Is There A Way To Check For Moisture? - Insulation - Contractor Talk
Old 07-06-2020, 08:33 PM   #1
nickelec's Avatar
Trade: professional licensed electrician
Rewards Points: 536
Hi all so I built finished my house about 6 months ago and been living here for maybe 4 months. While building u asked alot of questions here about spray foam thermal bridging etc. So is there a way to actually check for moisture issues to make sure we did it right
My set up is as follows
old true dimension 2x4 framed exterior walls filled with closed cell phone roughly 3.75
Basement foundation walls coated with 3 inches of closed cell ontop of foundation
On the exterior I have 1/2 foam and housewrap the siding guys put up
And the roof rafters filled about 7-8 inches of open cell does anyone see a problem with moisture mold etc and how can I tell?
Sent from my SM-G986U using Tapatalk
nickelec is online now
Old 07-06-2020, 08:44 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,704
Re: Is There A Way To Check For Moisture?
Get a moisture meter...
You could also do a variation of the old visqueen test...
Tape a 12" sq of visqueen on what ever surface you have and see what happens...
griz is online now
Old 07-06-2020, 09:25 PM   #3
nickelec's Avatar
Rewards Points: 536
I'm assuming outside the house?
Old 07-06-2020, 10:23 PM   #4
Fire up the BBQ
griz's Avatar
where outside the house?
are you talking about ground water?
griz is online now
Old 07-06-2020, 10:23 PM   #5
nickelec's Avatar
Rewards Points: 536
I was referring to the thermal brake
Old 07-06-2020, 10:24 PM   #6
nickelec's Avatar
Rewards Points: 536
Thermal break
Old 07-06-2020, 10:25 PM   #7
Fire up the BBQ
griz's Avatar
i still don't get what you are trying to do.
griz is online now
Old 07-06-2020, 10:29 PM   #8
nickelec's Avatar
Rewards Points: 536
From my understanding and correct me if I'm wrong, but from the reading I have done I understand that if there's not enough insulation or a significant thermal break between inside and outside , the cold air in the summer escaping the building to the outside hot air could cause condensation build up . Against the sheeting
Old 07-07-2020, 05:56 AM   #9
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 202
You have that backwards - hot moist air condensing against cold walls on the inside
During wintertime it is reversed to what you said
Best test is blower door with infrared - no air leaks no air flow for condensation issues
With Open cell in attic - good chance of issues (don't care which climate zone), just put a humidity meter up there which tracks it. Expect spikes during mid day - how bad can clue you in to if you need to worry or watch
Only other issue can be moisture sandwich - two layers of foam on sheathing. Siding guys did it right, generally no problems. Reverse laps, etc... you can have big issues but hey that applies to all jobs (with or without exterior foam) & no real test for that. Might get lucky with infrared but...
SLSTech is offline
Old 07-08-2020, 03:12 PM   #10
SPG's Avatar
Trade: Don't take trades, cash only.
Rewards Points: 1,304
This sounds like a GBA forum question... www.greenbuildingadvisor.com There's a lot of building science guys who love to get into exactly this kind of question over there.
SPG is offline
