Do These Vent Chutes Look Right To You? - Insulation - Contractor Talk
Old 03-10-2014, 10:49 AM   #1
mattbarnes's Avatar
Trade: Plumbing
I'm a plumber, so vent chutes and soffits aren't my thing. Anyway, my wife wants to bug the contractor of our new house in construction about every little thing. I've held her off for now, but she sent me these pictures today, and I wanted to get some feedback - is this bad enough for me to bug the contractor over?
I'd rather just get up there and do it myself if I could.
Do these vent chutes look right to you?-photo-11.jpg   Do these vent chutes look right to you?-photo-10.jpg   Do these vent chutes look right to you?-photo-9.jpg
mattbarnes is offline
Old 03-10-2014, 02:34 PM   #2
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 182
Re: Do These Vent Chutes Look Right To You?
Nope not correct, though I am not sure why they have them run so far past the insulation. Radiant barrier sheathing above? To DIY it - http://blog.sls-construction.com/201...-attic-baffles
Now would you mind adding in your location & popping over to the intro section to tell us about yourself?
SLSTech is offline
Old 03-10-2014, 06:11 PM   #3
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 12,083
Ahhhh. I know what those are. Throw him to the fishes.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 03-10-2014, 06:44 PM   #4
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,548
I like the exhaust pipe...I assume a bath fan. No insualtion and dumping right on the roof deck...that will be a mess soon.
overanalyze is offline
Old 03-10-2014, 08:49 PM   #5
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
I think #2 looks the best, although it is a bit broken.
I put these in each and every rafter chute. I think they are not only for ventilating the attic space, but also for air flow on the underside of the sheathing. Otherwise you have direct contact between the sheathing and the insulation in that area, and I think this will give you a rotten space over time.
I have retro'd many of these and I have one coming up to do on a 24' wide ranch with a hip roof, 4/12. Needless to say, I'm not looking forward to doing it.
I am thinking maybe to just blow everything in, then rip out the soffits and go along from the outside shoving a chute up there with something on the end, then knocking the end off when it has a few staples in it towards the bottom.
Anyone else have any ideas on how to do this from the exterior after the fact? Please don't tell me to remove the roof.
cleveman is offline
Old 12-04-2014, 08:43 PM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 10,374
Those chutes are a joke to begin with. That install is bad. And if thats a vent fan insulate that duct
Morning Wood is offline
Old 06-17-2015, 12:08 PM   #7
ASInsulation's Avatar
Trade: Insulation and Weatherization
Rewards Points: 220
It depends on your insulation application as well as whether the cosmetics is a true concern. Would I install personally to that standard, no. But will it keep fiberglass or blow in insulation from blocking the soffit, yes. If it is going to be a spray foamed, vented roof deck, then absolutely not. If you are going to bug him though, but him about the vent pipe, which I assume is venting out some type of exhaust fan.
ASInsulation is offline
Old 06-17-2015, 11:05 PM   #8
BarryP's Avatar
Trade: Insulation
Rewards Points: 1,128
Way more ventilation than needed anyways. You don't need to vent every run with double width vents. 1sq ft ventilation to every 300 sq ft of attic
BarryP is offline
Major Water Condensation in Furnace Flue Vent in Attic - Drywall Damage seaweed HVAC 11 01-13-2014 08:51 PM
Vent install gav_sharma Remodeling 2 10-05-2013 08:14 AM
Ridge Vent advice power Roofing 12 01-22-2013 09:55 AM
seal gable vents after ridge vent installed? tacoma5050 Roofing 41 06-07-2012 07:32 PM
Question about vent work licensed-trim Finish Carpentry 9 03-06-2010 01:37 AM
