Titian Return Hose - Painting & Finish Work - Contractor Talk
Titian Return Hose
Old 03-03-2019, 12:17 AM   #1
Stunt Carpenter's Avatar
Rewards Points: 1,616
Titian Return Hose
Hey Guys,
I was priming some mdf cap and window boxes in my basement tonight and blew a hole in the return hose of my Titian 440
I donít think I can get a new one till Monday but not sure if itís safe to leave oil primer in the sprayer till then?
Unless anyone has a quick fix for it?
Thanks
Stunt Carpenter is offline
Old 03-03-2019, 08:13 AM   #2
tjbnwi's Avatar
Rewards Points: 2,686
Re: Titian Return Hose
It has a return hose?
Leaving oil primer in it for a day should not be an issue. Make sure the pick up is submerged.
tjbnwi is online now
Old 03-03-2019, 08:29 AM   #3
The small hose that is used for priming and cleaning. I thought it was called the return hose.
Old 03-03-2019, 08:33 AM   #4
tjbnwi's Avatar
Got it. I thought you meant off the gun. Never looked to see what it is called, my mind a primer hose.
That should be a low pressure hose, maybe a length of tubing and a couple of clamps to get you by for now?
Old 03-03-2019, 09:11 AM   #5
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 4,058
Don't know what might cause the hole to blow - haven't heard that one...
But just a reminder that if you go to do the inner filter, mine was reverse-threaded. Wrench ordered from Grainger, from what I recall it wasn't typical. (an older 440, pre-circuit board)
artinall is offline
Old 03-03-2019, 10:14 AM   #6
I think it was just age. Itís right under the fitting that threads into the sprayer. Probably kinked and the split when I went to clean the sprayer and it relived the pressure
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
artinall (03-03-2019)
To return or not return calls? Chenyi General Discussion 40 06-19-2018 09:11 PM
Delta "quick connect" hose assembly o ring maineuropa Plumbing 3 01-04-2013 06:01 PM
Air Hose Repair onmywayup General Discussion 23 10-03-2012 06:17 AM
Festool CT33 with hose garage BCConstruction Contractor Swap 4 10-01-2012 01:17 PM
Extra air return Irishslave HVAC 3 06-30-2012 03:31 PM
