Stain Over Stain? - Cedar Lap Siding. - Painting & Finish Work - Contractor Talk
Old 10-14-2019, 01:23 PM   #1
acro's Avatar
Trade: Electrical
Rewards Points: 661
My personal house has rough sawn western red cedar lap siding. Originally finished 18 years ago with Sherwin Williams solid color Woodscapes House Stain.
Needless to say, I have high praise for the product and will likely use it again. My question is, now that it is time to re "paint" the house, is that the best product?
Maybe I am over thinking this, but a stain is a penetrating product to a large degree, and the wood is already "penetrated" so to speak. So, will the stain function properly?
Due to the very rough surface of the wood, prep will just be a pressure wash.
Thanks
acro is offline
Old 10-14-2019, 05:15 PM   #2
avenge's Avatar
Rewards Points: 298
Re: Stain Over Stain? - Cedar Lap Siding.
Solid stains don't penetrate.
avenge is offline
The Following 2 Users Say Thank You to avenge For This Useful Post:
hdavis (10-15-2019), Robie (10-14-2019)
Old 10-15-2019, 09:44 AM   #3
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,895
Can you try whatever you are thinking of using, on and inconspicuous spot first?
rescraft is online now
Old 10-15-2019, 10:12 AM   #4
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 1,042
Just stain it again with the same thing .
Of course, it has to be clean and free of mold and mildew.
Idothat is offline
Old 10-15-2019, 02:31 PM   #5
avenge's Avatar
Rewards Points: 298
For what? After 18 years that cedar is probably dry as a bone, powerwash and stain 2 coats.
avenge is offline
Old 10-15-2019, 04:04 PM   #6
acro's Avatar
Trade: Electrical
Rewards Points: 661
I have heard that, but...
Per the can...
"Long Lasting Penetrating Formula"
I have much more experience staining woodworking projects, not houses. And I know that once the top coat is on, a stain is not really an option after that.
Thanks for the input.
acro is offline
Old 10-15-2019, 07:35 PM   #7
avenge's Avatar
Rewards Points: 298
Per the can...
Solid stain isn't much different than paint, how else would you apply 2 coats? If you read the specs 2 coats are recommended. You're not staining over a top coat. You can apply solid stain over a primer.
avenge is offline
Old 10-15-2019, 10:10 PM   #8
hdavis's Avatar
Rewards Points: 1,186
Solid color stain is a paint formulated to weather away. The specific SW product doesn't penetrate for Jack, so they advise using their troubleshooting oil based primer last time I looked. Landscapes on weathered wood has inadequate adhesion.
Power wash it and 2 coats, just like painting a house.
hdavis is online now
Old 10-15-2019, 10:17 PM   #9
hdavis's Avatar
BTW, SW Woodscapes semitransoarent stain has better adhesion, so that's what I use as a primer these days. Put it on in the fall, 2 coats solid color stain or paint in the spring
Old 10-17-2019, 08:25 PM   #10
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,958
If you were planning to use the solid Woodscapes then i would lean towards using flat Resilience instead. My reasoning is that it will have better color retention than the Woodscapes.
Ohio painter is offline
Old 10-19-2019, 08:57 PM   #11
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,366
If the colors are similar and you don't want or need two coats, I'd go with a high quality solid colored stain. If using a semi-transparent stain, it might not give an even consistent look if some areas are more weather worn than others. I'm not talking about peeling, it's just that the new semi-transparent stain won't sit on top of the weathered paint film as much those areas that are in un-weathered good condition. Same happens when you cover over unevenly weathered surfaces with an enamel. The sheen will look uneven in places (when viewed at an angle to light) because it soaks in more at the weathered areas as opposed to areas that are still in less weathered condition.
Save yourself some money, too. If you're going over the same dark color in sound condition, you'll most likely be needing to re-paint down the road due to the color fading, not due to paint film breaking down.Therefore, no need to waste money double coating it. Heh, that won't keep "Deep Blue", or "Charcoal Grey", or "Jasmine Yellow" from fading out.
Caslon is offline
Old 10-28-2019, 08:39 AM   #12
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,030
I think I come across this contradiction of "penetrating" vs. solid color with an older stain they carried (20 yrs)
May want to recheck that new label as it could have been reformulated.
artinall is offline
