Insulation For Cold Storage - Insulation - Contractor Talk
Old 02-28-2017, 09:13 PM   #1
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 406
I'm bidding on a project to turn a pole building into apple storage, with a cold room in one end, and a conditioned clean room in the other end, with storage in between.
Planning on 2'' of spray foam on walls of storage and clean room, not sure how much foam I should have for the cold room. It will be just refrigerated, not a freezer.
Also planning on blown in cellulose in the ceilings, should I go thicker over the cold room?
Attached is a layout/description of the building.
Thanks in advance. Paul
mrcat is offline
Old 02-28-2017, 09:22 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,004
Re: Insulation For Cold Storage
this is what mechanical engineers do.
at the very least talk with your mechanical contractor.
many variables to consider.
griz is online now
The Following 4 Users Say Thank You to griz For This Useful Post:
Bull Trout (03-01-2017), Calidecks (02-28-2017), mrcat (03-01-2017), Rio (03-02-2017)
Old 03-01-2017, 03:56 AM   #3
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 176
I think you fall under the 2015 IECC which has an entire section devoted to just this subject - as I recall you are at R30 at a minimum
I would also rethink that cellulose directly over it due to potential of condensation issues (assuming it is even allowed)
SLSTech is offline
The Following 3 Users Say Thank You to SLSTech For This Useful Post:
hdavis (03-01-2017), mrcat (03-01-2017), Rio (03-02-2017)
Old 03-01-2017, 09:17 AM   #4
hdavis's Avatar
Rewards Points: 1,290
Don't forget insulating the floor, for much of the year in your location it will be one of the biggest heat sources around.
hdavis is online now
mrcat (03-01-2017), SLSTech (03-02-2017)
Old 03-01-2017, 08:48 PM   #5
mrcat's Avatar
Rewards Points: 406
So after some light reading while I ate breakfast this morning, it looks like R25 is minimum for walk in coolers, and R32 for walk in freezers. Freezers also require R25 under the floor, but I couldn't find any mention of floor insulation for coolers.
We were planning on 2'' of EPS under the whole floor of the building anyway.
I'm getting a quote from a company that will make a panelized cooler in whatever dimensions I need, so will be comparing that vs spraying the whole thing with 4'' of 2lb foam, plus framing and wall covering etc.
mrcat is offline
Old 03-01-2017, 08:49 PM   #6
mrcat's Avatar
Rewards Points: 406
Thanks Griz, once I started researching more on the topic this afternoon, I realized just that
mrcat is offline
The Following User Says Thank You to mrcat For This Useful Post:
griz (03-01-2017)
Old 03-02-2017, 10:36 AM   #7
hdavis's Avatar
At least in Maine, the HVAC has to be designed by an engineer, so start talking with them now, and they can tell you a rough sweet spot for trading off building insulatin cost vs cooling costs and operating cost. Some states also have credits available for energy efficient installations. LED lighting is the standard now for inside coolers - you save the wattage on the lights, and save more wattage on the cooler system.
Last I checked, panelized systems were significantly more expensive than sprayed.
Old 03-02-2017, 12:00 PM   #8
mrcat's Avatar
Rewards Points: 406
Thanks, I just got the quote back for the panelized system. A shizzy over $35,000, and we put it together thats without any refridgeration equip.
Sent from my SM-G900V using Tapatalk
mrcat is offline
hdavis (03-02-2017)
Opinion on adding foam board insulation on the interior over existing drywall. CaptainRon Remodeling 30 01-14-2015 09:44 PM
farm barn with attched storage area kathi General Discussion 1 01-17-2012 08:26 PM
complex sound insulation -duplex on incline desertsound General Discussion 4 12-03-2010 01:04 AM
Insulation Blower? MEL Insulation 7 11-25-2009 12:07 AM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
