Advice On How To Fix Old Home Owners Addition - Insulation - Contractor Talk
Old 07-31-2017, 12:13 AM   #1
mattcubb's Avatar
Rewards Points: 4
Hello I am a contractor / handyman and recently started a job requiring some brick repointing and replacing paneling with drywall.
The home owner purchased this house last fall. It has a sunroom addition built by previous owner. The sunroom used to be a porch/patio above the garage with a brick wall around 32" acting as a railing. The addition is halfass quality. After removing the paneling and finding wet insulation and every stud rotted on the bottom 10" i also discovered the entire room is simply resting on the bricks with a crowbar you can move the whole wall. And im pretty sure they didnt use any foam board on the top half of the room just plywood some crappy rolled insulation and siding.
Any recommendations on what to do for a moisture barrier and insulation on the inside on the brick and plywood?
Advice on how to fix old home owners addition-1501477896942.jpg   Advice on how to fix old home owners addition-1501477958125.jpg
mattcubb is offline
Old 07-31-2017, 12:26 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,292
Re: Advice On How To Fix Old Home Owners Addition
To protect your reputation and exposure to liability you have two choices...
1) Tear it down, get permits (if applicable) & build it right...
2) Run away quick, & Leave it alone as it is a disaster waiting to happen...
griz is online now
The Following 9 Users Say Thank You to griz For This Useful Post:
A&E Exteriors (07-31-2017), B.Johnson (07-31-2017), fjn (07-31-2017), Fouthgeneration (08-01-2017), onmywayup (07-31-2017), Peter_C (07-31-2017), Philament (07-31-2017), Robie (07-31-2017), SmallTownGuy (07-31-2017)
Old 07-31-2017, 03:17 PM   #3
90%-er
onmywayup's Avatar
Rewards Points: 2,104
He's right. Can't "fix" this one. It was simply built wrong from the get go and it's gonna bite you in the ass if it doesn't get totally redone. Last man that touches it owns it.....
onmywayup is offline
The Following User Says Thank You to onmywayup For This Useful Post:
Old 07-31-2017, 03:27 PM   #4
fjn's Avatar
Trade: mason
Rewards Points: 10,678
If it was a truck instead of a building,I'd say open the hood,jack up the radiator cap and slip a new truck under the cap.
fjn is offline
Old 07-31-2017, 03:59 PM   #5
Lettusbee's Avatar
Rewards Points: 838
Take the mike Holmes approach.
Sent from my SM-G860P using Tapatalk
Lettusbee is offline
Old 07-31-2017, 06:46 PM   #6
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,636
I think this should be moved from the insulation forum to the excavation and sitework forum. LOL
B.Johnson is offline
Old 07-31-2017, 06:54 PM   #7
fjn's Avatar
Trade: mason
Or,start a new section.......demolition.
fjn is offline
Old 07-31-2017, 09:56 PM   #8
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,525
How does one "run" when you're the one who removed the walls and insulation to reveal the dilemma?
MarkJames is offline
Old 07-31-2017, 10:12 PM   #9
John the Builder
SmallTownGuy's Avatar
Rewards Points: 7,824
All you got to do when you open it up is say "hey, this is beyond the SOW, call me when you get it fixed".
That's exactly what happened with that gal from my church: HD ripped her bathroom out, discovered bad joists and said "call us when you get it fixed".
SmallTownGuy is online now
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
hdavis (08-01-2017), MarkJames (07-31-2017)
Old 08-02-2017, 06:08 AM   #10
mattcubb's Avatar
Rewards Points: 4
Thanks for all the help and advice.
mattcubb is offline
Seeking advice on flooded LA home willg General Discussion 11 09-02-2016 08:56 PM
Building with Adobe as a Cost Effective Solution for Home Construction? tierraconcepts Green Building 14 09-19-2015 05:52 PM
2x4 Basement Stud Walls On a Three Story Home WITH NO FOOTER Baltimore Carpentry 13 08-16-2012 07:02 PM
Custom Home Builder vs. Spec and Tract Builder renet General Discussion 4 11-16-2008 01:51 AM
