Sealing Old Wallpaper Paste Before Painting - Painting & Finish Work - Contractor Talk
Old 03-10-2012, 04:51 PM   #1
trscontract's Avatar
Trade: painting
I've used Gardz sealer for years over old wallpaper paste without any problems. Recently I used Roman pro rx35 on wallpaper tear out and it worked fine in one bathroom, under eggshell finish. But in the family room and foyer we put a flat finish and it all cracked up. So I ended repriming with old reliable oil. Now I'm trying to figure out why the rx35 worked in the bath but no where else. Anybody use this product? We removed all the wallpaper at the same time, sealed the walls at the same time and painted the same time.
trscontract is offline
Old 03-10-2012, 05:09 PM   #2
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,485
Re: Sealing Old Wallpaper Paste Before Painting
Maybe a different glue was used in the family room.
Did both of the rooms have the exact same wallpaper in them?
-Paul
TextureMaster.com
Checkout my YouTube Channel with 90,000 Subscribers and over 13,000,000 views
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
Old 03-10-2012, 06:07 PM   #3
Pete'sfeets's Avatar
Trade: house painting and miscellaneous repair
news to me ,I,ve never heard of painting over old glue, I always washed it off with flat scrubbing pads unless the drywall was destroyed, and then I suppose I'd use a fast dry oil prime,. The likely hood of painted over glue in a bathroom not reacting to steamy hot air , well I just can't imagine it would hold up for long anyhow. That's a trick I'm not too sure I'm ready to learn. Even clay glue I washed off.
If paint covers all sins ,,,then I guess I should be covered
Pete'sfeets is offline
Old 03-10-2012, 09:33 PM   #4
Trade: painting
It was different paper in bath. Same type of material and definitely done at the same time.
Old 03-10-2012, 09:43 PM   #5
Trade: painting
The RX35 product claims to seal out wallpaper paste even though its a water based product. It seems to be just like Zinnsers Gardz. We use gardz a lot because it is low odor. I was wondering if flat is more likely to crack up or if it is some different paste from bath.
Need help painting carpet GibsonGuy Painting & Finish Work 4 02-20-2012 11:28 PM
Looking for wallpaper paste machine 56" or bigger in milwaukee/chicago area bummer71 Contractor Swap 1 04-03-2011 07:07 PM
wallpaper paste syringe salmangeri Wallpaper 5 03-27-2011 07:04 PM
Looking for wallpaper paste machine wildwings Contractor Swap 1 02-24-2011 09:12 PM
Painting and sealing in the fall..too cold? RDBD Painting & Finish Work 5 10-25-2010 08:55 AM
