Basement Spray Foam - Insulation - Contractor Talk
Basement Spray Foam
Old 01-29-2017, 12:41 PM   #1
fourcornerhome's Avatar
Trade: home improvement contractor
Rewards Points: 1,958
Basement Spray Foam
I never used spray foam on a basement finish job but have a client requesting it.
Typically we would use rigid board or fiberglas batts.
Does spray foam make sense? Is it overkill and is the cost justified?
I have no idea of the cost and need to shop prices but what can I expect?
Northeast Ohio......
fourcornerhome is online now
Old 01-29-2017, 03:09 PM   #2
NJGC's Avatar
Location: Unfortunately I live in the communist republic of NJ.
Rewards Points: 82
Re: Basement Spray Foam
Spray foam in the rim joist area is well worth the $. Most times the rim is under or un-insulated and leaks more air than all the windows combined. On walls I think it would be foolish and never really "pay for itself". Ridgid foam is absolutely the way to go on walls.
Spray foam is expensive and IMO not worth the $ anywhere but the rim area in a basement.
Sent from my SAMSUNG-SM-G930A using Tapatalk
NJGC is offline
The Following 2 Users Say Thank You to NJGC For This Useful Post:
fjn (02-21-2017), Philament (01-29-2017)
Old 01-29-2017, 03:15 PM   #3
TaylorMadeAB's Avatar
Trade: Renovations
Rewards Points: 1,686
I just did a quick spray on a basement I'm finishing, about 1100 ft2. I used 2 of those "froth packs" made by DOW. There are some other brands out there too. Cost about $1000 with my labour included, so I'd say it's well worth it.
I should clarify, I just did the rim joist areas.
TaylorMadeAB is offline
Old 01-29-2017, 03:36 PM   #4
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,220
I second NJGC's sentiments.
The few exceptions would be foundation walls that have a lot of undulations to them like board formed or stone because they're so difficult to air seal with board material. The other exception being speed, where you frame the walls off the foundation have them spray foam the rim and wall then just come back to do the finishing.
Personally I would never do a basement with fiberglass though.
Philament is offline
The Following 2 Users Say Thank You to Philament For This Useful Post:
NJGC (01-29-2017), Randy Bush (01-29-2017)
Old 01-29-2017, 05:41 PM   #5
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 114
Closed cell only if there is even a hint of moisture or moisture might be an issue
Yes it is well worth it depending on one's goals but for most when they see the price they go with a rigid board which can work almost as well though as mentioned above if moisture might be an issue you had better have a way of getting rid of that water which can add to the cost & complexity quickly
SLSTech is offline
The Following 2 Users Say Thank You to SLSTech For This Useful Post:
overanalyze (01-29-2017), Philament (01-29-2017)
Old 01-29-2017, 07:10 PM   #6
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 15,173
2"x4x8 poly coated styrofoam 1100 sf is $565 at retail cost from HD.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 01-29-2017, 07:17 PM   #7
Philament's Avatar
Is that an EPS sheet product?
Old 01-29-2017, 07:20 PM   #8
LRG WoodCrafting
Leo G's Avatar
Oops, says it 2' wide.
Was looking for the 1" originally. $18.85 each.
Don't know if it's EPS
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 01-29-2017, 11:18 PM   #9
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
I often do this for rim joist insulation, albeit with 2" RMax foil sided foam. The surround foam is just Great Stuff foam shot from a gun. Fairly quick and cost effective, with little vapor issues.
Peter_C is offline
The Following User Says Thank You to Peter_C For This Useful Post:
MarkJames (02-22-2017)
Old 01-30-2017, 03:31 AM   #10
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,202
How did you like the froth pack? I need to do the rim joist in my house and thought about using one of the diy kits...frothpack or tiger foam. Thinking about doing that or using rigid foam like peter c did. House is only 800 sq ft so I dont need much foam
Windycity is offline
Old 01-30-2017, 08:17 AM   #11
NJGC's Avatar
Rewards Points: 82
When $ is an issue I do it the same as Peter but with a 2 inch thick, reflective one side ridgid foam board. This pic is from a crawl space my guys just tightened up.
NJGC is offline
Old 02-21-2017, 02:53 PM   #12
Trade: Renovations
It's great for a quick job. Fast, easy, fairly clean. After 2 kits I'd say it's more cost effective to get a foam guy in.
Old 02-21-2017, 02:55 PM   #13
Trade: Renovations
I was just doing the rim joists, which had electrical, gas and HVAC run through already. IMO it was cheaper and faster to spray a continuos layer rather than piece in a bunch of chunks.
Old 02-21-2017, 05:33 PM   #14
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
Still needs fire protection on the spray foam, if I am not mistaken, or at least the last time I did one.
jlhaslip is offline
Old 02-22-2017, 01:04 AM   #15
Trade: Renovations
Inspector didn't ask for it... I've never heard of that before.
Old 02-22-2017, 08:00 AM   #16
Sean
SLSTech's Avatar
Rewards Points: 114
Per codes, the answer is yes unless the foam meets certain requirements. With that fire protection can be a sprayed on barrier, drywall, certain insulation, etc...
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
TaylorMadeAB (02-22-2017)
Old 02-22-2017, 06:03 PM   #17
Joe Pro's Avatar
Rewards Points: 246
Here it's cheaper to spray closed cell than buy and install the foam. Last basement was 105 lineal ft of 8ft wall 3" r17 of closed cell for $1,663. Just to buy the 2" foam with r13 would be $1,200, no tape, no great stuff. Plus spraying no worries of gaps or leaks.
Plus I'm somewhere else doing carpentry not insulation.
Joe Pro is offline
Spray Foam not adhering to concrete basement wall... Paint & Hammer General Discussion 6 11-04-2012 01:39 PM
Spray foam insulation and Vapor barriers in bathrooms Zenscapes.ca Remodeling 9 10-22-2012 07:01 AM
2x4 Basement Stud Walls On a Three Story Home WITH NO FOOTER Baltimore Carpentry 13 08-16-2012 07:02 PM
Spray Foam Insulation q&a Demilec Brandon Insulation 34 12-04-2011 01:27 AM
Soy Based Spray Foam ApgarNJ Insulation 9 08-05-2010 08:36 AM
