Would This Be Stupid? - Insulation - Contractor Talk
Old 07-08-2018, 12:51 PM   #1
BugmanBCE's Avatar
Trade: Pest Control
Rewards Points: 535
I live south of Houston where it is oppressively humid. I plan on insulating my garage and putting in a portable air conditioner. I have considered just throwing some batts in the attic, but the better stuff would cost close to the same price as having someone come blow some insulation in. However, I saw this product https://www.homedepot.com/p/UltraTou...6482/202710055 and thought I could save some money. It has no vapor barrier and I really don't know how much that matters, except that is how you do it properly. Even if I did 2 layers to get to R-13, it would still be pretty cheap.
So, what could go wrong?
I also plan on doing the doors and maybe having someone blow in some insulation in the walls. So, if any of you guys in my area do this kind of stuff, shoot me a pm.
I am not against spending money to do it right, just prefer saving money whenever possible. If that stuff would work out, it seems like it would be the cheapest way to go.
Pest Control League City, TX
BugmanBCE is offline
Old 07-08-2018, 12:57 PM   #2
BarryP's Avatar
Trade: Insulation
Rewards Points: 1,128
Re: Would This Be Stupid?
R-13 is less about than half of what you need. When you condition that space, you will create too much condensation.
It would be far better to not insulate at all and make sure you have excellent ventilation.
BarryP is offline
Old 07-08-2018, 01:14 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,773
If there's a vapor barrier on the conditioned side..why would condensation be a problem? That's how I would do it.
MarkJames is online now
Old 07-08-2018, 01:29 PM   #4
hdavis's Avatar
Rewards Points: 1,556
Hot and humid, so the vapor retarder goes on the outside of the envelope.
As usual, air seal before you even think about insulating.
hdavis is offline
BarryP (07-08-2018), overanalyze (07-08-2018)
Old 07-08-2018, 01:39 PM   #5
BarryP's Avatar
Trade: Insulation
Denim insulation has no vapor barrier. R-30 is what is recommended for his area.
A vapor barrier will just collect condensation if there is not enough insulation to stop the penetration of the humid air.
If you have enough insulation, then a vapor barrier is not required.
BarryP is offline
Old 07-08-2018, 02:25 PM   #6
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
You know if you buy blow in insulation at Home Depot they will let you use their blow in machines for FREE! Just reserve the machine in advance, get a buddy or spouse to feed the machine. Very easy job to do. You can bore holes in the walls between the studs and fill them up too. No need to hire someone to do the job for you.
Not used to living in a humid area, but attic fans displace a lot of heat, and help protect the roofs.
Peter_C is offline
The Following User Says Thank You to Peter_C For This Useful Post:
BarryP (07-08-2018)
Old 07-08-2018, 05:12 PM   #7
MarkJames's Avatar
I live in the swampy summer weather conditions of DC (hot and sticky) and we put the vapor barrier facing the envelope. Houston is kind of the same, only for longer.
How about foam board and cover it, since it's a garage?
Old 07-08-2018, 06:33 PM   #8
BarryP's Avatar
Trade: Insulation
The math is off. If you double that material, you are at $2 a square feet for a mere R13.
Check with https://insulationguru.com
BarryP is offline
Old 07-09-2018, 09:31 AM   #9
BugmanBCE's Avatar
Trade: Pest Control
Rewards Points: 535
OOPS! You're right. I thought it said 48 feet, it's inches. Big difference. So there goes any cost savings with that plan.
I'm not sure I need R-30. I seriously doubt my attic is R-30. Walls are R-13 normally. I know R-30 is recommended, and that's certainly better, I just wouldn't think it is a must.
If I call somebody to do the garage attic I plan on having them do the whole house. Might as well bring it up to specs.
I know this is something I could DIY, but I really don't have the time. Well, I could roll in some batts in the attic above the garage, but that really isn't cheaper than paying someone to blow it. I'm not going to blow insulation myself. Just not going to.
Old 07-09-2018, 09:33 AM   #10
BarryP's Avatar
Trade: Insulation
Then don’t keep that space conditioned all of the time. Just turn on the a/c when you are needing it.
