Insulating Floors And Moisture - Insulation - Contractor Talk
Old 02-16-2014, 08:47 PM   #1
power's Avatar
Trade: exteriors
Rewards Points: 406
Are floors generally insulated between the upstairs( bedroom) and downstairs family room area. If so, are mousture barriers needed?
What about between the basement and the upstairs?
power is offline
Old 02-16-2014, 08:57 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,448
Re: Insulating Floors And Moisture
Pretty normal to insulate floors on custom jobs.
No moisture barriers used inside.
griz is online now
Old 02-16-2014, 10:27 PM   #3
power's Avatar
Trade: exteriors
Rewards Points: 406
What about when installing hard wood to prevent moisture absorbtion?
power is offline
Old 02-17-2014, 07:53 AM   #4
hdavis's Avatar
Rewards Points: 2,008
The insulation between floors isn't there to be insulation, it's intended to provide some sound deadening so you don't hear loud footsteps above you. It's unfaced - there should be no moisture barrier on it.
Controlling moisture from a basement is a completely different topic and it isn't done with the insulation you're referring to.
hdavis is online now
RichardA (02-17-2014), SLSTech (02-17-2014)
Old 02-17-2014, 08:30 AM   #5
power's Avatar
Trade: exteriors
Rewards Points: 406
If a basement runs the full length of a home, a ranch style home for example, you dont need a moisture barrier in the flooring directly above the basement?
Obviously the basement ceiling is about 8 ft high.
power is offline
Old 02-17-2014, 08:37 AM   #6
hdavis's Avatar
If it has some heat / cooling, no. If you actually have a basement moisture problem, that's dealt with completely separate from your question. Any barrier would be over the floor / walls, and never the ceiling.
Old 02-17-2014, 10:33 AM   #7
power's Avatar
Trade: exteriors
Rewards Points: 406
So if the basement is a concrete slab, the barrier woukd go over the concrete slab?
If concrete walls are framed out with 2 x 4, the barrier goes overbthe insukation or directky over the concrete wall?
power is offline
Old 02-17-2014, 04:38 PM   #8
hdavis's Avatar
The slab should have been poured over a barrier. The outside walls should have had a barrier coating before back fill. If this is true for your situation, then there would be no further moisture barrier put over the basement floor, but if stud walls are built at the basement walls, you would put vapor barrier on the inside of the insulated stud walls. Whether you need a vapor retarder or a vapor barrier depends on your location and other details, so I can't say what's the best for you.
moisture problem when overlaying wood micah72281 Flooring 13 10-11-2010 04:10 PM
Sealing Sub Floors AcademyHardwood Flooring 7 08-21-2009 09:57 PM
moisture trap under water base poly RomZes13 Flooring 5 04-30-2009 03:19 PM
Crawl Space Ventilation Ed the Roofer Roofing 2 11-27-2008 11:15 AM
Refinishing pre-finished v-grove floors Bob H Flooring 3 09-29-2006 07:07 AM
