Blown In Walls With Rental Machine - Insulation - Contractor Talk
Old 12-03-2015, 08:08 PM   #1
diplomat
Golden view's Avatar
Rewards Points: 1,550
I want 20 bays insulated on my garage. Hard to get a good deal from a sub on such a tiny job, and I don't have any good relationship with an insulation contractor since I generally do a few batts myself on the walls I open.
Even though the pressure isn't sufficient and it's not designed for it, I wonder if I can get decent results with the little Home Depot atticat machine, which basically shoots L77. I don't even care if it settles a little. The heat loss already isn't terrible through the uninsulated wall. Fiberglass isn't nearly as bad as cellulose.
Any tips?
Golden view is offline
Old 12-03-2015, 08:28 PM   #2
diplomat
Re: Blown In Walls With Rental Machine
According to OC, it IS possible with the little rental machine. I had no idea. Now to invent my tapered drywall plug hole saw.
Old 12-03-2015, 08:35 PM   #3
tjbnwi's Avatar
Rewards Points: 4,688
The HD near me has the machine for cellulose, they have a different nozzle for use on walls.
tjbnwi is online now
Old 12-03-2015, 09:15 PM   #4
BarryP's Avatar
Trade: Insulation
Rewards Points: 1,128
You need between 2.8 to 4psi to do a decent job. Fact is, unless you run tubing up the wall, you are sure to end up with a poor job (voids in the wall).
BarryP is offline
The Following 2 Users Say Thank You to BarryP For This Useful Post:
Golden view (12-03-2015), SLSTech (12-04-2015)
Old 12-04-2015, 09:32 AM   #5
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 184
Just got to add - by the time you pick up the rental machine, fabricate the tube, blow the product in & return it - you are probably already paying more than you would to have someone else do it (assuming you value your time)
As for the tube mentioned above - in some cases it isn't necessary but that is only when you have a completely clean bay (no wires / pipes / protruding fasteners...) and even then you might not get the best results - i.e. the voids mentioned above.
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
Golden view (12-04-2015)
Old 12-04-2015, 09:40 AM   #6
diplomat
I do value my time a lot but I have a slow week coming up from a cancellation so I might just try to save a few bucks.
Old 12-04-2015, 09:41 AM   #7
BarryP's Avatar
Trade: Insulation
Are you willing to open up the cavity to send the 3" hose into it? If you try to make a nozzle that is smaller than 2" you will plug your hose.
Since there is no way to restrict the amount of fiberglass being blown with an adjustable airlock slider, you will only pack the insulation in the opening you make.
Insulators turn their air up and their material feed down.
If you have a Lowes or Menards nearby, see if they have a small blue metal Krendl. It has a smaller diameter hose and has an adjustable airlock.
BarryP is offline
Old 12-04-2015, 10:03 AM   #8
diplomat
I've used the krendl machine before, but I want to do fiberglass.
Old 12-04-2015, 10:04 AM   #9
BarryP's Avatar
Trade: Insulation
The Krendl will certainly do fiberglass.... Unless you are talking about their 1970s machine
BarryP is offline
Old 12-04-2015, 10:05 AM   #10
diplomat
Ha! Probably. Thanks, I'll look into it.
Old 12-04-2015, 10:06 AM   #11
BarryP's Avatar
Trade: Insulation
You may be right. I just found a through blower they still make just for cellulose
BarryP is offline
Old 12-04-2015, 10:08 AM   #12
diplomat
To answer this question though, I could make a single hole at the top of the wall big enough to send the 3" hose to the bottom plate and pull up as I go. 7" reveal Hardie on the outside and the top board is right under the top plate. Easy to remove and replace unobtrusively.
BarryP (12-04-2015)
Old 12-04-2015, 10:08 AM   #13
BarryP's Avatar
Trade: Insulation
Perfect!
BarryP is offline
The Following User Says Thank You to BarryP For This Useful Post:
Old 12-04-2015, 10:10 AM   #14
BarryP's Avatar
Trade: Insulation
You won't clog your hose and you will end up with a decent job. Not packed properly, but at least you are gaining.
BarryP is offline
Old 12-04-2015, 10:13 AM   #15
diplomat
Awesome, thanks. I'll do it from the outside then with one hole per bay. I'll just try my best to get the hose pull speed to achieve a reasonable PCF.
I've done a few thousand bags in attics, but never walls. Do I need some sort of mesh at the hole so it doesn't blow out while installing?
BarryP (12-04-2015)
Old 12-04-2015, 10:17 AM   #16
BarryP's Avatar
Trade: Insulation
Mesh may work. I don't know how you will do that.
Get a towel to stop the material from coming back on you. Get a mask too
BarryP is offline
Wet tap machine Gsittoniv Contractor Swap 3 03-02-2015 10:38 PM
Helped a friend build some walls wallmaxx Carpentry Picture Post 8 07-09-2012 09:22 PM
What is the max distance for load baring walls in a residence? kgcaddesign Architecture & Design 13 06-03-2012 02:35 PM
Sagging floors, over spanned joists, load bearing walls without support and more technique Remodeling 104 05-14-2010 04:16 AM
