Repair Garage Insulation - Insulation - Contractor Talk
Old 09-06-2018, 01:46 PM   #1
KosmoB's Avatar
Trade: Interior Renovation
Hi All,
I have never had to repair spray foam insulation and I would appreciate your help with the following:
A customer of mine had a water leak in a bathroom above their attached garage. They had the leak fixed and asked me to repair the damage on the garage ceiling (3-4" wide, 3' long).
When I opened the drywall, I saw that there is spray foam insulation on the ceiling. The damage (discoloration, the insulation is intact) on the insulation is small (3" by 2"), and I would like to ask you what would be the best option to repair it. [Edit] Since this is above a garage, I also want to repair it properly, so exhaust gases would not leak into the house.
Thank you!
KosmoB is offline
Old 09-06-2018, 02:03 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,261
Re: Repair Garage Insulation
I would leave it open for a week or so, let it dry out, then close it up. Hit it with kilz oil, if you wish.
MarkJames is offline
Old 09-06-2018, 04:03 PM   #3
KosmoB's Avatar
Thank you Mark!
Just to make sure I understand you correctly:
I shouldn't touch it at all and after it dries well, spray it with Kilz oil to seal it and then just close the drywall, right?
Would this be enough to prevent the exhaust gases from entering the house? Will spray can foam provide better seal or not? If yes, what should I use? (Sorry, never worked with foams!)
KosmoB is offline
Old 09-06-2018, 04:53 PM   #4
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 118
The drywall is pretty much the barrier to living space above. Install the drywall, mud it, finish it and paint it. Done.
Andy.
ScipioAfricanus is offline
Old 09-06-2018, 11:03 PM   #5
Mordekyle's Avatar
Rewards Points: 5,290
5/8
Mordekyle is offline
Old 09-07-2018, 08:10 AM   #6
KosmoB's Avatar
Thank you ScipioAfricanus and Mordekyle!
KosmoB is offline
Plenum Insulation Fire Rating ASMCHICO HVAC 3 06-22-2012 09:01 PM
Garage Insulation Installers treys New Member Introductions 2 02-14-2011 07:44 PM
Would You Install Insulation in the Garage? Hages Construction 7 01-29-2007 12:36 AM
