Sprayed Air Barrier. - Insulation - Contractor Talk
Old 07-01-2015, 12:24 AM   #1
2peterhunter's Avatar
Trade: Painting/waterproofing/roof coatings.
Rewards Points: 40
Have any of you guys been around or are you familiar with these products?
2peterhunter is offline
Old 07-01-2015, 06:40 AM   #2
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 184
Re: Sprayed Air Barrier.
Interior or exterior?
Interior is either closed cell foam at a minimum of 1.5 inch while open cell must be 4" thick - if water or moisture is a concern you need to use closed cell
Exterior I can't say I have had the pleasure yet but the results are really good plus they do a good job of eliminating flashing / lapping mistakes commonly seen
Radiant coatings do not count unless tested & to my knowledge none have
SLSTech is offline
Old 07-01-2015, 06:53 AM   #3
Hiber's Avatar
Rewards Points: 60
Only one I've seen is sprayed over open cell after the have trimmed it.
Hiber is offline
Old 07-01-2015, 09:27 AM   #4
Rewards Points: 40
Interior I think would be called fireproofing, the exterior is the air barrier.
crawlspace insulating and vapor barrier questions calipos12 Insulation 20 11-08-2014 12:54 PM
Vapor Barrier for Finishing Old Attic nycphotography Insulation 19 08-28-2012 09:25 PM
vapor barrier and laminate with pad attached bluebird5 Flooring 9 07-14-2012 07:28 PM
Foil "insulation"? Tinstaafl Insulation 22 03-07-2011 11:01 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
