What Makes Paint Do This? - Painting & Finish Work - Contractor Talk
Old 09-21-2016, 09:26 AM   #1
steveo1018's Avatar
Rewards Points: 42
Hey name is Steve I'm new here and I've been having this issue for a year only on some jobs, any of you pros out there know what makes it do this? Its only on doors and trim
Sent from my LGLS990 using Tapatalk
steveo1018 is offline
Old 09-21-2016, 11:18 AM   #2
Thread Reading Aficionado
Builders Inc.'s Avatar
Trade: Certified Building Contractor
Rewards Points: 1,458
Re: What Makes Paint Do This?
Latex over oil based paint?
Builders Inc. is offline
The Following 3 Users Say Thank You to Builders Inc. For This Useful Post:
Big Shoe (09-22-2016), Railman (09-21-2016), SmallTownGuy (09-21-2016)
Old 09-21-2016, 12:28 PM   #3
steveo1018's Avatar
Rewards Points: 42
That was what I was thinking, I'm debating on maybe the next job to prime it quickly with kilz or just try an oil based paint. Good idea?
Old 09-21-2016, 01:03 PM   #4
madmax718's Avatar
Trade: General
Rewards Points: 3,276
Try wiping down the surface before paint. Could be dust.
madmax718 is offline
Old 09-21-2016, 01:34 PM   #5
TimberlineMD's Avatar
Rewards Points: 738
Give the woodwork a TSP/alcohol rub before paint.
It's easy to have a business that is busy.. it's harder to have a business that makes a profit
TimberlineMD is offline
The Following 3 Users Say Thank You to TimberlineMD For This Useful Post:
hdavis (09-22-2016), robert c1 (09-25-2016), sunkist (09-21-2016)
Old 09-21-2016, 01:47 PM   #6
Talking Head
EthanB's Avatar
Rewards Points: 438
Something is inhibiting the bond. Common culprits that I would look for are silicone spray near stone counters, furniture polish w/ wax in it, grease, etc.
Wipe thoroughly with alcohol and then test it again after it dries.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
Old 09-21-2016, 02:17 PM   #7
Yes trisodiumphosphate I think that's how you spell it. TSP. Clean it with that. And make sure there's no silicone caulk that was used by a hack trim carpenter. Paint will not bond to silicone caulk like Ethan said
The Following User Says Thank You to Builders Inc. For This Useful Post:
Old 09-21-2016, 03:01 PM   #8
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,366
I've had this happen around bathrooms. I believe it'a due to a build up of air freshener sprays people use in bathrooms which leaves a film on the trim.
Caslon is offline
The Following 3 Users Say Thank You to Caslon For This Useful Post:
hdavis (09-22-2016), SmallTownGuy (09-21-2016), VinylHanger (09-21-2016)
Old 09-21-2016, 05:33 PM   #9
PRP's Avatar
Trade: Painting Contractor
Rewards Points: 132
Trim only, I'd bet on Pledge or Murphys oil soap or another cleaning product was used to on it. Wipe with denatured alcohol.
PRP is offline
Old 09-21-2016, 05:49 PM   #10
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
T.s.b rules
sunkist is offline
Old 09-21-2016, 05:55 PM   #11
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Had it happen recently on a bathroom wall - just blamed it on aerosol hairspray or deodorant because it was just at shoulder height.
SmallTownGuy is offline
Old 09-21-2016, 06:00 PM   #12
steveo1018's Avatar
Rewards Points: 42
Thanks guys, I will have to give all of these a try on the next job. just an FYI I have been switching between the behr alklyd paint and Sherwin Williams pro classic and both have reacted the same way. Any ideas on a better paint?
Old 09-21-2016, 06:09 PM   #13
Railman's Avatar
Trade: Railing
Rewards Points: 1,161
TSP is the all time go to std for cleaning all sorts of crap. It will also slightly etch the finish to create a better bond. I'd clean it, & then rub it down with a medium Scotch pad for a better mechanical bond.
Railman is online now
Old 09-21-2016, 06:38 PM   #14
PRP's Avatar
Rewards Points: 132
If you go with tsp make sure you rinse it after, it will leave a residue. Dirtex is a great no rinse cleaner.
PRP is offline
The Following User Says Thank You to PRP For This Useful Post:
EthanB (09-21-2016)
Old 09-21-2016, 06:48 PM   #15
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 870
Just doors and trim, odds are oil based paint. Used to use a product called Liquid Sandpaper that took care of that problem quick and easy.
Around bathrooms.....I usually blame hairspray...lacquer.
dsconstructs is online now
The Following User Says Thank You to dsconstructs For This Useful Post:
Old 09-21-2016, 07:11 PM   #16
steveo1018's Avatar
Rewards Points: 42
Do you know where I can get or if they still make this liquid sandpaper?
Old 09-21-2016, 07:18 PM   #17
avenge's Avatar
Rewards Points: 298
Anyone paint store or big box store should carry it or something similar, it'a liquid deglosser.
avenge is online now
Old 09-21-2016, 07:19 PM   #18
John the Builder
http://www.homedepot.com/p/Klean-Str...N285/100112667
Krud Kutter too...
http://www.homedepot.com/p/Krud-Kutt...O326/203396842
The Following User Says Thank You to SmallTownGuy For This Useful Post:
dsconstructs (09-21-2016)
Old 09-21-2016, 08:01 PM   #19
Caslon's Avatar
I'd done a good job of scruffing up the trim before priming with a high quality latex primer, which should have been fine. Only...that light sanding didn't remove the film of whatever (hairspray, aerosol room fresheners). I'd rolled out the entire door ready to brush it out when the paint film started receding. I had to quickly grab a bunch of rags to remove the wet primer before it started to set up. Afterwards, I wiped down the door with lacquer thinner (about the same as Liquid Sandpaper) to remove all that junk buildup that sanding didn't. The primer went on fine afterwards.
P.S. This wouldn't have been an issue if I'd used a solvent based primer, but I prefer to save my brain cells by using a quality latex product whenever I can.
Caslon is offline
Old 09-21-2016, 09:57 PM   #20
rselectric1's Avatar
Rewards Points: 946
Please do an intro in the introduction section.
Are you a professional contractor or is this for your own home?
rselectric1 is offline
Paint or stain on hardi plank? Jer Painting & Finish Work 28 02-17-2017 08:29 PM
Porch and Floor paint on trim and doors and cabinets ? Preventec47 Painting & Finish Work 15 08-02-2015 10:20 PM
paint flaking from the ceiling...cause/solution?? lornmastro Painting & Finish Work 27 02-26-2012 11:01 PM
Best Paint for a Historic Home fatal_degree Painting & Finish Work 15 04-23-2010 08:09 AM
