Removing Old Glazing Putty - Painting & Finish Work - Contractor Talk
Old 12-14-2015, 04:32 PM   #1
CarpenterSFO's Avatar
Rewards Points: 2,044
Any magical suggestions about removing old glazing putty? It's sound and hard - no cracks or loose parts - but it's separated just enough from the glass to let water and air in. Not enough of a crack to fill with glazing or caulk.
Special multi-tool blade? Heat gun is barely faster than chisel or scraper alone.
I'm thinking about using the router and track - if I cut a rabbet big enough to get 90% of it the rest (at least the part against the glass) will come out easily.
Trim router and flush bearing bit for the parts up on the ladder.
I've sold them new windows for the rest of the house - these windows are pretty and will be refurbished.
I'll appreciate any advice.
- Bob
CarpenterSFO is offline
Old 12-14-2015, 04:36 PM   #2
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,706
Re: Removing Old Glazing Putty
Heat
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
The Following 2 Users Say Thank You to WarnerConstInc. For This Useful Post:
CarpenterSFO (12-14-2015), Warren (12-14-2015)
Old 12-14-2015, 04:36 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 398
How old is the stuff?
Just had some tested and it came back hot.
griz is online now
Old 12-14-2015, 04:48 PM   #4
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
steam - yawn....
(I can hear the jaws drop from clear over here)
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Old 12-14-2015, 05:10 PM   #5
hdavis's Avatar
Rewards Points: 1,556
Esiest is sub it...
Assume it's lead putty, unless you have data differently...
hdavis is offline
Old 12-14-2015, 05:10 PM   #6
avenge's Avatar
Rewards Points: 110
Ya just take those windows to your nearest steam room and invite some friends.
avenge is online now
Old 12-14-2015, 05:21 PM   #7
hdavis's Avatar
Everything I've tried has been covered....
hdavis is offline
Old 12-14-2015, 07:04 PM   #8
If you mean lead or asbestos, I can deal with that - this house is old, with asbestos siding over the original lap on the back of the house, layer after layer of lead paint, a child inside, and a couple of inquisitive neighbors outside. We've had plastic enclosures, wipedowns, double-bagged waste, the full treatment.
If by "hot" you mean radioactive.... yikes, really?
- Bob
Old 12-14-2015, 07:06 PM   #9
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 154
I wish I had some magic for you Bob on this but no such luck.
I have referbed many an old window with hardened putty around here in the Old Town district of Orange, CA. and many was the time I wished I had had a good way other than careful scraping. All the methods seem to have terrific draw-backs to them.
Andy.
ScipioAfricanus is online now
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
Old 12-14-2015, 07:20 PM   #10
oldfrt's Avatar
Rewards Points: 94
Worked in a hardware store when I was a teen,did all their window repairs using a glazing iron.
It had two heat coils,similar to the ones in old toasters,at a 90* angle for getting working the corners.Moved along pretty quickly.
Just had to get the timing down so you didn't singe the wood.
Very similar to the upper one in the pic at the top of this link;
http://www.myoldhouseonline.com/foru...02Comment21398
Good luck finding one though,probably not made anymore.
oldfrt is offline
The Following 2 Users Say Thank You to oldfrt For This Useful Post:
BRShomerepair (12-15-2015), CarpenterSFO (12-14-2015)
Old 12-14-2015, 07:33 PM   #11
Fire up the BBQ
griz's Avatar
Rewards Points: 398
Asbestos.
griz is online now
Old 12-14-2015, 08:40 PM   #12
tjbnwi's Avatar
Rewards Points: 1,138
Steam.
tjbnwi is offline
Old 12-14-2015, 08:48 PM   #13
Renaissance Man
superseal's Avatar
Rewards Points: 5,838
http://www.praziusa.com/putty-chaser/
Just hold your breath if it's hot
supersealconstruction.com
superseal is online now
The Following User Says Thank You to superseal For This Useful Post:
Old 12-14-2015, 09:08 PM   #14
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 14
If you end up using a heat gun, shield the glass with something to block the heat.
Ask me how I know.
Defenestrate is offline
The Following User Says Thank You to Defenestrate For This Useful Post:
Old 12-14-2015, 10:02 PM   #15
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,366
Laborious chipping out of the old glazing is sometimes the only way to go.
I've tried a heat gun on 30 year old aluminum window glazing on school building windows, and believe me, it's like trying to soften up granite.
Caslon is offline
The Following User Says Thank You to Caslon For This Useful Post:
Old 12-14-2015, 11:33 PM   #16
Heat gun, steam gun, and speedheater IR aren't having much effect, at least in the time I'm willing to spend. I don't want to reduce these windows to raw beginnings, and some of them are fixed, i.e. I can't get them out and to the shop.
So here's what I did:
Mask up, put a flush bit in the router, clamp track or board, and fire away.
Working so far.
and cut away.
- Bob
The Following User Says Thank You to CarpenterSFO For This Useful Post:
hdavis (12-15-2015)
Old 12-14-2015, 11:39 PM   #17
Fire up the BBQ
griz's Avatar
Rewards Points: 398
Working so far.
and cut away.
Hope you are wearing a GOOD respirator and have any other orifices
covered up...
griz is online now
CarpenterSFO (12-15-2015)
Old 12-15-2015, 12:00 AM   #18
VinylHanger's Avatar
Rewards Points: 11,514
I usually take a small chisel to get started. Then the best tool I've found is a regular glazing knife. They just work. Followed up by a chisel if needed.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
Ornamental Plaster (Removing Paint) Jason Whipple Painting & Finish Work 4 09-23-2012 07:55 PM
Sarco Putty (glazing compound) Jason Whipple Historical Restoration 11 06-09-2012 10:03 AM
removing glazing macbe Painting & Finish Work 21 04-19-2012 11:41 AM
removing sheen left by soft putty abdullahchris Finish Carpentry 7 06-03-2009 02:49 PM
