Pole Barn Insulation Questions - Page 2 - Insulation - Contractor Talk
Old 02-04-2018, 12:17 PM   #21
diplomat
Golden view's Avatar
Rewards Points: 1,550
Re: Pole Barn Insulation Questions
Originally Posted by SLSTech View Post
Better just getting a professional sprayer in there to spray closed cell instead of going with froth packs - it actually comes out cheaper with better results & heh they can spray the ceiling in one shot. As for how much depends some on climate zone but minimum 2" including girts, 2x's encapsulated....
I have a good sub for this. I'll get a quote.
Covering the girts with rigid would encapsulate them. Only the poles wouldn't be.
I hear you on the froth packs. I've used them with good results when I use them in a bucket of warm water but a real rig is always better.
Golden view is offline
Old 02-04-2018, 12:32 PM   #22
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,650
Originally Posted by Golden view View Post
Instead of starting a new topic I'll tag onto this one. I making an offer on a property with a pole barn, already built. I would stick frame a shop if I was building from the ground up.
I'm not on so much of a budget. I want to condition the space and not cause condensation issues. Of all the types of projects I've done, pole buildings are not included. They are unfamiliar to me and look like funny buildings with no apparent lateral design and 1/4 the right amount of trusses
I like the idea of ridgid plus spray foam. Maybe instead of cutting between the girts, just lay over. I could also just spray foam the seams. One $700 600 board foot foam kit might do it. 2" Polyisocyanurate (yeah I spelled that without looking it up!) is about $1 a square foot. R13 might be enough, I'll be heating it 20 degrees delta T a few months a year, with an efficient heat pump.
What about the ceiling?
While this paper needs to be considered for the source's potential bias, if there is truth behind it, it's a consideration.
Further, I think extruded polystyrene is around $0.50 per board foot, and iso would be around $0.33. Of course that would depend upon who is buying and where.
A few years ago I did a horse stall ceiling (3 stalls maybe 500 sf) with 2" extruded and the two part SPF (portable, disposable cans you are describing) on the seams and joints. I think it worked out well. The horses were causing a condensation issue that appears to have been remedied.
Using the described method would be quick and easy on walls between posts. I honestly don't recall what I did for the ceiling bays (16"o.c.), but I probably ripped them on the table saw. I probably didn't use even half the foam.
Above all, a good roof
Mr Latone is offline
Old 02-04-2018, 01:05 PM   #23
diplomat
I remember reading that once. I had forgotten the info. Good info though. I've done wall assemblies with iso on the inside of a bunch of fiberglass, based on this report. Seems like XPS would be the way to go for a lightly insulated pole barn.
Old 02-04-2018, 01:05 PM   #24
Donohue Const's Avatar
Rewards Points: 1,722
if you use spray foam, don't spray it directly to the steel on the building.
it will make it look terrible from the outside.
does the building have soffits for attic ventilation?
we take quite a few pole sheds and turn them into shops for people
if you want cheaper, they make large faced batts 8' wide to fit between the poles
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
Old 02-04-2018, 01:13 PM   #25
diplomat
Any issues with condensation with fiberglass? I don't want to spray straight to the metal. I'll do a combination of rigid and spray.
Old 02-04-2018, 01:30 PM   #26
we haven't had any issues as long as you make sure the fiberglass is thick enough to fill the whole wall cavity to the steel
kinda like a steel structure building that gets pinch insulation between the steel panels and walls.
no condensation problems untill the fiberglass sags overtime from the ceiling and leaves small gaps where the fiberglass is no longer in contact with the steel panels
had it happen in the local school gym when we put a new roof on.
I told them we should replace insulation with the steel, because when we "break" the seal between the insulation and steel it will cause an air gap
they said it wasn't in the budget. that winter they had drips in the gym floor. so they called to say the roof was leaking. I can and looked, said no your insulation is bad and it's condensation
they didn't believe me, so they had a engineer come look.
guess what he said, you need new insulation, old stuff is no good.
then the school said they should of listened to me from the start, so an 8k cost turned into closer to 20k to put new batts in from underneath
Ryan
Old 02-04-2018, 01:38 PM   #27
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,278
Originally Posted by Chrisgaliano91 View Post
Hey everyone I'm looking for some tips on how to insulate my new shop. I have an idea but not sure if it's appropriate,so all feedback is welcomed.
I just built a 1000 square ft pole barn I am framing inside with 26 to match poles 2 ft centers. My plan was to then use bat insulation probably r 21..iny question is on the way they built the pole barns is they have 24s laying flat on exterior to attach siding.if I frame and insulate as I mentioned it will leave a 1 1/2" air gap behind the insulation and the metal siding. Is this ok? Will it create moisture behind the walls? Please let me know what you guys think. Ps I have a budget so I'm looking for proper and cost effective solutions..thank you, chris
This plan is fine and will work just fine. I would recommend that before studding the walls you closely inspect the bottom of the metal panels for places where mice could get in or where you might have significant outside air leakage. Have seen guys go along the base with a can of spray foam and fill all the ribs for this reason.
Fishindude is online now
Old 02-17-2018, 02:28 PM   #28
diplomat
I just learned my neighbor to be owns a spray foam company.
Old 02-18-2018, 05:43 PM   #29
diplomat
Originally Posted by overanalyze View Post
We did a black ceiling with galv walls for this one. It was an old horse barn we converted to a toy barn/art studio for our client.
What did you do above the ceiling?
Old 02-18-2018, 05:53 PM   #30
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,508
Blown cellulose.
overanalyze is offline
Old 02-18-2018, 06:44 PM   #31
diplomat
Blown cellulose.
What spacing are the supports for the metal?
Old 02-18-2018, 06:46 PM   #32
diplomat
I'm also debating just insulating the top of the trusses, I get a lot more ceiling height and could make half the shop have a mezzanine with 8' head room. My trusses are 14' OC. The heat loss is almost identical. It's not about cubic feet, it's about square feet of exposed surfaces. Doing a ceiling though would let me have a vented roof.
Old 02-18-2018, 06:50 PM   #33
Always Learning
Trying to remember but I think those trusses were 4' O.C. Our shop trusses are 8' O.C. with blown cellulose and we don't have any issues.
Golden view (02-19-2018)
Old 02-19-2018, 09:05 PM   #34
Box Builder
Morning Wood's Avatar
Rewards Points: 10,368
I'm not that familiar with pole barns, but whenever I hear fiberglass batts I think major air leakage. Since I'm almost positive pole barns aren't built with air sealing details, I wouldn't even consider fiberglass batts as a stand alone insulation.
Morning Wood is offline
The Following User Says Thank You to Morning Wood For This Useful Post:
overanalyze (02-19-2018)
Old 02-19-2018, 11:39 PM   #35
diplomat
I could 6mil poly, tape the seams and tremco to the framing.
But unless anyone has reason this is a bad idea, I'm just going to put foam board between the girts and then spray foam the whole thing.
Heat/cool with a 3 ton mini split. Easier than running a gas line out there and almost identical energy costs, with added bonus of A/C.
New block construction question(s) TLHWindows Construction 2 01-31-2014 01:42 AM
Insulating pole barn question pinwheel Construction 21 01-18-2013 08:18 AM
Whats it cost to put up a 3000sq ft Pole Barn? CarrPainting General Discussion 18 11-15-2012 08:47 PM
warping barn door fix artinall Windows, Siding and Doors 6 06-09-2012 08:19 AM
stocking service trucks MO-AMPS Electrical 23 11-25-2009 10:39 PM
