Flash Coat Of Polyurethane Foam With Cellulose - Insulation - Contractor Talk
Old 05-29-2015, 08:00 AM   #1
fikey's Avatar
Trade: Handyman
Rewards Points: 100
I am building a house in Idaho, zone 6. I was set on using a flash coat of foam with cellulose filling the cavity. In getting a second price, I was informed that this could cause moisture to condensate in the cavity. The information I researched did indeed say that flash and batt could have these problems. Is flash and cellulose the same?The only other "reasonably" priced option is open cell urethane. ??? I live in a colder climate and it can be really windy and I do not want air infiltration. HELP
fikey is offline
Old 05-29-2015, 09:17 AM   #2
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 182
Re: Flash Coat Of Polyurethane Foam With Cellulose
Splash & Dash / Flash & XYZ are bad practices - you need to hit the code &/or manufacturer minimum to actually get the benefits of it acting as an air / vapor barrier
1.5" Closed Cell & 4" open cell (though that is debatable) if memory serves me correctly
Batts should never be used - blown in materials are better as you don't have to worry about voids, compressions, etc... but it must fill the cavity to the proper density
SLSTech is offline
The Following 2 Users Say Thank You to SLSTech For This Useful Post:
BlueRidgeGreen (05-29-2015), Tom Struble (05-29-2015)
Old 05-30-2015, 07:24 AM   #3
fikey's Avatar
Trade: Handyman
Rewards Points: 100
What code are you referring to? Do you think open cell is a good product?
For some reason I have always thought it was inferior.
fikey is offline
Old 06-17-2015, 12:21 PM   #4
ASInsulation's Avatar
Trade: Insulation and Weatherization
Rewards Points: 220
I never recommend open cell up front as it carries much of the cost of install, with very little of the extra benefits over batts or blown. If you were to apply .5-1" of closed cell foam and then appropriately densepack the wall cavity to achieve your R-value, I would say your risk is going to be very slim. You can further cut it down by applying complete foam in any bays with water or plumbing lines, or any duct work that may run in an exterior wall cavity.
ASInsulation is offline
The Following User Says Thank You to ASInsulation For This Useful Post:
BarryP (08-25-2015)
Old 06-17-2015, 06:51 PM   #5
Box Builder
Morning Wood's Avatar
Rewards Points: 10,374
Are you talking about walls or ceilings? How thick are the walls and ceilings. And are the roofs hot or cold? We need details to answer your question appropriately
Morning Wood is offline
Have the Hilti foam gun but where to get foam? BCConstruction Tools & Equipment 18 02-21-2020 07:13 PM
Closed Cell Foam ctg-andrew Insulation 0 05-11-2015 01:42 PM
Tyvek under 1/4in foam for Vinyl siding? PittTrack Windows, Siding and Doors 66 06-22-2012 12:56 PM
Open cell foam overtop closed cell foam jnjsad Insulation 1 03-03-2010 11:16 PM
Spray foam under a slab for insulation -- Mike Finley Construction 22 01-10-2010 02:39 PM
