Curiosity And The Cat - Insulation - Contractor Talk
Old 12-20-2015, 11:28 AM   #1
Creter's Avatar
Rewards Points: 1,966
A client of mine has an issue with her cats getting into the rim joist insulation in her basement.
She has multiple shelves and storage systems that the cats are able to ascend and get into the insulation.
Contemplating a way to shield the insulation from the cats in a cost effective, yet at the same time, durable manner
One idea I had was boxing the areas out with plywood to the first available joist.
Thought that maybe there are other ideas out there. So throwing it out there.
Thanks in advance!
Creter is offline
Old 12-20-2015, 11:44 AM   #2
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Re: Curiosity And The Cat
this:
http://www.homedepot.com/p/Unbranded...1178/203183010
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Creter (12-20-2015)
Old 12-20-2015, 11:54 AM   #3
Creter's Avatar
Thinking of just ripping ply on the table saw and fastening flat along the areas of cat intrusion...
Creter is offline
The Following User Says Thank You to Creter For This Useful Post:
SmallTownGuy (12-20-2015)
Old 12-20-2015, 11:56 AM   #4
Lazy Millennial
Youngin''s Avatar
Rewards Points: 758
Is the basement undeveloped? Sounds like it. Is she planning on developing it eventually? Would it be worth putting drywall along the affected walls to be tied into if she does develop it?
Originally Posted by mnld View Post
Home Depot... you can glue it, we can help!
Youngin' is offline
The Following User Says Thank You to Youngin' For This Useful Post:
Creter (12-20-2015)
Old 12-20-2015, 11:57 AM   #5
John the Builder
Originally Posted by Creter View Post
Thinking of angling it from the sill plate that runs parallel to the first joist and fastening it to both.
Then at the walls where the joists are attached to the rim simply running it flat.
Yeah, it ain't got to be too pretty. Cut it an 1/8 long & spring it between joists on the butt runs.
Creter (12-20-2015)
Old 12-20-2015, 12:17 PM   #6
Creter's Avatar
Correct in that it is unfinished. She has no plans of finishing the basement at the moment other than a wall with a door that will make one section of her basement cat proof. That wall I will lay out in a manner to tie in to future finishing if that would ever occur.
Creter is offline
Old 12-20-2015, 12:52 PM   #7
BarryP's Avatar
Trade: Insulation
Rewards Points: 1,128
How about using hardware cloth to cover the insulation?
BarryP is offline
Old 12-20-2015, 12:57 PM   #8
Lazy Millennial
Youngin''s Avatar
Rewards Points: 758
I suppose if you want to go really cheap you could throw some chicken wire up there.
Youngin' is offline
Old 12-20-2015, 05:28 PM   #9
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Rewards Points: 1,262
simple-- shoot the cats and most of their (the cat's) relatives. It would solve a lot of problems in this world.
Anthill is offline
The Following 2 Users Say Thank You to Anthill For This Useful Post:
BarryP (12-20-2015), digiconsoo (12-20-2015)
