Insulating Concrete Block Walls With Rigid Foam Board Question - Insulation - Contractor Talk
Old 09-06-2015, 08:44 AM   #1
Mark Z.'s Avatar
Rewards Points: 14
What's the best way to apply rigid foam board to a concrete block wall in a crawl space. Would using concrete nails and caps work or is there a risk in cracking the block?
Mark Z. is offline
Old 09-06-2015, 10:45 AM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,554
Re: Insulating Concrete Block Walls With Rigid Foam Board Question
Tapcons and fender washers. Seal the seems with expanding foam and tape.
overanalyze is offline
WindowsonWash (09-07-2015)
Old 09-06-2015, 11:42 AM   #3
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 342
What's your fastening pattern on a 4x8 sheet Andrew? It seems that it wouldn't need much.
Xtrememtnbiker is offline
Old 09-06-2015, 11:54 AM   #4
Always Learning
I do 6-9 on a 4x8 sheet.
Old 09-06-2015, 12:44 PM   #5
Rewards Points: 342
So no foam or glue behind the sheet, hold it up and sds through the foam and into the masonry? Then run a bead of foam down the edge of the sheet and put the next piece up and repeat?
After all installed you would run foam around the perimeter, and then tape seams?
Old 09-06-2015, 12:48 PM   #6
Always Learning
Yep. Exactly how we do it.
Xtrememtnbiker (09-06-2015)
Old 09-06-2015, 01:00 PM   #7
Mark Z.'s Avatar
Rewards Points: 14
What is sds?
Mark Z. is offline
Old 09-06-2015, 01:23 PM   #8
Always Learning
Originally Posted by Mark Z. View Post
What is sds?
Sds hammer drill.
Old 09-07-2015, 05:19 AM   #9
windowsonwashington.net
WindowsonWash's Avatar
Trade: Exterior Construction
Rewards Points: 1,178
We glue and screw ours.
You can't leave it exposed so something needs to be going overtop of it if its in a conditioned space.
Windows on Washington
WindowsonWash is offline
Old 09-07-2015, 08:39 AM   #10
Mark Z.'s Avatar
Rewards Points: 14
Sds hammer drill.
Thanks for all the feedback so far. First time with a concrete block wall, usually worked in basements with solid poured concrete walls. Just wanted to make sure not to risk damaging the hollow block.
Mark Z. is offline
Faulty Masonry construction at Moore School cdkyle Masonry 6 02-24-2014 12:46 PM
Insulating Walls - what if ???? power Insulation 6 03-08-2013 10:12 AM
Rigid foam airspace question VinylHanger Insulation 5 09-25-2012 07:02 AM
Vapor Barrier with concrete block walls? pzeiler Insulation 0 04-21-2010 11:40 PM
Block Walls DaHammer Masonry 29 03-06-2009 07:11 PM
