Soy Based Spray Foam - Insulation - Contractor Talk
Old 05-17-2010, 08:35 PM   #1
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
Just had my architect (leed certified) ask me if I could use Soy based spray foam in this next project we have coming up. It involves a 3 story porch on the back of the house and on the third floor, we'll be expanding out a new bathroom and the shower will actually be framed out on the new porch, but closed in. I'm worried about it being cold, so I want to use normal closed cell. she is wanting to lean towards greener ways of doing it. I looked into it but found that it looks like the soy based is not R-7 per inch.
How many of you guys are installing soy based and how much more is it to buy than petroleum based foam. roughly, not looking for exact prices. I'm sure it's gotta be a considerable amount more
This job is small, so I'm not sure i will be able to even get anyone to come out and spray around a big shower stall extension this house, when nothing else is getting done there for insulation.
thanks
ApgarNJ is offline
Old 05-17-2010, 08:50 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Soy Based Spray Foam
Just throwing an idea out; why not cellulose?
It's LEED certified, an effective insulation, mold resistant, pest resistant and cheaper than foam. It allows the exterior wall to breathe when using a vapor barrier on the inside of the wall.
When insulating a complete bathroom gut, that's what I use on tub surrounds/showers that have an exterior wall.
Angus
angus242 is offline
The Following 2 Users Say Thank You to angus242 For This Useful Post:
ApgarNJ (05-18-2010), Joasis (08-02-2010)
Old 05-17-2010, 09:21 PM   #3
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 144
Demilic - maybe a few cents more if memory serves me correctly
I wouldn't hold to much stock in CC being an r7 - maybe when installed but it drops down to a 6.X after a while & then holds steady at that number
You could always look into buying a pack, so you could self install it, but I would stick with a pro if they are not to busy (about the same cost)
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
Old 06-17-2010, 10:18 PM   #4
spraytekfoam's Avatar
Trade: spray foam insulation
i spray demilec products and the soybased cc foam is the same price as petroleum based r6.8 per inch
spraytekfoam is offline
The Following User Says Thank You to spraytekfoam For This Useful Post:
ApgarNJ (06-18-2010)
Old 06-26-2010, 06:17 PM   #5
Dr Warm's Avatar
Trade: foam insulation energy audits
I have sprayed Bio Base. It shrinks like crazy. It has an odor. All polyurethanes comes in two drums, isocyanate and polyol. ALL polurethane foams, including "soy" foams are 50% isocyanate, which is petroleum based. The polyol side has the soy, which replaces SOME of the petroleum, along with other chemicals such as catalysts, surfactants and fire retardants. The soy people cannot replace all of the petroleum in the polyol side because it doesn't work. Why would you want a product that is compromised for the sake of a marketing gimmick? The FTC is coming down on these companies for making false claims. The soy component is 5 to 10 % of the product. The manufacturers won't tell you because they know they are lying when they say it is soy based. If LEED gives more points for soy foam than other foams, shame on LEED.
What about the embodied energy of tractors driving around, the use of fossil fuel based fertilzers and pesticides to grow the soy, the drastic loss of topsoil that is agriculture (read "Dirt", a great book).
I think foam is great as the amount of fuel saved vastly justfies using petroleum to make it.
There are a number of good foams. I spray Lapolla as it sprays great and has low odor.
Dr Warm is offline
The Following 3 Users Say Thank You to Dr Warm For This Useful Post:
ApgarNJ (06-26-2010), aptpupil (08-04-2010), MALCO.New.York (08-04-2010)
Old 06-26-2010, 06:22 PM   #6
Dr Warm's Avatar
Buy a 200 or 600 BF kit such as Froth Pak. It isn't worth a spray foam contractor's time to spray such a small job, but it is worth having a well insulated shower for comfort.
Dr Warm is offline
Old 08-02-2010, 09:26 PM   #7
boehsconst2's Avatar
Rewards Points: 12
Smile
Find a DemilecUSA authorized contractor and use Heatlock Soy 200, its the best CC foam I've sprayed (out of 4 brands) The last I heard the R-value is at 7.2 but they didn't have the tests back from independent labs yet.
