Treating Pump Paint Sprayers. - Painting & Finish Work - Contractor Talk
Old 11-25-2018, 11:34 PM   #1
tjbnwi's Avatar
Rewards Points: 1,214
If I'm parking the sprayer(s) for more than a few days I use pump protector to treat the unit(s). Problem was always wasted treatment product. I solved the problem by creating a narrow vertical vessel instead of using a bucket.
It's simply a 3" diameter 16" tall piece of PVC pipe glue to a closet flange that has the test cap molded to it.
I have 5 gallons of protector mixed up. I set the pick up into the pipe, filled half way with protector is enough to treat the 395AAA or the Merkur. Both have 25' hose sets on them.
No more wasted mix.
Treating pump paint sprayers.-img_0757.jpg   Treating pump paint sprayers.-img_0758.jpg
tjbnwi is online now
The Following 6 Users Say Thank You to tjbnwi For This Useful Post:
griz (11-26-2018), hdavis (11-26-2018), Mordekyle (11-25-2018), overanalyze (11-26-2018), pinwheel (11-26-2018), sparehair (11-26-2018)
Old 11-26-2018, 09:19 AM   #2
tjbnwi's Avatar
Re: Treating Pump Paint Sprayers.
One other thing about pump service. Don't forget to check and top off the TSL daily.
Old 11-26-2018, 09:42 AM   #3
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 682
I really don’t see how the tsl works. It goes in a reservoir that feeds directly to the hose, it doesn’t go through the machine at all. I think it’s a scam by graco to sell more stuff.
Big Johnson is offline
Old 11-26-2018, 10:12 AM   #4
tjbnwi's Avatar
If you watch how the pump works, the TSL lubricates the connecting rod seal. The lube does not enter the hose.
I have a unit that does not need the lubricant, the pump is a diaphragm type pump.
Old 11-26-2018, 10:36 AM   #5
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,358
I like to put the tsl on threads of gun. It eats the paint and keeps everything easy to screw together. Also on the trigger assembly.
sparehair is offline
Old 11-26-2018, 05:53 PM   #6
Rewards Points: 682
I meant the prime hose. If you open the prime valve it dump whateverís in the tsl cup down the prime hose. So I guess if youíre supposed to mix it in the paint during the priming step it does that.
Old 11-26-2018, 06:45 PM   #7
tjbnwi's Avatar
Mine dies not do that. It stays in the cup. Ran a unit today for 8+ hours, TSL is down from the cup rim about 1/8"
Big Johnson (11-26-2018)
Old 11-26-2018, 06:46 PM   #8
Rewards Points: 682
Iíll get a video and TRY to post it.
Old 11-26-2018, 07:30 PM   #9
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,366
It's normal when spraying a lot of paint to see some milky looking paint on the piston as it rises and falls, even when using TSL. An excessive amount means the packings are starting to get worn. Not enough to freak out about unless you notice a drop in spray performance. If the packings are in good shape, it's not unusual to only need a little bit of TSL to top it off.
Caslon is offline
Old 11-26-2018, 09:08 PM   #10
tjbnwi's Avatar
I find it needs a topping off after 35-40 gallons.
Old 11-26-2018, 09:18 PM   #11
Caslon's Avatar
No more wasted mix.
If you do that math, a quart of optimally diluted concentrated pump saver costs just $0.40. If you use only a pint in there, that's just $0.20 used. How thrifty.
If you flush your unit enough with just plain water , until it's 80% water (to keep it okay for a few days), that won't hurt your airless. Splash a pint of diluted pump saver concentrate at the end after flushing most of the paint out, and you're fine (for a few days).
With the stainless steel parts and all, it will take more than a few days for corrosion to start. The paint will be diluted so much that there won't be any seating issues either (excluding diaphragm airless pumps maybe).
Caslon is offline
Old 11-26-2018, 09:53 PM   #12
tjbnwi's Avatar
I found that in a bucket I ended up putting far more than the pint needed in it. Using the pipe causes the mix to go vertical rather than horizontal.
