Your Take On "Ben" - Painting & Finish Work - Contractor Talk
Your Take On "Ben"
Old 05-17-2019, 06:46 PM   #1
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 15,705
Your Take On "Ben"
How would you rate the "Ben" line (from Benjamin Moore)?
I thought it was thin and awful. Thank goodness I was just putting a fresh coat (eggshell) over the same color.
MarkJames is offline
Old 05-17-2019, 07:02 PM   #2
KAP's Avatar
Trade: Custom
Rewards Points: 36,020
Re: Your Take On "Ben"
It's changed over the years... the current incarnation, not a fan...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
MarkJames (05-17-2019)
Old 05-17-2019, 07:23 PM   #3
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 5,046
Sorry MarkJames - misread your OP. Not familiar with "Ben per se" but on some other Ben Moore (already had posted);
I question whether the lines retailed through hardware outlets are the same as dealers.
My B.M dealer is excellent with color, I can give him that (one man low volume shop) Some other, more local retailers have shuttered.
Once in a while I used to use Aquavelvet which I liked before it became Regal.
Satin Impervo has always been a standout for doors/ trim (oil) although in the twenty five years or so since I've dipped into it, I'm sure its been redone like the others...
artinall is offline
Old 05-17-2019, 07:26 PM   #4
MarkJames's Avatar
I'm fine with the color, not so much the stuff dripping off my brush while cutting in. Too watery for my taste.
KAP (05-17-2019)
Old 05-17-2019, 07:30 PM   #5
KAP's Avatar
Trade: Custom
They used to be one of the thicker ones...
KAP is offline
Old 05-17-2019, 07:32 PM   #6
artinall's Avatar
I've noticed this watering down in a number of paints.
Apparently the makers seem to think they can increase revenue simply by cranking up the water spigots.
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
Old 05-17-2019, 08:34 PM   #7
VinylHanger's Avatar
Rewards Points: 11,092
I think it also changes the VOC percentages. If there is more water and less "paint", it automatically lowers the VOC content.
VinylHanger is online now
Old 05-18-2019, 01:21 AM   #8
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,338
Ben was my friend. He never did nobody any harm. Only you can prevent forest fires.
Caslon is offline
Old 05-18-2019, 08:01 AM   #9
tjbnwi's Avatar
Smokey attended a neighbors daughters wedding...
tjbnwi is offline
Old 05-18-2019, 08:41 AM   #10
MarkJames's Avatar
Good one for a Saturday morning. So...got an opinion on the paint itself?
Old 05-19-2019, 07:41 PM   #11
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 220
I’ve used it before but still don't really understand why it’s there. I’m using Scuff-X on trim and Regal Select on walls. If I need a cheaper paint I can get Ultraspec for at least $10/gal less than Ben and Ben doesn’t seem to do anything Ultraspec can’t.
EricBrancard is offline
The Following User Says Thank You to EricBrancard For This Useful Post:
MarkJames (05-19-2019)
Old 05-19-2019, 07:47 PM   #12
Talking Head
EthanB's Avatar
Rewards Points: 346
I've almost never used Ben. As others have said. Ultra Spec for budget jobs where coverage isn't an issue, Regal for the rest. I never took to Aura because it was too thick and dried to fast but the formula has probably changed since then. Advance is a good line for some applications.
Thin paint isn't necessarily cheaper. Whiting is a cheap thickener that some brands use to thicken paint without really adding any better hide. Pratt and Lambert was my favorite brand for years until they started making pudding instead of paint. I want it just thick enough the it doesn't spatter but thin enough that it doesn't leave a lot of brush marks or stipple behind.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
Old 05-22-2019, 07:24 PM   #13
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 14,128
Agreeing with the others.
In a world with SuperHide, UltraSpec, and Regal, there is no room in my life for Ben. My needs are already met. I like the finish of Advance and I keep trying to work it into stuff, but the dry time makes it basically useless for most paint jobs. It looks awesome, but not awesome enough for me to wait a whole day to recoat.
