Blow In Insulation - Insulation - Contractor Talk
Blow In Insulation
Old 02-25-2010, 08:11 AM   #1
Versacoat
Versacoat's Avatar
Trade: Epoxy floor coatings
Blow In Insulation
I have a 12 year old house that has fiberglass batt insulation and the contractor did a really bad job. I want to add some blow in insulation to help bring our energy costs down. In our ceiling we have about 30 recessed lights. Now the way I understand it you should not cover those with insulation.
Questions.
1) Is that correct about not covering the lights with insulation?
2) If you are not to cover them how do you seal them off so the insulation isn't touching them?
3) Can anyone share their process on how to deal with this?
Thanks!
Versacoat is offline
Old 02-25-2010, 08:14 AM   #2
Joasis's Avatar
Rewards Points: 652
Re: Blow In Insulation
You might want to check the cans and see if they are insulation compatible. If they are, nothing needs to be done, and if not, they have blocking materials for them, and the blow in covers them completely.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
The Following User Says Thank You to Joasis For This Useful Post:
Versacoat (02-25-2010)
Old 02-25-2010, 09:59 AM   #3
zab's Avatar
Trade: Energy Renovation / Masonry
Rewards Points: 25
cans - if they aren't certified for direct contact then:
use a sheet material (generally sheetrock or 1/2" High-R) to box around the light. What you really want/need to do is stop air infiltration through the cans, so seal with single or 2 part foam.
I'm not particularly familiar with cooling houses, so I can't give you many more suggestions then that
zab is offline
Old 02-25-2010, 03:06 PM   #4
parts's Avatar
Trade: Insulation contractor
Rewards Points: 150
If they are only 12 years old you have a chance they are insulation contact lights as that was the standard for outside ceiling here then check them. If they are not I would be hesitant sealing them up with foam or even boxing them in with such. They make a metal product to do this you can get a an insulation supply house or better yet switch them out.
parts is offline
Old 02-25-2010, 11:32 PM   #5
tommytwo's Avatar
Trade: Remodeling and Home Performance
Rewards Points: 79
If they are not IC rated, we make a box out of sheetrock, keeping 3" clearance on all sides and above. Use can foam to seal the edges of the box. Do NOT insulate above them.
tommytwo is offline
The Following User Says Thank You to tommytwo For This Useful Post:
Versacoat (02-26-2010)
Old 10-29-2013, 01:32 PM   #6
MattAngelly's Avatar
Trade: General Contracting
Make sure you save your receipts for when it comes time to do your taxes. Insulation projects fall under the American Taxpayer Relief Act and you can qualify for huge tax credits!
Read about the American Taxpayer Relief Act here... http://www.solomoncontractingstl.com...energy-solomon
MattAngelly is offline
Old 11-01-2013, 11:22 AM   #7
ASInsulation's Avatar
Trade: Insulation and Weatherization
Rewards Points: 220
If you give yourself plenty of clearance above the lights around your blocking(8-12 inches) a breathable material such as fanfold may be a good idea to drastically cut airflow and give some r-value. I've always avoided leaving them completely uncovered as much as possible. If there isn't an R-value applied universally to the attic plane, it will drastically effect performance.
ASInsulation is offline
Old 11-01-2013, 12:15 PM   #8
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
I'm no insulation contractor...... but seems to me that if you are going to the trouble of insulating, while you are up there, it is worthwhile to go ahead and replace your cans with obviously IC (insulation conjtact) rated cans, and I go ahead with IC air tight cans....
the airtights are more expensive, but it seems to me that ceiling cans are like a lot if individual chimneys throughout my home.....
not sure if technology has now brought on IC airtight LED fixtures... might be a consideration while you're doing it.
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Should you pay more for a quality insulation job? ecworks Insulation 8 12-10-2012 10:02 PM
Blow in insulation into walls? beapainter Remodeling 6 01-08-2010 07:25 PM
Insulation Blower? MEL Insulation 7 11-25-2009 12:07 AM
Foam Insulation - Close and Open Cell AMS Co Insulation 4 10-09-2009 04:08 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
