When Soft Foam Gets Wet - Insulation - Contractor Talk
Old 07-25-2018, 02:55 PM   #1
META's Avatar
Trade: General and Trades
Rewards Points: 7,104
Recently, we remodeled a home and the owner sprayed 1# open cell soft foam in the walls. We had a roof leak. Two weeks later this was the condition of the foam near the upper portion of the walls.
META is offline
Old 07-25-2018, 03:20 PM   #2
META's Avatar
Re: When Soft Foam Gets Wet
Here are a couple video links of the wet foam.
https://drive.google.com/file/d/0ByH...ew?usp=sharing
https://drive.google.com/open?id=1em...dN0UyfWr5ijrpN
META is offline
Old 07-25-2018, 07:53 PM   #3
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,895
Was the leak your fault? If so, what do you plan to do?
rescraft is offline
Old 07-25-2018, 09:46 PM   #4
META's Avatar
It is a joint effort with the owner. We pulled out all the foam and redid the drywall and trim in the affected areas.
One of the points of the thread is to bring attention to how soft foam absorbs and holds water. If it gets wet, it will not dry out on it's own and must be removed. 2 weeks is a significant amount of time for that water to be sitting there....no way it would dry out before mold set in or wood component and drywall damage.
META is offline
Old 07-26-2018, 08:33 PM   #5
TimNJ's Avatar
Rewards Points: 6,838
That's like having a sponge in the wall.
TimNJ is offline
The Following User Says Thank You to TimNJ For This Useful Post:
META (07-26-2018)
Spray Foam not adhering to concrete basement wall... Paint & Hammer General Discussion 6 11-04-2012 01:39 PM
progressive foam vs foam clad siding contractorjay Windows, Siding and Doors 15 10-25-2012 08:03 AM
foam insulation question phnola Construction 3 05-01-2011 09:56 AM
the great debate, foam rain screen woodworkbykirk Windows, Siding and Doors 8 09-13-2010 07:54 PM
Spray foam under a slab for insulation -- Mike Finley Construction 22 01-10-2010 02:39 PM
