-   Painting & Finish Work (https://www.contractortalk.com/f8/)
-   -   Spraying crown moulding? (https://www.contractortalk.com/f8/spraying-crown-moulding-382089/)
JBH 01-24-2018 06:24 PM
@Ohio painter - I use pre-painted white hinges. Since 99% of the trim paint I use is white, no masking thus required. (If a client wanted different hinges, I would just spray with the white ones and replace them later with the client's preferred type - still easier than masking.)
@ Xtrememtnbiker - My current project is an 1800+ sq ft bungalow ground floor gut/reno + top-up addition. Not a huge house, but not tiny either. All trim and doors (except for the bathrooms, which were brushed/rolled as masking the already-tiled floor would be too much of a hassle) were sprayed in about an hour. With just a plywood subfloor elsewhere in the house, no masking/dropcloths were required - another major timesaver.
avenge 01-24-2018 06:27 PM
Originally Posted by JBH (Post 6719705)
In any newly-constructed space (i.e., all new drywall, all new trim) I use a Titan sprayer to do all the cutting in - walls, ceilings, trim. Then one coat satin latex on all trim (doors, jambs, casings, baseboards, crowns). No masking, not even window glass (a single-edged razor easily deals with the overspray). Then brush/roll the rest - I've never have a problem with the sheen on trim overspray showing through flat ceiling or wall paint.
Frankly I have no idea how anyone paints trim with a brush. With a sprayer I can paint every door and all trim in an entire house in an hour.
Bet you really have some really fine cut in lines with a sprayer. WTF
avenge 01-24-2018 06:29 PM
So you paint the hinges? Again...WTF
Golden view 01-24-2018 08:47 PM
House flipper? Unless you're just dusting with paint, I can't imagine the hinges take the paint well. And there won't really be paint on the trim next to them.
Standard new construction isn't that much different than what you do, but at least they take the doors off. And mask windows.
I helped someone flip 7 houses when I lived in Tacoma 18 months and didn't want to start my own business for such a short stay. Similar quality, similar time frames. 45 day whole house, mostly just me working. We didn't do bad work or hide things, we just rushed through stuff. Basically half the cost of the mid-range work I do now. New owners were always happy. Still better stuff than what's out there.
heavy_d 01-24-2018 10:32 PM
I sprayed the crown 2 coats today. Looks great! Will roll out the ceilings tomorrow.
Sent from my SM-G930W8 using Tapatalk
cedarboarder 01-24-2018 11:11 PM
I miss my little Graco cordless sprayer.
I am looked at the new ones with DeWalt batteries
heavy_d 01-25-2018 07:28 AM
That's the one I have. It's great!
Mordekyle 01-26-2018 12:20 AM
I just picked one up yesterday.
I'll see how it goes tomorrow.
heavy_d 01-26-2018 08:31 AM
https://www.instagram.com/p/BeW4ggbh6NU/
heavy_d 01-26-2018 08:32 AM
The 310 tip is still a little big I feel for crown and base so I may pick up a 208.
Golden view 01-26-2018 09:10 AM
That's a FF LP tip, right? At least on a big rig you can really turn down the pressure and not get tails, and paint pretty slow.
cedarboarder 01-27-2018 08:01 PM
what size batteries does it come with?
have you been able to run a battery dead since you are not spraying much?
