Water Based Poly Over Latex? - Painting & Finish Work - Contractor Talk
Thread Tools
Old 08-09-2014, 07:22 PM
GODZILLANINJA's Avatar
Trade: Finish Carpenter
Rewards Points: 42
Hey, has anyone ever applied wb poly over latex to make it more durable and feel less tacky to the touch?
GODZILLANINJA is offline
Old 08-09-2014, 08:23 PM
hdavis's Avatar
Rewards Points: 2,358
Re: Water Based Poly Over Latex?
Do you mean waterborne polyurethane or water based polyacrylic?
hdavis is online now
Old 08-09-2014, 08:35 PM
avenge's Avatar
Rewards Points: 130
It's done all time but why does the paint feel tacky?
avenge is online now
Old 08-09-2014, 08:53 PM
hdavis's Avatar
Probably the brand / sheen. Only really popped up in the past 5 years with the reformulations, as far as I can tell. Even some 100% acrylic enamel semi glosses have this problem. Mostly cheap lines:
Color Place (was OK when SW made it)
America's Finest (practically unuseable after reformulation)
Some of the other Glidden lines
Some BM Impervo
Old 08-09-2014, 09:30 PM
Rewards Points: 42
I meant waterbased polyurethane.
The paint is SW Pro Mar 200 in semi gloss.
Old 08-09-2014, 09:37 PM
Rewards Points: 42
I have wonderered if the tackiness was due to the fact that our company's regular painter was applying coats too quickly, but after using the paint myself and letting each coat dry overnight, the tackiness is less pronounced but still there. If you set something on a painted piece and then take it off its sticky for lack of a better phrase.
Old 08-09-2014, 10:01 PM
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
Use an enamel pro mar is a wall paint.
Metro M & L is offline
The Following 2 Users Say Thank You to Metro M & L For This Useful Post:
GODZILLANINJA (08-23-2014), hdavis (08-09-2014)
Old 08-23-2014, 12:33 AM
DavidRackley's Avatar
Rewards Points: 52
For use water based poly over latex make sure the surface is fully dry and free of dust, it helps the polyurethane adhere better. Before applying the second coat, the first coat must be dry. It is quit time consuming method. As you are using water-based polyurethane, so cover any air vents or ducts in the room to minimize dust in the air.
http://123paintingpros.com/
DavidRackley is offline
The Following User Says Thank You to DavidRackley For This Useful Post:
Old 08-23-2014, 07:13 AM
Rewards Points: 42
We have more built-ins to do in the closets and I suggested to the lead man to use the pro-classic. Im looking forward to seeing the difference.
Thread Tools
Rate This Thread
Using water based dye outside. NYCB Concrete & Paving 0 10-10-2012 01:28 PM
Latex Primer over Poly Urethane?? DemRem Painting & Finish Work 32 08-19-2012 03:32 PM
High gloss water based? NEhardwoodfloor Flooring 7 02-21-2011 02:17 PM
Comments on replacing tank water heater with tankless CRIMPS Plumbing 3 12-04-2009 11:54 PM
Refinishing - 3 coats oil VS. 4 coats water based poly patrcarl Flooring 3 07-24-2009 09:56 AM
