Questions - Insulation - Contractor Talk
Questions
Old 05-18-2010, 07:28 PM   #1
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Questions
PS. IT WILL NOT ALWAYS BE HEATED IN THE WINTER
I am going to build a small workshop and i plan to insulate using roxul or JM insulation w 6 mil vapor barrier.
In the floor i plan to use 1" foam and i wondering if i need to vent the floor joist cavity if i did so?
Also in the walls i will be using typar or tar paper over the studs behind the sheathing/siding and i wondering if i would have any moisture problems or if it is fine. I was told by one fellow i should not put vapor barrier.
FramingPro is offline
Old 05-22-2010, 01:15 PM   #2
Taylor8's Avatar
Trade: Insulation
Rewards Points: 75
Re: Questions
Your on the right track with using JM insulation in the walls, and putting up 6mm poly. I wouldn't suggest using Roxul, for a small workshop there wouldn't be many benefits.
I'm a little on confused as to why your putting 1 inch foam in your floor. You could insulate the floor with batts, and get a higher R-value with a lower material cost.
Taylor8 is offline
Old 05-22-2010, 07:47 PM   #3
Forming and Framing
FramingPro's Avatar
Re: Questions
I might but would i put vapor barrier?
Old 05-22-2010, 07:59 PM   #4
Taylor8's Avatar
Trade: Insulation
Rewards Points: 75
Re: Questions
Yes, you should use a vapor barrier.
Taylor8 is offline
Pricing questions Brian Painting & Finish Work 11 08-18-2012 06:34 PM
Painting business start-up questions oneelwayfan_com Painting & Finish Work 56 02-02-2010 01:55 AM
Posting Rules Update: How-To Questions Nathan General Discussion 1 09-21-2009 02:33 PM
Questions for Operators Lar Excavation & Site Work 2 02-10-2009 01:11 PM
Direct mail questions answered dave3717 Marketing & Sales 9 11-20-2008 01:43 PM