As I stated, a few days, it gets flushed--twice. I run the material back into the container, about 15 seconds of pithing the product with water, Lock the trigger on, let the water circulate back into the bucket, after a couple of minutes, I swap water buckets, spray into bucket number one for about 30 seconds, drop the gun in bucket number two, let it circulate for a couple of minutes. Unlock the trigger, wipe the gun off, wrap the hose, leave the pickup in the bucket until the next day. I lock the trigger on because there are other better things to do than spray water in a bucket.
More than a few days, it gets pump protector.
Old 11-26-2018, 11:09 PM   #13
Caslon's Avatar
While I won't contest your method of keeping your airless fresh for a few days, I just don't see why using my method doesn't simplify things. The time to circulate water thru and out of the pump housing takes minutes.
Nevermind. Bravo.
Caslon is offline
Old 11-26-2018, 11:15 PM   #14
tjbnwi's Avatar
While I won't contest your method of keeping your airless fresh for a few days, I just don't see why using my method doesn't simplify things. The time to circulate water thru the pump housing takes minutes.
Let me type slower so you can comprehend what I've stated from the very first post of this thread.....
I only treat the pump if it will be more than a few days before I get back to using it. I do flush the pump at the end of every day with water.
Today we shot 25 gallons of Kem Aqua+, at the end of the day the units were flushed, tomorrow we need to shoot about 10 more gallons. After that is done, it will be a week to 10 days before they get fired up again. Tomorrow will include treatment.
Old 11-26-2018, 11:48 PM   #15
Caslon's Avatar
I dig what you're saying. Working out of a truck with an airless, not having a site to clean up. I have an endless supply of empty 5 gallon buckets to store my clean up water. Heh, lids are a must to keep clean up water from splashing out at a stoplight.
Caslon is offline
Old 11-27-2018, 12:11 AM   #16
Caslon's Avatar
I like your idea and all, only with a twist. When moving lo-boy airlesses over sometimes rugged terrain, it'd be cool not to have to drag along the 5 gal. paint can too. Your tube would attach itself to the airless siphon rod, and allow enough paint in the tube to keep recirculating fresh paint while moving the airless. The only thing shooting that down is having to pour paint into that little tube from a 5 gallon container.
I once thought I could shut down the sprayer for a few minutes. I was wrong, especially this primer I used way back. I left the sprayer off for 60 seconds and the sprayer froze up, totally gunked up. If only I could have kept a small amount of that primer re-circulating.
Keep a wet edge. Have I not said that all along? Hehe. Whether you brush or spray?
Caslon is offline
Old 11-27-2018, 12:31 AM   #17
tjbnwi's Avatar
Get a couple of these for the 5's. You'll have to cut the threaded part off, once it's gone the spout snaps into the gun hole on a 5 (it's designed to fit thread and snap in). As I said I have a 5 of protecter mixed, pours easily into the pipe.
I have the spout in the top portion when I pour out of a 5 until the 5 is half empty. Once half empty the spout can be in the lower pour position.
A couple of holes and some wire, you could "strap" the pipe to the bucket handle bail on the sprayer.
https://www.etundra.com/restaurant-p...hoCnGoQAvD_BwE
Old 11-27-2018, 12:49 AM   #18
Caslon's Avatar
I was replying to your idea and saying IF I worked out of a pickup with a sprayer sitting in the bed, needing to go for a few more days...self sufficient, contained...I could do it and have.
I grow weary reply posting to this thread.
Caslon is offline
Old 11-27-2018, 09:38 AM   #19
tjbnwi's Avatar
Simple solution---stop responding---works ever time for response weariness...
tgeb (11-27-2018), Wile E Coyote (11-29-2018)
Old 11-27-2018, 07:22 PM   #20
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 614
Iíve always used mineral spirits for storage of my airless rigs. Never had an issue doing that
Idothat is online now
5 coats of new paint peeled right off wall 18delta Painting & Finish Work 53 12-27-2015 03:13 PM
Pre-finished paint problems CompleteW&D Painting & Finish Work 13 05-29-2013 10:39 AM
Satin Paint vs. Stain on Rough Cedar Siding Biker01 Painting & Finish Work 4 09-21-2010 11:18 PM
Behr paint is great... lol Mike Finley Painting & Finish Work 132 08-14-2010 10:13 AM
Paint Sprayers Clev Contractor Painting & Finish Work 7 07-14-2008 10:31 PM
