Stone Foundation...insulation Options - Insulation - Contractor Talk
Old 02-16-2011, 03:47 PM   #1
Jambruins's Avatar
Trade: Professional Engineer
Rewards Points: 83
I am wondering what is the best way to insulate my basement. My basement is about 5 feet high with a stone foundation. The stone foundation extends about 18" above grade. Whenever the snow melts or it rains I get water in the basement.
Would I be better off putting insulation between the floor joists or using a spray foam insulation on the stone foundation.
If I use a spray foam insulation will I have problems with the water that comes into the basement?
Thanks.
Moser Engineering
www.jmoserengineering.com
Jambruins is offline
Old 02-16-2011, 04:09 PM   #2
G Teoli
Teoli's Avatar
Rewards Points: 150
Re: Stone Foundation...insulation Options
Sprayfoam is the way. But add a drain tile to have the water trickle down between the Closed cell to the edge of the foundation wrap. Sump takes it away.
Teoli is offline
ridgid insulation under new siding PeterQBrown Remodeling 18 12-21-2010 08:45 PM
I thought it was this Stone Foundation CJKarl Masonry 1 10-07-2010 09:00 PM
Stone Foundation Question mikeleasara Masonry 10 10-06-2010 10:21 PM
insulation options trimdoctor Insulation 9 07-31-2010 01:06 PM
framing floor joist for stack stone on perimeter foundation dvd Framing 7 09-20-2009 11:19 PM
