Screwed Up - Painting & Finish Work - Contractor Talk
Screwed Up
Old 05-06-2019, 06:55 PM   #1
Tom M's Avatar
Rewards Points: 12,458
Screwed Up
Not feeling well and just going through the motions and I overfilled spray foam in the rough opening of a door I was installing today. Normally I would tape off the jamb and after a few minutes of expanding I push back on it to control the expansion.
Well I went to lunch and when I got back it overfilled and crept around the face of the door.
I called my painter he said light sand the whole side and roll the door. Done in about an hour. The manufacter didn't see it that way. It's a made for Lowe's color /thermatru. They don't provide a potion. Factory finish fiberglass.
What to do......
Tom M is online now
Old 05-06-2019, 06:58 PM   #2
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 690
Re: Screwed Up
Acetone?
www.gebcon.com
tgeb is online now
Old 05-06-2019, 07:05 PM   #3
Tom M's Avatar
Re: Screwed Up
I was afraid of stripping the finish while moist and gambled on rubbing off cure. Doesn't work on curred
Tom M is online now
Old 05-06-2019, 07:13 PM   #4
Dan_Watson's Avatar
Rewards Points: 2,572
Re: Screwed Up
Not a Lowe's door, but Therm-tru prefinished from somewhere else and I used acetone without issue. But..it was very little area.
Dan_Watson is offline
Old 05-06-2019, 07:21 PM   #5
Tom M's Avatar
Re: Screwed Up
Not like this......I was out of it today
Tom M is online now
The Following 4 Users Say Thank You to Tom M For This Useful Post:
artinall (05-07-2019), greg24k (05-06-2019), MarkJames (05-06-2019), TheConstruct (05-06-2019)
Old 05-06-2019, 07:32 PM   #6
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 506
Re: Screwed Up
Eek, that's a bad day right there
mrcat is online now
Old 05-06-2019, 07:40 PM   #7
woodspike's Avatar
Rewards Points: 440
Re: Screwed Up
i don`t get it .
i`ve gotten foam on doors before
it comes off.
you can use mineral spirits or even wd 40.and use a plastic putty knife .
why did it affect the finish?
or was that from you scraping it?
woodspike is offline
Old 05-06-2019, 07:47 PM   #8
woodspike's Avatar
Rewards Points: 440
Re: Screwed Up
i guess i`m wrong .
just read a bunch of articles , and they said no , mineral spirits doesn`t take it off.
i know its a bear , i thought i had removed it before that way.
one article said goof-off works , since it has same chemicals as acetone in it
Old 05-06-2019, 07:50 PM   #9
Tom M's Avatar
Re: Screwed Up
Thanks
Tom M is online now
Old 05-06-2019, 07:52 PM   #10
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,035
Re: Screwed Up
Oh man Tom, that's gorgeous. You could have put that in a popular thread here, the name of which I won't mention.
Sorry, I have no good solution for you. More often than not, I stuff 'em with fiberglass just so there's no chance of that sort of thing happening.
Tinstaafl is offline
Tom M (05-06-2019)
Old 05-06-2019, 08:02 PM   #11
Tom M's Avatar
Re: Screwed Up
Gonna try steel wool then a cloth with acetone. Quickly followed up with a dry wipe. If not I scuff the door and top coat it with something close.
Last thing I needed not feeling well.
Tom M is online now
Old 05-06-2019, 08:03 PM   #12
VinylHanger's Avatar
Rewards Points: 9,526
Re: Screwed Up
My doors at my house are similar though not as bad. I still look at it and go.. I should really cut that back.
Not much help I'm afraid. Though it is nice to know I'm not the only one who makes an occasional super duper oopser.
It sounds like a day you should have just bagged it and started over tomorrow. Problem with those days is you usually dont realize it until it's too late.
VinylHanger is offline
Old 05-06-2019, 08:08 PM   #13
Tom M's Avatar
Re: Screwed Up
Yeah....she's been waiting since November. Starting a bathroom later in the week and finally had a window of good weather.....so much for that.
I use the **** out spray foam too. I'm not a rookie. Nothing better to hold and air seal, nothing worse if you get it on yourself or anything other than what you want
Tom M is online now
Old 05-06-2019, 08:22 PM   #14
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 19,903
Re: Screwed Up
Read elsewhere that MEK will dissolve it, but not sure what it will do to the finish.
https://www.lowes.com/pd/Crown-128-f...ne-MEK/3024048
MarkJames is online now
Tom M (05-06-2019)
Old 05-06-2019, 08:23 PM   #15
KAP's Avatar
Trade: Custom
Rewards Points: 32,190
Re: Screwed Up
You might try pulling back on the insulation, then scraping with a plastic knife, followed by trying to get rid of dust/residue with Goof-Off / Goo-Gone (of course, try on inconspicuous area first) on a rag lightly working it off in downward strokes (don't drench it)... usually doesn't affect finished areas...
KAP is offline
Old 05-06-2019, 08:28 PM   #16
Tom M's Avatar
Re: Screwed Up
I used a wooden shim. Probably should have even left it overnight to harden more but was too anxious
Tom M is online now
Old 05-06-2019, 08:30 PM   #17
KAP's Avatar
Trade: Custom
Re: Screwed Up
So where are you at with it? Just the residue or is it done?
KAP is offline
Old 05-06-2019, 08:42 PM   #18
Tom M's Avatar
Re: Screwed Up
Residue film. I let it go for the day to think about it and calm down. Hoping the Wizard of CT had a bailouts.
Tom M is online now
overanalyze (05-07-2019)
Old 05-06-2019, 08:43 PM   #19
Tom M's Avatar
Re: Screwed Up
I was gonna just cut to the chase and ask Inner but Mark came along.
Tom M is online now
The Following 2 Users Say Thank You to Tom M For This Useful Post:
MarkJames (05-06-2019), tgeb (05-07-2019)
Old 05-06-2019, 09:01 PM   #20
KAP's Avatar
Trade: Custom
Re: Screwed Up
I haven't personally used it for foam, but Motsenbockers Lift-Off - 4.5 oz. Silicone, Latex Caulk and Foam Sealant Remover advertises it's made for that, is water-based and works on all surfaces...
Can get it at box stores for under $10... Good luck whatever solution you choose...
KAP is offline
The Following 2 Users Say Thank You to KAP For This Useful Post:
Tom M (05-06-2019), VinylHanger (05-06-2019)
First time you got screwed Idothat General Discussion 23 06-20-2018 08:06 AM
I got screwed and screwed myself Michaeljp86 General Discussion 23 11-27-2017 11:53 PM
Screwed up on the Stain !! AcademyHardwood Flooring 7 10-03-2009 02:56 AM
screwed on siding baseline Carpentry 10 06-19-2009 06:58 AM
remove glued and screwed sub floor codaman General Discussion 14 12-19-2008 01:19 AM
