Tyveck For Vapor Barrier? - Insulation - Contractor Talk
Old 02-20-2010, 07:55 PM   #1
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Rewards Points: 1,014
Our building inspector told me that its much better to use tyveck than plastic for a vapor barrier when using uncrafted insulation.
Any thoughts?
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 02-20-2010, 08:13 PM   #2
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Re: Tyveck For Vapor Barrier?
Tyvek is different that Typar. Tyvek allows air to pass through in both directions. It is not a vapour barrier. I've never heard of it being used inside a home.
It is intended for exterior as a wind barrier.
I'm not familiar with the insulation you stated. If it is figergass, then we use an appoved 6 mill poly VB
katoman is offline
Old 02-20-2010, 09:26 PM   #3
Best looking Carpenter
forsmant's Avatar
Trade: General Contracting, Remodeling
Rewards Points: 133
Tyvek has a 58 perm rating and 6 mil poly has a .06 perm rating. In order to have a vapor barrier the perm rating needs to be below 1.
forsmant is offline
The Following User Says Thank You to forsmant For This Useful Post:
Tom Struble (02-21-2010)
Old 02-20-2010, 10:11 PM   #4
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,607
Looks like your BI needs to read up on Tyvek a bit.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 02-20-2010, 10:16 PM   #5
Plumber / Carpenter
Bill's Avatar
Thanks. I thought it to be strange.
Bill is offline
Old 02-21-2010, 08:17 AM   #6
buddy110's Avatar
Trade: Exteriors as a whole
Rewards Points: 530
It's interesting. I'm having a few conversations with some pro's about perms, dense foam and tyvek. It seems the majority of pros, when using a foam AND tyvek, like to install foam first then tyvek afterwards. Dense foam has a perm rating of .01, Tyvek 58. Installing dense foam against the sheathing would therefore block vapor from escaping the house, trapping that moisture against the sheathing.
Now someone just told me tyvek will perm in both directions?? I was under the assumption it was a one way ticket. Can anyone comment?
buddy110 is offline
Old 02-21-2010, 08:27 AM   #7
Plumber / Carpenter
Bill's Avatar
Maybe I need to re state my post.
The building inspector said when installing uncrafted insulation it is best to use tyveck INSIDE the house as a vapor barrier instead of plastic or paper between the drywall and insulation.
Bill is offline
Old 02-21-2010, 08:31 AM   #8
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
in a properly assembled wall,where is this ''vapor'' coming from?
What use is tyveks fairly high permiability if you cover it with
a lower perm matierial?
Tom Struble is offline
Old 02-21-2010, 08:35 AM   #9
buddy110's Avatar
Rewards Points: 530
So by that theory why put dense foam at all?? (which has always been my feeling anyway) Putting it on top of tyvek virtually nullify's it's effect.
buddy110 is offline
Old 02-21-2010, 09:11 AM   #10
Trade: siding
Rewards Points: 20
i don't know
Old 02-21-2010, 10:04 AM   #11
Trade: siding
Rewards Points: 20
the problem i have with foam is that when you cut it around windows and put it over step flashing's is that you are screwing up the drainage plane
you should consider the foam installed this way a solid siding so installing the foam on a rain screen would probably be best for moisture control,not sure exactly what that does to its insulation qualities tho
best way to do it IMO is to install the foam first,pack out the openings the foam thickness,install roof step flashing on top of the foam,this way the drainage plane is directly under the siding where it should be,not 2 inches under
doing it this way you could probably just tape the seams/flashing's and forget the tyvek,i think i would still use i tho
Old 02-21-2010, 10:12 AM   #12
forsmant's Avatar
Rewards Points: 133
I don't think permeability is ever going to be a one way phenomenon.
forsmant is offline
Old 02-21-2010, 10:20 AM   #13
buddy110's Avatar
Rewards Points: 530
Ya, I'm beginning to see the logic behind this, especially knowingf the tyvek will perm back into the home.
To be honest, I think I'm going to resort to a permeable foam. It's just better all around.
buddy110 is offline
Old 02-21-2010, 11:15 AM   #14
Trade: siding
Rewards Points: 20
i think i agree and it would be nice if the back of the foam was sculpted to encourage drainage
to be honest i look at the tyvek that i install pretty much as a bulk water barrier,i detail it as much as i reasonably can but by the time I'm there the roofs and ledgers make getting an installation like is in the manual....well
to do that effectively is to build the walls on deck, then tyvek them, then
this way it would be everywhere it has to be
i think the main reason guys wanna do the tyvek first is that its easier to staple it on than having to use 2'' or whatever nails
Old 02-21-2010, 11:46 AM   #15
Don
rotarex's Avatar
Trade: Renovator/ Builder
Rewards Points: 508
after i read the construction book, i wonder why we dont use tyveck also, but it wont meet code as vapor barrier in theory is suppose to work, for me it looks like it would build mold from all the water build up
Custom Decks
Custom aquarium all salt water
Renovation
next on my list............planting trees for all those material i used
rotarex is offline
Old 02-21-2010, 12:17 PM   #16
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Rewards Points: 1,772
Exactly, and I agree with you on the foam first then tyvek, if required, and the build out of flashings and windows.
Vapor barrier and it's placement depends on your climate and where the moisture is (inside or outside).
I have not totally figured this out yet, but getting close.
MJW is offline
Old 02-21-2010, 12:18 PM   #17
MJW's Avatar
Another thing to consider is the perm rating of the OSB, plywood, buildrite that is used. I'm not sure if I agree with totally sealing walls like we do up here in the north.
MJW is offline
Old 02-21-2010, 12:37 PM   #18
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
I agree. OSB and CDX both have low permeability. However, with a proper vapor barrier on the inside (warm in winter), most of the moisture would be occuring from the outside, whether by improper flashing details or moisture being driven through the WRB in the wrong direction. With a non permeable foam, any moisture that accumulates behind it wil be trapped and wreak havok. I still prefer the variable permeability of #30 felt over plastic wraps of any kind.
loneframer is offline
Old 02-21-2010, 12:42 PM   #19
Trade: siding
Rewards Points: 20
yea but i thought you didn't like to combine the two?And if ya think about it Lone maybe 2 layers of felt is a good idea under any siding not just stucco for the same ''wrinkly'' effect
Old 02-21-2010, 12:42 PM   #20
Rory Read
Rory Read's Avatar
Trade: Basements, Excavation, Waterproofing and Finishing
Rewards Points: 25
No matter where you live, you want the wall to breathe in at least one direction or the other. You have to figure what makes sense for your climate. After you decide that, then you decide where vapor barriers and retarders go and what your ideal wall construction looks like.
Try the DOE for regional guidance:
http://www1.eere.energy.gov/building...lications.html
Rory Read is offline
