Garage Roof Insulation - Insulation - Contractor Talk
Old 08-11-2015, 01:18 PM   #1
GasCat's Avatar
Trade: metal fabrication
Rewards Points: 2
I am going to insulate my garage roof because I don't want a ceiling and want to keep the extra space open. I wanted to do closed cell spray foam but thought that would present a problem if I ever have to install a new roof having the foam stuck to the chip board. Next I was thinking craft faced fiberglass rolls with a foam board for extra insulation and support for the batts. I was also pondering radiant barrier under the fiberglass insulation.
I don't have any sofet vents and only have a bird cage on the roof whitch I would remove and seal because I am going to AC and heat the garage.
What are your thoughts on the best way to get the max out of this project.
GasCat is offline
Old 08-11-2015, 01:29 PM   #2
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
Re: Garage Roof Insulation
What do you mean by "bird cage?"
- John Williams
Complete Window and Door
Originally Posted by TNTSERVICES View Post
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
Old 08-11-2015, 03:26 PM   #3
GasCat's Avatar
Rewards Points: 2
The turbine vent.
GasCat is offline
Old 08-11-2015, 08:58 PM   #4
txgencon's Avatar
Rewards Points: 468
Originally Posted by GasCat View Post
... I wanted to do closed cell spray foam but thought that would present a problem if I ever have to install a new roof having the foam stuck to the chip board...
Replacing whatever roofing material used wouldn't be an issue. Are you concerned about some day replacing the decking?
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Old 08-11-2015, 09:33 PM   #5
GasCat's Avatar
Rewards Points: 2
Yes. I don't want to spray foam up there and have it stick to the decking and get firm up if it needs to be replaced. So was thinking of fiberglass rolls and foam board.
GasCat is offline
Old 08-15-2015, 05:04 PM   #6
windowsonwashington.net
WindowsonWash's Avatar
Trade: Exterior Construction
Rewards Points: 1,178
Where is the home and how about a picture of the inside and exterior?
Windows on Washington
WindowsonWash is offline
Old 08-15-2015, 10:14 PM   #7
Donohue Const's Avatar
Rewards Points: 1,722
So if I understand right, you want to do a "hot roof"?
Since it sounds like you will have no venting
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
Old 08-17-2015, 07:07 AM   #8
GasCat's Avatar
Rewards Points: 2
Yes no venting. Like a cathedral ceiling but instead of sheetrock I pained on using foam board.
GasCat is offline
Old 08-17-2015, 07:19 AM   #9
Box Builder
Morning Wood's Avatar
Rewards Points: 10,374
Since your roof is probably not air sealed and your finished roof is already on, you are pretty much stuck with doing spray foam. That is my opinion. Closed cell, you could flash and batt. I'd use closed cell and then open cell or dense pack cellulose to finish off the interior. Foam board under the rafters helps with thermal bridging, but it is labor intensive and you still need to install gypsum or ply over foam board for fire code issues.
Morning Wood is offline
Old 08-17-2015, 07:21 AM   #10
GasCat's Avatar
Rewards Points: 2
Ok. Thanks a bunch.
GasCat is offline
Old 08-18-2015, 08:18 AM   #11
Where is the home?
If you are demoing the interior, you have a few options.
SPF is definitely the easiest but isn't cheap. Depending on where you are, OC SPF will work fine too.
Old 08-18-2015, 05:03 PM   #12
GasCat's Avatar
Rewards Points: 2
Houston TX. Not demoing. The garage was never finished out.
GasCat is offline
Old 08-20-2015, 07:02 AM   #13
Is the roof metal or asphalt? South Facing? Pitch?
You spray a roof in Texas and you can count on it lasting not as long. You can create a below deck vent system or spray it.
If you spray it, I would still put in some rigid foam to to isolate it from the roof deck.
Old 08-20-2015, 09:43 AM   #14
GasCat's Avatar
Rewards Points: 2
That's good info thanks.
GasCat is offline
Old 08-20-2015, 09:44 AM   #15
GasCat's Avatar
Rewards Points: 2
The roof is pitched on all four sides. Front is east facing.
GasCat is offline
Old 08-22-2015, 10:05 AM   #16
If it were my home, I would create a below deck vent channel with some foil faced ISO board, open the roof at the bottom and the top, and then spray over the foam.
Best of both worlds. Insulation and venting.
Old 08-22-2015, 01:39 PM   #17
GasCat's Avatar
Rewards Points: 2
That sounds like a really good idea
GasCat is offline
Roof gone Bad! Round Dormers, Anyone have experience with them? stombaugh85 Roofing 10 01-03-2013 09:42 AM
Fire Rating of garage walls, exterior siding Richard_N_S General Discussion 9 12-12-2012 09:58 PM
Should you pay more for a quality insulation job? ecworks Insulation 8 12-10-2012 10:02 PM
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
