Sherwin Williams Tredplex - Painting & Finish Work - Contractor Talk
Old 09-27-2010, 10:50 AM   #1
randrohe's Avatar
Trade: Painter
Rewards Points: 25
Hello all,
I have a porch floor that is covered by a ceiling.
I sanded and washed the entire porch 4 years ago and spot primed with a coat of tredplex followed by 1 topcoat as per the recommendation of the SW rep.
There is failure on 40% of the joints of the flooring. (tongue and groove, not sure of the species of wood)
The Sherwin Williams rep told me that it was likely because the underside wasn't back primed. The porch has a 6 foot crawl space with a dirt floor without any kind of ventilation.
SW rep told me this was the problem and it is now a maintenance issue.
I believe the original coating was likely oil base.
This is actually a customers porch and I don't really want to give them this kind of news, as the original coating seemed to hold up much better than the tredplex..
Should I be looking at a different product? a different approach?
By the way, I asked the SW rep about the SW floor enamel and he literally said it was garbage!!
OK, thanks for any input
Randy Rohe
Bothers' Painting
randrohe is offline
Old 09-27-2010, 03:10 PM   #2
NAV's Avatar
Trade: commercial building restoration
Rewards Points: 250
Re: Sherwin Williams Tredplex
That's SW for you, they will never say that their product failed. It's always the application, moisture, delamination, anything other than a bad spec or bad material.
anyway, depending on where you are, 4 years is about as long as you can expect on exterior wood (at lease in Cleveland, Ohio)
Ask your rep "if you prime the bottom and you get moisture intrusion from the top, where is it suppose to go?"
NAV is offline
Old 09-27-2010, 06:15 PM   #3
Paint Dribblz's Avatar
Rewards Points: 25
If you use an oil based product you HAVE TO coat both the top and bottom of the floor. It has to seal, even on the bottom. I would use a waterbased stain.
Paint Dribblz is offline
Old 09-27-2010, 06:36 PM   #4
Professional Tradesman
GPI's Avatar
Trade: Painting-Wallcoverings-Drywall-Carpentry
Rewards Points: 250
Why in the World would you use armour seal tredplex on a wood floor? Did you not even look at the specs on the material? We have always used this product in an industrial environment as the coatings over concrete.
Calling all contractors, use the specification manuals on your products, please.Thats why they have them.... Not all reps are too swift, all reps will burn you when the time comes. I would replace the decking and learn from this. Stay away from floor coatings unless youre absolutely positive youre aware of the ramifications.
Failure in the joints is caused by expansion and contraction of the wood .Which tredplex has no flex. Let it dry on a brush, itll be rock hard in 30 min. Damage is damage..Replace it.
GPI is offline
Old 09-28-2010, 08:33 AM   #5
randrohe's Avatar
Trade: Painter
Rewards Points: 25
ok, thanks for the input.
replacing it is not an option.
In my ignorance, I did listen to the SW rep, but he is also the store manager and I felt had the most experience, or at least more than I.
The floor is not ruined, but does have some issues.
how about Benjamin Moore products? Anything from their line that may be helpful in this case?
randrohe is offline
Old 09-28-2010, 09:27 AM   #6
Rewards Points: 25
You may not like answers but if you've been paid for a complete hack job that failed you need to make it right. I've heard of people screwing up and walking out unpaid...still that should not be the case for any "contractor".
Old 09-28-2010, 12:10 PM   #7
randrohe's Avatar
Trade: Painter
Rewards Points: 25
yeah, thanks Dibblze..
I'm not out there "hacking" anything.
This was a case where I believe that I should have been informed by SW if there were any special precautions.
This house is over 100 years old and I don't believe there was much back priming done back in the day..Nor was Tredplex widely available..
thanks again
randrohe is offline
Walmart paint made by Sherwin Williams? KellyPainting Painting & Finish Work 54 01-18-2011 10:55 PM
Irritated with Sherwin Williams Dorman Painting Painting & Finish Work 16 03-14-2010 09:12 PM
Best practice quickbooks and hundreds of sherwin williams tickets Paint Poss Technology 1 03-09-2010 05:07 PM
I've found the best Sherwin Williams trim paint ever Dorman Painting Painting & Finish Work 16 04-03-2009 07:27 PM
Sherwin Williams high build primer jakester Painting & Finish Work 8 11-24-2007 08:29 PM