Just go to demilecusa.com and there's a authorized contractor link there. Hope this helps
boehsconst2 is offline
Old 08-04-2010, 08:42 AM   #8
buildingscience's Avatar
Trade: Roofing, Weatherization, Insulation
Have sprayed foam for almost 10 years - have sprayed all the soy based products on the market that I'm aware of - some spray great, others are terrible. Bottom line is that the soy polyol is inconsistent and therefore soy foam is inconsistent.
Also - Dr. Warm is right - there is only a couple % of soy polyol in a set of soy foam so don't be fooled. We have sprayed Icynene's MDR (medium density renewable) product which has recycled plastic pop bottles in it and it sprays great - has an R5.2 per inch. Its pricy, but its the best I've sprayed.
If you're going for LEED points - then Icynene is your "golden ticket". They've made more progress w/ LEED than any other foam mfg. that I know of. Their website is plastered with LEED stuff and they have a great resources page that has a LEED spec that will show you exactly how their products will get you LEED points.
buildingscience is offline
Old 08-04-2010, 07:02 PM   #9
Sean
SLSTech's Avatar
Rewards Points: 144
Dr Warm - The numbers you want - on average 65% of part B is the "propellant" and up to 25% of that can be replaced at max per industry rep at the Bldng Science Camp - now exactly how much certain companies do, well....
bldgscnc - all foams can lead to inconsistent results, proper care & installation count for all of them, and yes that applies to soy formulas as well - trying to say they are all bad is the same as saying all contractors are crooks...
You really do not want to get me started on Icenyne & their BS marketing - so quite simply, all major foam suppliers can get you the same LEED points
SLSTech is offline
Old 08-05-2010, 08:36 AM   #10
You really do not want to get me started on Icenyne & their BS marketing - so quite simply, all major foam suppliers can get you the same LEED points[/quote]
SLStech - wasn't saying they are all bad - was saying soy polyol is inconsistent. That is why soy "based" foams can only contain a very small amount of the polyol. Not all soy is processed down to food-grade consistency like sugar or vegetable oil.
Half the land in our state is in soy beans so this is something I'm familiar with. Soil type, soy bean variety, chemicals applied to the plant during growing season, and the Q.C. standards of the processing plant itself will create a pretty wide range of different grades of soy polyols.
Soy foams are among the most inconsistent bio-foams out there and the most inconsistent ones are those that utilize the highest percentages of the soy polyol.
The more soy, the more finicky the foam is to spray. I've had one set spray great, and the next fall out of the wall. Same brand of foam, sprayed with the same equipment, same ambient temp & humidity, same equipment temps & pressures, same resin agitation rate & time, same job, same wall, same sprayer with 8 years spraying experience. I've had reasonably good luck spraying the Demilec Heatlok product. Had some minor adhesion problems and pull away, but nothing major. Touch'd it up prior to leaving the job and customer was happy.
Many foam mfgs (including Icynene) have opted to utilize other - more stable/consistent - bio-sources for their renewable foams like castor oil, sugar/sucrose, and recycled materials so that their products spray out and yield more consistently. I've sprayed Icynene MDR 2.0lb foam to a metal wall with an 1/8" of frost on it and it burned off the water and after it cured I almost couldn't pull it off the metal it adhered so well. When I did get it off I found zero voids.
Why do you say that Icynene's marketing is BS? I've found it to be very helpful as a contractor trying to get LEED commercial work. They've taken the initiative to make it easier for the contractor - like myself - to walk in the door of a GC or institution and plop down a doc that talks about LEED and how their product fits into that system.
Icynene also the product I see spec'd most frequently by architects who specify foam and I believe that is because they've been doing lunch-n-learns for the past 15+ years. Very few other foam companies have taken that kind of initiative.
They're promoting their product and in so doing they are pushing spray foam into the "main stream" promoting the concept of air-sealing/insulating a building envelope with spray foam which helps all foam mfgs. and contractors.
Don't hate.
closed cell spray foam wayne3434 Insulation 9 10-28-2010 08:50 PM
Can closed cell spray foam be used as a water proof vapor barrier in a shower? Mike Finley Construction 16 10-09-2009 04:14 PM
Does Behr Ext. Satin spray easily? renet Painting & Finish Work 2 11-17-2008 10:31 AM
opinions on spray foam insulation anyone sprayfoambob General Discussion 20 04-05-2008 10:06 PM
Spray foam conctractor in MI needed doubleaction Help Wanted or Looking For Work 1 03-09-2008 12:46 AM