BarryP is offline
Old 07-09-2018, 09:59 AM   #11
BugmanBCE's Avatar
Trade: Pest Control
Rewards Points: 535
Thanks. You've been so helpful. Let me take this a different direction real quick.
My intention is not to turn it into a conditioned living space. I would definitely like it to be much cooler in there. Also, all my stuff rusts and molds and deteriorates like crazy in the garage. I want it drier and cooler, and I know to do that I would prefer to go with a portable air conditioner. But doing that without insulating the doors, walls, and attic is fairly pointless. I probably won't run that a/c at 70°, 80 is more likely, 75 or 78 sometimes. I just need to take the edge off.
Anyway, so considering I am not looking for optimal performance, there seems to be a major price difference between R19 and 30. You think R-13 would lead to condensation, so we can leave that out. Would rolling in some R-19 be sufficient for these goals?
Old 07-09-2018, 10:05 AM   #12
hdavis's Avatar
The HD machines will blow loose, but they won't work for drill and fill. Something like a Force 2 that can be rented will do it.
hdavis is offline
BarryP (07-09-2018), Peter_C (07-09-2018)
Old 07-09-2018, 10:06 AM   #13
BarryP's Avatar
Trade: Insulation
R19 (unfaced) would be my personal minimum. However, even in colder climates, some use R13.
The problem down here (I am in Gulf Shores), is exactly the mold issue.
Ventilation is key. Keep the air moving at all times. Leave everything “cracked” open.
In our RV, we use Damp Rid. That helps, but must be watched.
BarryP is offline
The Following User Says Thank You to BarryP For This Useful Post:
hdavis (07-09-2018)
Old 07-09-2018, 12:05 PM   #14
BugmanBCE's Avatar
Trade: Pest Control
Rewards Points: 535
Well, it looks like blown is the only solution anyway. I got up there and measured and the rafters are 17.75" apart. They don't make batts that size.
The Following User Says Thank You to BugmanBCE For This Useful Post:
BarryP (07-09-2018)
Old 07-09-2018, 12:06 PM   #15
BarryP's Avatar
Trade: Insulation
Then call insulation gurus.
They are experts in your area.
BarryP is offline
Old 07-09-2018, 12:18 PM   #16
hdavis's Avatar
A couple of notes
DC and Houston are way different. Houston's heating season is very short, vapor barriers are set up for AC, not heating. You don't want hot humid air moving through the wall system and condensing on the inside wall surface, so the vapor retarder goes on the outside of the wall system.
As a practical matter, you're stuck with however it was built.
The major source of condensation in retrofits is outside air moving through the walls and ceiling. Air seal penetrations before you start insulating.
If you run a window AC unit, you will remove some of the moisture you're concerned about, but it isn't that straight forward to prevent rusting. If you have temperature swings, your equipment can end up being cold when hot humid air is present, and you'll get condensation. IMO, keeping a dehumidifier running is needed to prevent condensation issues. Alternatively, you can keep the AC running all the time to keep the temp stable.
While you're figuring all that out, consider wiping your tools with Ballistol, or putting a chunk of camphor in your tool box, or similar methods of preventing rust.
hdavis is offline
MarkJames (07-09-2018)
Old 07-09-2018, 01:07 PM   #17
BarryP's Avatar
Trade: Insulation
^^ solid advice
BarryP is offline
hdavis (07-09-2018)
Old 07-09-2018, 05:26 PM   #18
MarkJames's Avatar
Buy yourself lots of new [email protected] that come with silica packs. Re-deploy them in the garage.
Texting while driving - how stupid can some folks be? MarkJames Off Topic (Non Trade) 19 04-13-2013 07:09 AM
Stupid question? Anyone ever mix sodium bicarbonate with recycled glass? MasterBlaster Sandblasting 7 03-23-2013 06:14 PM
crazy stupid timelines. Rich D. Business 21 09-29-2012 07:07 PM
I'm Ignorant, Not stupid Paul Burns Painting & Finish Work 9 03-14-2006 06:08 PM
