Adding Insulation - Insulation - Contractor Talk
Adding Insulation
Old 12-04-2007, 06:00 PM   #1
Small Project Specialist
RightConnection's Avatar
Trade: Home Repair and Maintenance
Rewards Points: 27
Adding Insulation
Several of my neighbors got to talking and want to add another layer of insulation into their attic ... I've looked at a couple of the homes and they will require a layer of R30 to meet the current standard ... All attics are accessible via a pulldown stair and are approx 750 to 900 sq ft ...
I've priced R30 unfaced locally for about 65 cents per square foot, but I don't have a good idea of labor costs ... I would be doing the job alone, material would be delivered and stored on-site in lower level garages so I would be carrying up a total of 3 flights of stairs ...
Any ballpark numbers would be appreciated ...
RightConnection is offline
Old 12-04-2007, 07:05 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Re: Adding Insulation
To make it worth your while I would be thinking about $ 1.00 per sq.ft. you should be able to do a house a day without killing yourself.
What's your time worth?
Chris
Chris Johnson is offline
Old 12-04-2007, 08:51 PM   #3
Home Serve's Avatar
Trade: General Remodeling
Rewards Points: 250
Around here nobody would use fiberglass batts to add to existing insulation. They would blow it in with an insulation machine. Cellulose or fiberglass can be blown in. It is much better than manually trying to add insulation over existing. It does not make sense to lay in all the batts by hand when you can blow it all in leaving no gaps, not tromping all over the attic on existing insulation, etc. There are certain procedures you should follow for this of course, do some homework first! Make sure that you are doing these folks a good service not just makin some $$.
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline
Old 12-04-2007, 08:57 PM   #4
G-Rott's Avatar
Save yourself a lot of crawling around and blow cellulose in. It does a better job of stopping/slowing air infiltration into the existing FG.
Save the homeowners money too blow in at least R-44 if your going up in the attic, heating oil is not getting any cheaper.
After re-insulating a number of Blown FG jobs I would not put Blown FG in a job I an associated with.
Garett
G-Rott is offline
Old 12-04-2007, 09:03 PM   #5
Home Serve's Avatar
Rewards Points: 250
Garett
I think cellulose is better also. Make sure and use the stryofoam channels for air from soffit vents. Be super careful around can lights.
Do some more homework.
Dave C
Old 12-04-2007, 09:09 PM   #6
G-Rott's Avatar
Both good point Dave, Thanks
G-Rott is offline
Old 12-05-2007, 07:25 AM   #7
Joasis's Avatar
Rewards Points: 1,940
I would not be surprised in the next few years if the "myths" of fiberglass finally get exposed....cellulose is the obvious choice.
Unfaced fiberglass has very little, if any, value, and blown could hardly be better. My son's insulation business is getting better, and next year, he may be ready to add the spray foam rig.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Old 12-05-2007, 08:27 AM   #8
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Rewards Points: 2,000
After checking out how the Canadians and the Swedes do insulation I blew cellulose into my attic last year. Blown fiberglass loses value when it gets below 20 degree fahrenheit. Or so I read. I'm convinced. Minnesota.
silvertree is offline
Old 12-20-2007, 05:08 PM   #9
calnan's energy's Avatar
do you have insurance? does the customer use the attic for storage?
do you need to protect the floors for the exterior to the stairway?
if yes to all of the above 1.50 per square footfor all labor. take your time do a neat job.
calnan's energy is offline
Old 04-08-2008, 03:03 PM   #10
Stewcanoe's Avatar
Does anybody have any experience with Owens Corning Pink Plus? Seems like this might fit the bill.
Stewcanoe is offline
Old 04-08-2008, 04:57 PM   #11
DavidC
DavidC's Avatar
Rewards Points: 2,006
... Any ballpark numbers would be appreciated ...
Would that be Wiggly field or the little league park?
A valuable add on service would be to seal all protrusions in the ceilings, light fixtures and the like. It goes a long way to make any insuation job perform better. Make sure you w/strip the attic pulldowns and there is a styrofoam dome you can get to insulate it.
My choice would be cellulose and ignore the FG when doing your R calculations. FG won't get any better with time, very apt to go the other way IMO.
Good Luck
DavidC is offline
Old 04-08-2008, 10:48 PM   #12
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
cellulose up to your balls is a good rule of thumb
cleveman is offline
Canada, ND, MN area - adding insulation to exterior of home - discussion Kevin Remodeling 7 01-02-2008 12:19 AM
Adding extra blown in insulation to attic Mike Finley Construction 8 10-20-2007 08:40 PM
1950s Brick Ranch, No insulation but weird plaster type drwall. personalt Construction 5 01-21-2007 07:49 PM
2000 sf of ceiling...how to remove insulation? carlspackler Remodeling 8 11-26-2006 11:01 AM
Interesting attic insulation findings IHI General Discussion 5 02-28-2006 02:22 PM
