Sherwin Williams Deckscapes On Vertical Surface - Painting & Finish Work - Contractor Talk
Old 10-11-2010, 08:12 PM   #1
randrohe's Avatar
Trade: Painter
Rewards Points: 25
I am staining a cedar log home with SW Woodscapes. I needed an additional 2 gallons to complete the job..I can't blame it on my employee, but I can point the finger at the SW manager who sold me Deckscapes instead of Woodscapes, and this after handing him an empty
Woodscapes can for a match...
Bottom line is, this went on a portion of the customers house as a second coat
Now I have to worry about what? Will it hold up? I would like to be u[p front and inform the customer, but I also am aware that it is partially my fault for not noticing this before it got emptied into the sprayer and shot on. I actually noticed when I was trying to do a couple of touch ups and the sheen was wrong....
Any thoughts? I'm mostly concerned with it holding up, or what to do if it doesn't....
Bring it on and don't hold the punches
Thank for your opinions,
Randy Rohe
Brothers' Painting
randrohe is offline
Old 10-11-2010, 08:38 PM   #2
Chesapeake's Avatar
Trade: Exterior Cleaning Contractor
Re: Sherwin Williams Deckscapes On Vertical Surface
I think you'll be ok using the deckscapes on the vertical surface. From what I remember, I think the deckscapes actually provides a harder finish because it is designed for horizonals, and made to be walked on. Now if you had used the woodscapes on a deck surface, I think you would run into problems. Check with your local SW rep to be sure.
Chesapeake is offline
Old 10-12-2010, 07:24 AM   #3
NAV's Avatar
Trade: commercial building restoration
Rewards Points: 250
I agree, you should be fine. I used Deckscapes on my fence because I thought it would hold up longer. It's been 4 years and water still beads up on it.
NAV is offline
Old 10-12-2010, 04:20 PM   #4
randrohe's Avatar
Trade: Painter
Rewards Points: 25
thanks for the input..that seems logical........
randrohe is offline
Old 10-15-2010, 12:34 PM   #5
Youcanpaintit's Avatar
No. there is a reason it says Deck, you need woodscapes for vertical surfaces.
Youcanpaintit is offline
Old 10-26-2010, 05:38 PM   #6
Paint Dribblz's Avatar
Rewards Points: 25
You will be in better shape coating your vertical surface with Deckscapes especially where the sun hits the most. It will take longer to fade out because of the formula having more UV protection.
"I think the deckscapes actually provides a harder finish because it is designed for horizonals, and made to be walked on."
Yes. The question is; is the Deckscapes you used oil? Does the coating clearly look different from the sides where you used Woodscapes? Guarantee the side you used Deckscapes holds at least two years longer than the others.
Paint Dribblz is offline
Old 10-27-2010, 05:29 PM   #7
randrohe's Avatar
Trade: Painter
Rewards Points: 25
that's great news...
It is the water base formula, and actually, it is on the side with the most sun.
WIN-WIN
thanks for everyones input
randrohe is offline
Walmart paint made by Sherwin Williams? KellyPainting Painting & Finish Work 54 01-18-2011 10:55 PM
Sherwin Williams Tredplex randrohe Painting & Finish Work 6 09-28-2010 12:10 PM
Irritated with Sherwin Williams Dorman Painting Painting & Finish Work 16 03-14-2010 09:12 PM
Best practice quickbooks and hundreds of sherwin williams tickets Paint Poss Technology 1 03-09-2010 05:07 PM
I've found the best Sherwin Williams trim paint ever Dorman Painting Painting & Finish Work 16 04-03-2009 07:27 PM
