Need A Vapor Barrier - Insulation - Contractor Talk
Old 06-12-2011, 08:06 PM   #1
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Rewards Points: 1,014
Got an attic that I was going to use as livable rooms when I started out, so I insulated the ceiling below with fiberglass insulation without any vapor barrier. I done this just to muffle any noise was all between floors. Now money and family needs have altered those plans. I will not be using the attic as livable rooms. Problem is, I know I should have a vapor barrier on the ceiling below but dont, so what can I use as a vapor barrier. can I simply pull the insulation up from between the joists and install say maybe red rosin paper between the joists and then re install the un crafted insulation? Or is there something else, like plastic caulked to the joists?
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 06-12-2011, 08:10 PM   #2
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Need A Vapor Barrier
they have paint on vapor barriers but i think 2 coats of oil based primer should work too
make sure to seal any penetrations like wire holes and the like
red rosin isn't a vapor barrier
Tom Struble is offline
Old 06-12-2011, 08:13 PM   #3
Plumber / Carpenter
Bill's Avatar
Humm, never heard of that. Is that just on the back side of the sheet rock, or do I need to do the joist sides as well?
Bill is offline
Old 06-12-2011, 08:17 PM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
What about just using kraft-faced fiberglass insulation? That's considered a viable barrier in the Chicago area.
Angus
angus242 is offline
Old 06-12-2011, 08:21 PM   #5
Plumber / Carpenter
Bill's Avatar
I could, but then I would have to purchase all new insulation. I already have enough but without vapor barrier. Thought maybe instead of wasting it all just install something for the barrier. If push comes to shove I could remove the uncrafted and install craft faced, then install the uncrafted 90 degrees to the craft faced insulation which would make it tighter. But I was just trying to use what I already had was all.
Bill is offline
Old 06-12-2011, 08:21 PM   #6
Trade: siding
Rewards Points: 20
no bill paint it on the cieling not under the insulation
sw has a latex based one
http://www.sherwin-williams.com/pro/...vapor_barrier/
Old 06-12-2011, 08:24 PM   #7
Plumber / Carpenter
Bill's Avatar
Now that may be the ticket. The ceiling below is already primed and painted, so it makes me wonder if I can re paint using this paint over the old?
Bill is offline
Old 06-12-2011, 08:43 PM   #8
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,261
You should be okay with going over the existing paint. Here are a couple of other threads on the subject:
http://www.contractortalk.com/f94/va...r-paint-49618/
http://www.contractortalk.com/f18/wa...uestion-33616/
Tinstaafl is offline
Old 06-12-2011, 09:08 PM   #9
Plumber / Carpenter
Bill's Avatar
Thanks. Appreciate it much.
Bill is offline
