Spray Foam Advice Needed - Insulation - Contractor Talk
Old 01-11-2014, 06:34 PM   #1
Patsfanindallas's Avatar
Trade: General contractor
Rewards Points: 522
So I'm looking to spray the crawl space on my pier and beam house. One foam guy is telling me I should only do closed cell because of moisture and mold. The other guy, who just sprayed my brother in laws doctor office which was new construction, and had 9 inches of open cell sprayed in the crawl space says there is no problem with that.
Being that closed cell is alot more expensive, I was wondering if anyone had some advise on the matter.
Patsfanindallas is offline
Old 01-11-2014, 06:36 PM   #2
Rewards Points: 522
Re: Spray Foam Advice Needed
North Texas is the climate, if that makes a difference.
Old 01-11-2014, 07:42 PM   #3
duburban's Avatar
Trade: building
Rewards Points: 1,774
Interesting topic. I've read a lot about this subject regarding underslab insulation for slab on grade type homes. The answer in that situation is that either works given the right PSI ratings. In your situation your really just trying to achieve a certain R value, so if you can get there quicker with less closed cell, then you've got to run the numbers.
I haven't heard of mold issues specifically relating to either type of foam unless there is a building envelope issue already present.
ps. Look into moisture permeability ratings of each. It seems like if you can moisture proof with closed cell at the same time you'll be ahead of the game.
duburban is offline
Old 01-11-2014, 10:56 PM   #4
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 156
If moisture maybe an issue - closed cell it is
Crawl spaces are basically always a given for Closed Cell
SLSTech is offline
Old 01-11-2014, 10:59 PM   #5
Rewards Points: 522
Originally Posted by SLSTech
If moisture maybe an issue - closed cell it is Crawl spaces are basically always a given for Closed Cell
I've always agreed with that until this insulation contractor, who has a very reputable company in Dallas told me otherwise. That's why I was asking.
Old 01-11-2014, 11:12 PM   #6
painter213's Avatar
Trade: Coatings consultant and Inspector
Rewards Points: 1,334
Since he is in Dallas then, who's material does he use then? There is two large foam suppliers in Dallas and truth be told, I would only trust one of them. There is a lot of people out there that will say anything to take your money and then there gone. I would go with the closed cell foam in a crawl space for sure. You get better air sealing and R value with less thickness.
NACE Certified Coatings Inspector Level III #7953
SSPC Protective Coatings Specialist #2014-529-139
[email protected]
205-717-0292
painter213 is offline
Old 01-11-2014, 11:12 PM   #7
Sean
SLSTech's Avatar
Rewards Points: 156
Unless he is guaranteeing no water will ever touch or come in contact with it... Open cell is essentially a sponge that not only will help trap it but also allows it spread out
SLSTech is offline
Old 01-13-2014, 03:10 PM   #8
ASInsulation's Avatar
Trade: Insulation and Weatherization
Rewards Points: 220
I would never recommend open cell in a crawlspace. I am not a big fan of the open cell product in any circumstances, but it does serve its purpose and that is not one of them.
ASInsulation is offline
Old 01-13-2014, 05:03 PM   #9
Rewards Points: 522
Exactly what I thought. I can't figure out why he's recommending that. He was saying how the closed cell is the same as open cell except for the skin barrier on the exterior of it.
Old 01-13-2014, 07:59 PM   #10
painter213's Avatar
Well that shows he doesn't know squat about foam then. Did he mention who's foam he installs?
[email protected]
205-717-0292
Old 01-13-2014, 08:42 PM   #11
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 204
I wonder if a scheme of using fiberglass in the bays and say 2" rigid foam attached to the underside of the floor joists would work really well for your situation.
The foam should be radiant barrier type.
Andy.
ScipioAfricanus is offline
Old 01-13-2014, 09:21 PM   #12
Rewards Points: 522
He didn't say, and since I'm not using him, I'm not asking.
Old 01-13-2014, 09:37 PM   #13
painter213's Avatar
Since your in Dallas, you have one of best spray foam manufacture in the world right there in Rowlett. www.specialty-products.com
Give them a call and talk to Scott James. He can get you in touch with some qualified locals.
[email protected]
205-717-0292
Old 01-14-2014, 08:30 AM   #14
Rewards Points: 522
Thx bud
The Following User Says Thank You to Patsfanindallas For This Useful Post:
painter213 (01-14-2014)
Old 01-31-2014, 10:22 AM   #15
Montanafoam's Avatar
Trade: Insulating contractor
I agree with the above posters. Closed cell is definitely a better choice for crawl spaces. Generally we are only using open cell in new construction applications when we have a 2x6 wall system. Open cell offers lowers cost per inch but one has to apply a lot more of it to achieve the what closed cell does. Open cell can retain some moisture which could be a concern in a crawlspace. Check us out at www.montanafoam.com
Montanafoam is offline
Old 01-31-2014, 11:44 AM   #16
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
I know for a fact that most spray foam contractors will try to push what ever product they are trying to get rid of . There is a shelf life with this product and they don't want to eat it .
Eaglei is offline
Corrugated Nail Gun Advice Needed openhearth Tools & Equipment 8 04-17-2013 07:43 PM
Spray foam jhammer7 General Discussion 1 04-19-2012 12:23 PM
Spray foam questions DuFast Insulation 4 02-04-2012 02:49 PM
Spray foam under a slab for insulation -- Mike Finley Construction 22 01-10-2010 02:39 PM
