Garage Door Insulation - Insulation - Contractor Talk
Old 02-11-2011, 07:34 PM   #1
davinci's Avatar
Trade: roofing
does a well insulated garge door really make a difference as far as keeing a house warmer? i have a bedroom over my garage and my bedroom is freezing. the doors are old. would getting new doors make a difference?
davinci is offline
Old 02-11-2011, 07:37 PM   #2
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 448
Re: Garage Door Insulation
I have a bi level with bedrooms over the garage. We insulated the garage walls and used an insulated door when we built it. Seems like it helps a little but it is still a bit colder than the rest of the house. In my detached garage I have an uninsulated door and even with the walls and ceiling insulated, it doesn't hold heat very well.
Warren is offline
Old 02-11-2011, 07:48 PM   #3
Etowngiant's Avatar
Trade: Steel framing
Always check and make sure the blockers and runners are insulated well...
You can buy a thermal scanner at a decent price if you shop around too.
Etowngiant is offline
Old 02-11-2011, 07:51 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 2,448
I noticed that the insulated doors helped keep the garage & shop warmer. But, I don't have the cold weather you guys have.
griz is offline
Old 02-11-2011, 08:34 PM   #5
txgencon's Avatar
Rewards Points: 468
With the weather in my area (Dallas, Texas), the big difference is with a west facing door in hot weather. I replaced a non-insulated door with an insulated door last August and it made a lot of difference. Lately, with temperatures below 20 degrees F, it didn't seem to help much.
txgencon is offline
Old 02-15-2011, 08:14 AM   #6
EdCon
edconst's Avatar
Trade: framing and exterior reno
If your not going to heat your garage then don't bother with an insulated door it won't help much. If not heating garage then insulate the bedroom floor joists. I actually do this on heated garages because who keeps their garage at the same temp as house and it will cut down on noise transfer. This seems to work pretty well where I am and we see -30C regularly between nov to feb.
edconst is offline
The Following 2 Users Say Thank You to edconst For This Useful Post:
concretemasonry (12-12-2013), Golden view (12-12-2013)
Old 05-28-2012, 02:14 PM   #7
We Repair Garage Doors
doorrepairsac's Avatar
Trade: Garage doors, openers and garage door repair
Rewards Points: 250
I serviced a garage door in Blackhawk, CA where the concrete floor was self heating, amazing!
doorrepairsac is offline
Old 05-28-2012, 02:42 PM   #8
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 144
How?
donerightwyo is offline
Old 12-12-2013, 07:51 PM   #9
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 1,216
Is that you Darwin?
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is online now
Old 12-12-2013, 08:04 PM   #10
diplomat
Golden view's Avatar
Rewards Points: 1,550
The Gdoor can be a major source of heat loss through infiltration and convection. I built in the subarctic so things were a little more overkill but we always used something like overhead door 494
In my homes the boiler would keep the garage warm when it was -40 outside, no call for heat.
Golden view is offline
Below grade attached garage, concerns new home owner Construction 1 09-06-2010 08:14 AM
Garage problems.... nwksremodeler Remodeling 29 05-12-2010 02:55 PM
does the garage really need the GFI? handyman99 Electrical 21 08-31-2009 11:33 AM
Vapour barrier between garage and living area?? big builder Insulation 18 12-23-2008 02:25 PM
