Staining Log Home - Painting & Finish Work - Contractor Talk
Staining Log Home
Old 05-05-2015, 11:38 PM   #1
Frostpro's Avatar
Trade: Painting Roofing Siding
Rewards Points: 12
Staining Log Home
I am looking into re staining a log home that is 10 years old. The stain they used before is a water base stain and only lasted about 3 years. The home is in direct sunlight with no shade. They want to use an oil base stain that will last at least 5 years. If they have to touch up spots before 5 years there fine with that. The logs are really dried out and look like there 20 years old. What would you recommend for prep without blasting? Pressure wash and spray brightener to clean it. Also what stain would you recommend? There looking it TWP stain. It's located in Central Wisconsin.
Frostpro is offline
Old 05-06-2015, 09:49 AM   #2
mrcharles's Avatar
Trade: GC, Remodeling
Rewards Points: 1,652
Re: Staining Log Home
We are going to put stain "there"
"They're" going to buy stain.
That is "their" stain.
Sorry, just bugs me to no end. I would be somewhat concerned if the oil based stain will penetrate the wood, or just sit on top of the old latex based stain.
This company has a nice pros and cons list of all the types of stains, http://www.logcabinrestorationservic...og-Home-Stains. You could probably contact them and ask their advice if you are not in their market place.
mrcharles is offline
Old 05-06-2015, 08:10 PM   #3
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,976
First will the existing surface take a stain or does it still repell? That will determine the prep that is necessary.
I would be concerned about being asked to rule out latex based stains, some are very good.
I like the SW Log Home Stain, it is excellent. Be sure to follow directions before applying as there are some factors to be followed.
Ohio painter is offline
Old 05-06-2015, 09:01 PM   #4
Frostpro's Avatar
Rewards Points: 12
Thanks for your input guys. The only spot that would repel water is underneath the porch, where the sun doesn't hit. I use Sherwin Williams all the time but haven't used the log stain yet. The sun is the biggest factor on this house. It's in a very open area with no shade. The home owners are not interested in latex stain.
Frostpro is offline
Old 05-06-2015, 09:24 PM   #5
kwunch's Avatar
Rewards Points: 596
I've only done one with it, and it was only a year ago, but it still looks mint. Which is hard to get from wood on the lake after long hard winters around here; house adjacent to it was stained about a month before the one we did was (they were built at roughly the same time, few weeks apart, new construction with a ship lap log facade), and that one looks nowhere near as fresh.
Did have a small problem area where a co-worker failed to keep the stain wet on wet and tried moving a bit too fast, not too bad though. Just don't get too far ahead of yourself and it looks mint.
kwunch is offline
Old 05-08-2015, 08:58 PM   #6
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,366
Is it a solid colored stain or semi-transparent stain? If the new semi is going over the same old semi color, then fine. If the new semi stain is going over a different color, then the old stain color underneath the new may cause color conflicts.
If I take a greenish semi-transparent stain and try to cover over an existing reddish colored semi-transparent, then you can imagine there's going to be a color conflict showing thru.
Caslon is offline
If you're not on Facebook, you should be. Sir Mixalot Marketing & Sales 1862 02-15-2020 02:59 PM
Get any and all Columbia Forest Products at Home Depot if needed TBFGhost Carpentry 15 01-02-2013 09:31 PM
New home cost estimator spread sheet? Joasis Technology 1 12-30-2012 01:29 PM
Vet Employment Issues at Home Depot? MAULEMALL Off Topic (Non Trade) 12 04-11-2012 06:01 PM
Illinois Mechanics Lien Forms and Instructions Ed the Roofer Business 4 02-23-2008 08:58 PM
