Removing Ceiling Popcorn That's Been Painted - Painting & Finish Work - Contractor Talk
Old 12-12-2018, 11:23 PM   #1
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 2,460
Never done it, never want to have to. My condo owner is looking to have it done and I want to let him know what he's in for cost wise. I know that removing unpainted popcorn is just a matter of wetting it thoroughly and scraping it off. It probably costs twice as much to remove painted popcorn?
The water can't soak in due to the popcorn having been sealed. The ceiling probably gets pretty scarred up having to scrape it off and likely needs extensive patching of the scars afterwards. Does water soak in at all?
Who here has removed ceiling popcorn that's been sealed? I bet it was no fun (which is why I avoid it).
Caslon is offline
Old 12-12-2018, 11:39 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 812
Re: Removing Ceiling Popcorn That's Been Painted
once sealed it is likely going to be very difficult to wet & remove.
just finished a remodel with approx. 1000 sq ft of painted popcorn ceiling.
drywall guy said it would be WAY cheaper to overlay than try to remove...
my previous experience as well....
griz is offline
Old 12-12-2018, 11:40 PM   #3
tjbnwi's Avatar
Rewards Points: 670
Planex on sealed popcorn after you verify there is no asbestos.
120 square foot ceiling takes about 2 hours. It will take some skimming to get it pretty.
tjbnwi is online now
Old 12-13-2018, 12:39 AM   #4
Caslon's Avatar
Ah. Thanks. Wasn't up on the technique nowadays. I YouTubed it. Probably should have in the first place.
I was also remembering how hard it must have been before planex, years back. I remember having the owner hire that part out. As I remember the ceiling needed a lot of skimming afterwards (gouge gouge).
Edit: I checked out a planex video. Was it the lighting on that video or what? What he was grinding off looked a lot less heavy popcorn than I'm used to seeing. Still, that's the way to go (for sealed acoustic).
Another reason I passed on acoustic removal is some older acoustic ceilings were in the asbestos time frame (still are).
Caslon is offline
Old 12-13-2018, 01:20 AM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 812
mine were asbestos
way faster & cheaper to encapsulate and finish than try to remove.
drywall guys had it overlayed w/two coats of mud in one day....
skimmed & skip trowled the next day...
pretty dam fast....
griz is offline
Sir Mixalot (12-14-2018)
Old 12-13-2018, 05:17 AM   #6
Caslon's Avatar
Originally Posted by griz View Post
mine were asbestos
pretty dam fast....
Overlayed? as in a 1/4" of drywall over the ceiling ?
Acoustic ceilings. All that ever did was hide faster drywall and taper mistakes. It never did an acoustic thing. My stereo speakers didn't sound any better.
Caslon is offline
Old 12-13-2018, 07:21 AM   #7
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 1,296
I’d expect to pay about $1/ft for what Griz describes, probably more in S. CA.
Big Johnson is online now
Old 12-13-2018, 11:38 AM   #8
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,762
I did a main floor and by the time I got to the living room, I was so fed up I dropped the whole ceiling and installed new drywall.
I would either do this or skim over it after knocking down the big chunks.
Sent from my SM-G930W8 using Tapatalk
heavy_d is offline
Crown molding against popcorn ceiling Shouldz14 Finish Carpentry 26 01-22-2016 08:15 PM
Scraping painted popcorn mike gunderson Drywall 39 12-03-2012 05:20 AM
How much should I charge for removing popcorn ceilings per sq ft? mnpainter General Discussion 5 08-06-2012 05:00 AM
Cutting Walls Along Popcorn Ceiling mc handyman Painting & Finish Work Picture Post 12 02-18-2012 07:47 PM
popcorn ceiling red_cedar Painting & Finish Work 8 04-14-2010 02:52 AM
