCad is typically-native 2D. You need to export to a 3D format (file extension) for most other applications to interpret the 3D data. Such as Sketchup and from there out to other applications that integrate with it or formats that can be exported from sketchup to the 3D oriented application.
Not very streamlined but Sketchup to family members app maybe quicker than rebuilding in 3D
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
META (06-23-2019)
Old 06-22-2019, 10:12 AM   #5
Eater of sins.
Rewards Points: 190
If he has the Professional version then he has the ability to do 3D rendering in the program. I think that the professional version and the remodel versions will both convert their SoftPlan files into DWG files if that is what you need.
Andy.
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
META (06-23-2019)
Old 06-22-2019, 10:26 AM   #6
Texas Wax's Avatar
Andy.
Unless something has changed, dwg is 2d ins't it Andy?
Old 06-22-2019, 11:32 AM   #7
Eater of sins.
Rewards Points: 190
DWG is also 3D. It is just really difficult to create 3D in AutoCAD and then render it or ray trace it.
Andy.
Old 06-22-2019, 01:02 PM   #8
Texas Wax's Avatar
Andy.
3D from AutoDesk to Autodesk product for sure and it's AutoCad revision dependent, not backward comapitable. Haven't exchanged from autocad to 3D outside of the Autodesk Family in 4-5 years.
Now that every swinging dick has a cad app that renders pretty pics (or at least good enough), don't really matter to me one way or the other. Sketchup was often a good go between, if the Cad/3D app has support for formats it can read. And in turn a more advanced/wider set of formats suitable for other applications.
Old 06-22-2019, 01:17 PM   #9
META's Avatar
I typically need to visualize how truss design and other roof components need to be assembled, after I am on site. This is usually because I do not always get a component list prior to bidding jobs.
I think it was AutoDesk that I had a demo of on my Android. That was an awesome program for visualizing intercepting roof and cathedral lines. The overframe work can also be tedious depending on the job.
The job in the OP, is going to be a messy roof with overframe on top of overframe.
META is online now
Old 06-22-2019, 02:16 PM   #10
Eater of sins.
Rewards Points: 190
IF done carefully and precisely enough, Chief can provide you with great detail in your truss plan in 3D.
I didn't spend much time on this as the roof planes are insanely complicated and ridiculous.
Andy.
META (06-22-2019), overanalyze (06-23-2019)
Old 06-22-2019, 04:51 PM   #11
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 864
No offense to your family member but that is a needlessly horrible design. $$$$$
Big Johnson is online now
ScipioAfricanus (06-22-2019)
Old 06-22-2019, 06:32 PM   #12
META's Avatar
It's what happens when homeowners get what they want....
Fess up, it's yours isn't it.
META is online now
Old 06-22-2019, 09:46 PM   #13
Rewards Points: 864
I’m betting HO is playing GC so there’s no one to step in to bitch slap some sense into them. I like complex roofs but that is a mess.
Old 06-23-2019, 05:30 AM   #14
META's Avatar
There's a builder involved.
META is online now
Old 06-23-2019, 09:57 AM   #15
rjconstructs's Avatar
Trade: Residential remodel
Rewards Points: 268
That is a peculiar layout. I'm not sure about it. I'd like to see some finished pictures when you are done.
rjconstructs is offline
The Following 2 Users Say Thank You to rjconstructs For This Useful Post:
META (06-23-2019), Rio (06-23-2019)
Old 06-23-2019, 02:42 PM   #16
Texas Wax's Avatar
Interesting design, I'd frame it in a heart beat.
The one thing that stands out, which would drive me to model this...
Left elevation, the one roof line is taller stands above the rest, and it's not shown in any of the other elevations. Red flag if you stick frame, that something might not jive.
Old 06-23-2019, 06:23 PM   #17
META's Avatar
I noticed that as well.
I talked with the draftsman this afternoon and he said this is the second design the client/builder are on. This particular print is a modification of a stock print from a catalogue or list.
META is online now
Old 06-23-2019, 07:11 PM   #18
Texas Wax's Avatar
Strangely makes me feel good, nothings changed much in a couple decades
Might want to check out and put a little time into sketchup, if you haven't. Free for personal use version. Just to have a 3D option available on the fly for visualizing cut up messes like that one. And checking funky rafter cuts/truss layouts.
META (06-23-2019)
Old 07-02-2019, 01:43 PM   #19
META's Avatar
Here she is.
META is online now