Easy Gibson is offline
Old 05-22-2019, 07:27 PM   #14
MarkJames's Avatar
Tell me about superhide and ultraspec (along with the price points).
Old 05-22-2019, 09:47 PM   #15
I think SuperHide is great. It works really well, covers really well, and is really cheap. It's about $20 less a gallon than Regal. I really don't see that much of a discernible difference between the two in terms of finish quality. You maybe have to pay attention a bit more with the SuperHide to make sure it's covered, especially on cutting, but if you've got eyeballs you can figure out what you need to hit harder on the second pass.
I use SuperHide at my place all the time.
UltraSpec is what you'd use to do large scale stuff that isn't going in a magazine. It's fine paint if you're painting a warehouse or whatever. I wouldn't use it in a high end home. You'd have to make too many passes to ensure total coverage. I don't know how well it holds up long term because I rarely use it, if ever.
Paint a warehouse with UltraSpec.
Paint a rental with SuperHide.
Paint the good house with Regal.
Paint a mansion with Aura(because they'll want to know they spent a lot).
Paint the concerned citizen's home with Natura. It's really not that bad!
The Following User Says Thank You to Easy Gibson For This Useful Post:
MarkJames (05-23-2019)
Old 05-23-2019, 02:47 AM   #16
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 8
I pay $30 for Ultraspec, which I think is too much. Superhide is about $19. Aura is $55 or $57. Canít remember exactly. Scuff-X was $40 but they recently upped it to $50. I think itís getting popular so, like a crack dealer, they decided to start screwing people who they got hooked on it. Dries really fast, itís spray paint for dummies. Never seen anything like it.
Big Johnson is offline
The Following 2 Users Say Thank You to Big Johnson For This Useful Post:
Easy Gibson (05-24-2019), MarkJames (05-23-2019)
Old 05-24-2019, 07:30 AM   #17
Tell me more about Scuff X. Where are you using it? Product description sounds like you're using it in apartment building hallways almost like a vinyl wallpaper substitute.
You ever bring it into residential? Long hallway in a raised ranch?
Old 05-24-2019, 07:06 PM   #18
Rewards Points: 8
I’m using it as my main trim paint now but my local Ben dealer says it’s good for everything. There’s some talk about how hospitals paint their halls every few months but switching to Scuff-X has made it so they get over twice the time between repaints. I guess the issue is gurneys banging the wall.
Dealer said all his big paint firms are switching from Advance to Scuff for residential trim.
The Following 3 Users Say Thank You to Big Johnson For This Useful Post:
artinall (05-24-2019), Easy Gibson (05-29-2019), EricBrancard (05-31-2019)
Old 05-31-2019, 12:55 PM   #19
Rewards Points: 220
In my house I have Ultraspec, Ben, Regal Select, Aura and PPG Breakthrough. I'm going to start repainting my first floor trim with Scuff-X now. While I love Breakthrough, it's kind of a pain because I have to drive to the PPG store to get it (which is out of my way) and it's a completely different color fan than BM. This is why I tried Scuff-X which I am very happy with.
Breakthrough vs Scuff-X so far. BT dries much faster and has better block resistance. Scuff-X sands to a powder and feels/looks more like a WB Lacquer finish. Block resistance of the satin is ok but not as good as BT. I hear the semi gloss has much better block Resistance than the satin.
I'm going to be trying Scuff-x on a stairwell and hallway soon in the matte finish. Normally I would use Regal select for this. I hear the scuff-X has a higher sheen in matte than select which would make me shy away from it because I usually want as low a sheen as possible. In this case, I skim coated the walls so the higher sheen and light washing won't be an issue. If the Scuff-x matte ends up looking ok, I may transition to it for walls and trim/doors as It costs me less per gallon than select.
Old 05-31-2019, 12:59 PM   #20
Rewards Points: 220
I despise Advance. Some guys can get great results with it, but I hate it. That said, I still think Advance reaches a harder final finish after it cures sometime months after its applied. Initial hardness with Scuff-X is impressive, though.
