edward trowelhands
Trade: Diplomat
Rewards Points: 298
Insulation Vac
My house, so as usual I have a stupid question because it's not my usual area of experience:
I want to move about 400sf of L77 50 feet or so from a living room area to insulate a garage, then do some remodel wiring in the attic before re-insulating the living room. That stuff is so light and fluffy, can I just set up a duct fan in some flex duct, or do I need to hire the insulation vacuum guys. Yes I could just wade around but I'm doing enough work this way seems easier.
You make something idiot proof and the world invents a better idiot. |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
![]() ![]() Trade: Insulation
Rewards Points: 1,128
Re: Insulation Vac
I doubt the fan will have enough pull, even for OC fiberglass. If it were even possible, the fiberglass would eat your blades within minutes. If you cannot shovel it with a feed shovel, then consider renting a vacuum at Sun Rentals (if there is one by you).
Advertisement |
The Following User Says Thank You to BarryP For This Useful Post: |
Golden view (08-01-2015)
edward trowelhands
Trade: Diplomat
Rewards Points: 298
Re: Insulation Vac
Thanks,
I think you're right about the power for sure.
Sponsored Links | |||
Advertisement |
edward trowelhands
Trade: Diplomat
Rewards Points: 298
Re: Insulation Vac
$300 day rental. Not much more to hire the guys. maybe this and I bring it up there with me for short suction length? http://www.harborfreight.com/13-gall...tor-31810.html
Re: Insulation Vac
It would cost, minimally, $1.50 a square foot to hire out.
The 1hp dust collector would not have enough cfm. You would, minimally need a 3hp electric hp. The smallest gas vacuums are 6hp. |
edward trowelhands
Trade: Diplomat
Rewards Points: 298
Re: Insulation Vac
Sounds like I need the real machine. I asked the insulation contractor about it once and he would give me a better price because it's new (no debris) and not getting bagged, just moved across the attic.
The Following 2 Users Say Thank You to Golden view For This Useful Post: |
BarryP (08-01-2015),
WindowsonWash (08-01-2015)
I like Green things
Rewards Points: 5,682
Re: Insulation Vac
I just sucked the cellulose out of the walls in my house. Used a 1 1/2hp dust collector.
Saved it for the shop attic. |
The Following 2 Users Say Thank You to WarnerConstInc. For This Useful Post: |
Golden view (08-01-2015),
WindowsonWash (08-02-2015)
windowsonwashington.net
Trade: Exterior Construction
Rewards Points: 1,178
Re: Insulation Vac
The insulation vacs are crazy. I have seen/heard where guys sucked up a framing nail that was in the attic and it would go right through the hose nearer the vacuum and actually stuck in one of the guys.
Advertisement |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
insulation Q | canadianwhite | Construction | 8 | 12-31-2012 11:15 AM |
Removing wet insulation | Tom Richards | Insulation | 8 | 12-16-2012 08:44 PM |
Should you pay more for a quality insulation job? | ecworks | Insulation | 8 | 12-10-2012 10:02 PM |
Radiant Barrier Fact Sheet | Ed the Roofer | Roofing | 0 | 02-09-2008 08:57 PM |
Go to Page... |
