Help With Spray On Polyurethane Insulation - Insulation - Contractor Talk
Old 10-31-2013, 12:19 PM   #1
AlProInsulation's Avatar
Trade: Insulation
I got a customer that wants spray on polyurethane insulation, so I looked into it a little bit more. I have researched some on the process and it seem like it might have a hefty price tag to start up with the protection required to spray isocyanates. I am looking for experience/advice on the need for this service and if it is worth the start up cost.
AlProInsulation is offline
Old 11-01-2013, 11:30 AM   #2
ASInsulation's Avatar
Trade: Insulation and Weatherization
Rewards Points: 220
Re: Help With Spray On Polyurethane Insulation
There will be ALOT of trial and error. You MUST have somebody familiar with YOUR equipment as well as spraying to get decent production and profit.
Personally, I stay away from the big projects with foam. If its not something I can do with regular spray kits, I will forward them somewhere else. Your looking at an easy $65,000 start up cost for decent equipment. And in my experience, you are dealing with the same profit range as other products, and the higher ticket is coming from the material cost and labor cost. Alot of prep, clean up, experience, and finesse is required, and if there are issues(such as temperature, mixture, overspraying, shrinkage) the fix can be extremely costly.
I know 2 guys that pretty much went out of business trying to cling to a spray foam division, and another 2 guys that are doing fairly well with it but can take it or leave it. On the other hand, a friend of mine went and spent $140,000 on all new equipment, training, the works, and he is loving it.
ASInsulation is offline
The Following User Says Thank You to ASInsulation For This Useful Post:
Metro M & L (11-01-2013)
Old 11-01-2013, 12:30 PM   #3
Trade: Insulation
This does not sound like something I am ready to get into at this point. My company is fairly new. I have asked around a bit and have gotten a quite a bit of complaints about spray on foam insulation and the cost vs. profit.
I am also looking into a spray on rubber coating insulation, but I think the cost vs. profit factor might be an issue their as well.
Old 11-01-2013, 12:54 PM   #4
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
Just curious..... what is that puppy ????......
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Old 11-01-2013, 01:11 PM   #5
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
Go big or go home!
Metro M & L is offline
Old 11-01-2013, 01:16 PM   #6
Trade: Insulation
Not too sure about the rubber insulation. I was talking to a friend about it and he told me that he knew someone using a two part rubber system to spray in ceiling tiles. I have not been able to find much on it, but it seemed interesting.
Spray Insulation Water Pump and 2 Jet Nozzle for sale Kansas City InsulationGuy Contractor Swap 0 08-31-2012 10:15 PM
Would insulation below membrane help? 232323 Roofing 11 11-15-2011 09:40 PM
Spray Foam Insul Kits. Timber Jockey General Discussion 1 12-19-2010 10:11 AM
opinions on spray foam insulation anyone sprayfoambob General Discussion 20 04-05-2008 10:06 PM
Spray foam insulation? tgeb Insulation 5 12-16-2007 11:11 PM
